Tearing rear anti-sway mounts. - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-27-2013, 10:41 AM   #11
teamDFL
teamDFL's Avatar
Fan#: 92060
What I Drive: 2001 ZX3, 2012 SE Sport Hatchback
FF Reputation: 6 teamDFL Good Standing Member
Originally Posted by felixthecat View Post
Looks like they made the sway bar brackets a little smaller, then they should be. Funny my brackets don't look like those. Just to add, you'd feel the resetense in the bar as you'd rotate it, to mount the end links. And to add a little of the special grease.
Do you have the Steeda big bar? Both of the ones I bought have these bushings and the purchases were 10 years apart.
If you take off the end links and the bar does not drop so that the arms are pointing straight down, you have a problem. Race cars run sway bars through bearings for good reason.
Rich aka Dr. Bilkenstein, the three footed hobbit
Rally Revolution #21
teamDFL is offline
Old 11-27-2013, 10:54 AM   #12
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,906, Level 74
Points: 12,906, Level: 74 Points: 12,906, Level: 74 Points: 12,906, Level: 74
Level Up 14% Completed
Forum Activity 99%
I added the 28.6mm Addco bar in '08 to replace a Eibach 25mm one. Yea, your right about the bearings.
felixthecat is offline
Old 11-27-2013, 11:10 AM   #13
teamDFL
teamDFL's Avatar
Fan#: 92060
You should check yours in the same way I did mine. The bushing will not close around the bar. If you close the bushing, then it is the right size for the bracket, but since it should not close during use, well, you know the rest.
teamDFL is offline
Old 11-27-2013, 02:57 PM   #14
Templar
Templar's Avatar
Fan#: 795
What I Drive: Pitch black '03 Ford Focus ZX3
Points 3,912, Level 39
Points: 3,912, Level: 39 Points: 3,912, Level: 39 Points: 3,912, Level: 39
Level Up 75% Completed
FF Reputation: 4 Templar Good Standing Member
Buy-Sell-Trade Rating: (6)
It's the steeda bar.
"Logic is a way of saying that anything which didn't happen yesterday won't happen tomorrow"
- Robert Heinlein
Glory Road
"The question is, do you possess the constitution, the depth of faith, to go as far as is needed?"
- Boondock Saints
Templar is offline
Old 11-28-2013, 01:12 PM   #15
teamDFL
teamDFL's Avatar
Fan#: 92060
You need to do what I outlined above. FYI you can bend the mounts on the subframe is you tighten the bolts too tight.
teamDFL is offline
