voltage and rpm at idle - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-15-2013, 09:48 PM   #1
suby6
suby6's Avatar
Fan#: 57613
What I Drive: 2003 ZX5
FF Reputation: 1 suby6 Good Standing Member
My lights and dash have always dimmed at idle even with big 3 upgrade. Using the instrument cluster diagnostic mode i can see my voltage seems low at idle around 12.5v give or take. even seen it dip to 11.9. no batt light ever comes on.
Voltage even under load at higher than idle is a solid 14 minimum.
Have also noticed that the rpm seems to sit around 700 at hot idle. What should proper idle for a 03 zetec manual be? Does anyone have a definitive answer? Searching gave numbers all over the place. 700 seems low based on other cars I've owned.
Curious if voltage is lowering the idle or vice versa. No warning lights and doesn't misfire or stumble at idle.
Ive got a tune for 91, 02 delete, egr disabled, SRI, race header with small cat added. Alternator original and battery about 6 or so years old.
Any thoughts?
Am going to check terminals and reclean grounds soon plus will check for voltage drops.
Wish it is as fast as it sounds...
suby6 is offline
Old 11-15-2013, 11:10 PM   #2
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
Manual Zetec idle should be about 700 rpm so nothing untoward there. If the car idles without missing, shaking or stalling, the lower the idle speed the better, otherwise you're just wasting fuel.
On my '01, I see 14.5 volts right at idle. When it did fall to 11.9 - 12.5V charging system ("battery") light came on intermittently during long idles and DTC P1246 eventually registered (but no CEL light came on.) Have you scanned for pending codes? Alternator failed shortly thereafter (intermittent output due to failed VR, I assume.)
If you have a tune, your tuner should be able to bump the idle if it bothers you.
BC_ZX3 is offline
Old 11-15-2013, 11:49 PM   #3
suby6
suby6's Avatar
Fan#: 57613
Thanks for the info. Will check the cables and terminals but it does seem like an alternator is likely in the near future.
Just had electrical gremlins and an alternator replacement on the wife's escape now right after the focus follows suit lol.
suby6 is offline
Old 11-19-2013, 01:32 PM   #4
suby6
suby6's Avatar
Fan#: 57613
Picked up a refurb bosch alternator, belt, and tensioner.
Gonna drive it a bit more first to see if it gets worse to verify it being the alt.
still no batt light or trouble codes scanned.
Today the voltage seems to have increased where driving or high idle is pushing 15v and hot low idle 13.2 - 12.2 but sometimes around 14.
suby6 is offline
Old 11-26-2013, 01:58 AM   #5
suby6
suby6's Avatar
Fan#: 57613
Never did get codes or batt light but did have to nurse it home keeping rpm above idle.
Replaced the alternator (what a PITA) and did the belt and tensioner since I was in there. Battery too since it was 6 years old or so. Solid 14.4 now even at idle. No more dimming lights or odometer light blinking with the turn signal at idle. I think the old alt was on its last legs for a long long time.
To get the alt out you don't need to move the engine. Bend the bracket the block grounds to and move the metal tubes clipped to the firewall. One unclips where it connects to a plastic tube.
suby6 is offline
