Valve Tolerances on an Interference zetec? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-20-2013, 10:23 AM   #1
aheroicrevolt
le kittens meow
aheroicrevolt's Avatar
Fan#: 57964
What I Drive: 92 Burnt Orange Toyota Supra
Points 8,591, Level 62
Points: 8,591, Level: 62 Points: 8,591, Level: 62 Points: 8,591, Level: 62
Level Up 47% Completed
FF Reputation: 2 aheroicrevolt Good Standing Member
Buy-Sell-Trade Rating: (15)
I know the valves and lifters need to be in spec to the cams,
if they are out, you can order lash caps and other things, or drill out your lifters.
The distance between the bottom of your cam lobe, and the valve lifter if i recall is suppose to be-
Exhaust- .27mm -.33mm
Intake- .11mm -.18mm
I just got a valve job done on my head, and my exhaust valves measure a solid .33-.38 all the way across the board, and I know .33 is in spec, but do I SEROUSLY have to worry about .38? Is it going to hit the piston with that extra teeny tiny miniscule not even a hair thick difference? Or is this distance (between lobe and lifter) just effecting how long they are open, and if I have valve tick?
THe real problem is my intake side, the specs are way off. But again I am wondering how big of deal it is. If my car is just going to tick, then I dont really care, but obviously if the valve is going to hit the piston because these are so far off, thennnnn I need to fix it.
my intake valves are all .33-38 as well (between lobe and lifter) when they are suppose to be .11mm - .18mm
How much should I be worrying about it? Are we talking ticking or ruining another engine?
Dont worry about my signature btw-------, thats for a different car, this focus is being resold.
Looking for: T4 57trim or larger Turbo, Wideband Gauge with wiring and sensor, HKS VPC with 550 chip
aheroicrevolt is offline
Old 11-20-2013, 11:11 AM   #2
BigRed03
( o Y o )
BigRed03's Avatar
Fan#: 32177
What I Drive: 2003 CD Silver ZX5 SVT
FF Reputation: 9 BigRed03 Good Standing Member
Buy-Sell-Trade Rating: (4)
Did you measure all of your buckets before re-assembly? If you did, you could play with the numbers and swap buckets between intake and exhaust sides and see whether youd be within spec.
Otherwise its see if people parting out or have done engine rebuilds have spares you could buy or call steve.
Did you replace the valves with this valve job? typically due to the removal of material in the valve seat, the clearances are tighter than you are showing and a quick blast of material off of the valve stem tip would get them within spec. But since this is not your case...hmm
IIRC, you can buy shims, but its better to buy/find the bigger buckets themselves.
BigRed03 is offline
Old 11-20-2013, 03:20 PM   #3
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,808, Level 100
Points: 51,808, Level: 100 Points: 51,808, Level: 100 Points: 51,808, Level: 100
Level Up 0% Completed
Forum Activity 32%
Activity: 32% Activity: 32% Activity: 32%
Buy-Sell-Trade Rating: (28)
You need to keep the lash with in the specs called for , to much ticking will set off the knock sensor to pull timing which is bad , beat the tips of the valves / buckets and cause issues
To tight can burn a valve
There are no shims and nothing you can drill or machine
Your best bet is to take the head back apart and move the buckets around and cut the tips of the valve to gets things to work right , if the valve job was dont right all your valves should now be taller so cutting them to set your valve lash is easy and no need to buy any new buckets
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 11-20-2013, 09:38 PM   #4
F O C U S
F O C U S's Avatar
Fan#: 79747
What I Drive: 2003 SVT
Points 613, Level 12
Points: 613, Level: 12 Points: 613, Level: 12 Points: 613, Level: 12
Level Up 26% Completed
FF Reputation: 1 F O C U S Good Standing Member
So I'm guessing the measurements given up top are the correct ones?
Someone on another forum told me:
Intake .21-.29mm
Exhaust .32-.40mm
Guess I gotta call the machine shop
2003 Ford Focus SVT #1091
F O C U S is offline
Old 11-20-2013, 11:54 PM   #5
aheroicrevolt
le kittens meow
Fan#: 57964
i put in used valves from a different svt, did not reseat, just new seals, guides and retainers.
How can I actually measure the buckets? with a Micrometer?
Do i need a screw type micrometer? Where can I get one?
Old 11-21-2013, 06:08 PM   #6
aheroicrevolt
le kittens meow
Fan#: 57964
bump bump
Old 11-21-2013, 11:51 PM   #7
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 32%
You cant just take used valves and put them in another head , you need to take it to a machine shop and get them to do a valve job and have them set up the buckets before the assemble the head
If you sat with what you have chances are you will be pulling it back apart and doing the valve job anyway
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 11-25-2013, 09:03 AM   #8
amc49
Fan#: 96610
Points 3,258, Level 35
Points: 3,258, Level: 35 Points: 3,258, Level: 35 Points: 3,258, Level: 35
Level Up 39% Completed
Forum Activity 3%
Like he says absolutely you cannot just drop other valves in with no reseating, all valve run in differently from each other. simply swapping out they will NOT seal and engine runs like crap.
Valves hit pistons when they are too TIGHT, too loose they get more clearance. Think it out..................you lose lift with more clearance.
amc49 is offline
