Will 18" wheels eliminate wheel gap? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-14-2013, 04:21 AM   #1
z4nder
z4nder's Avatar
Fan#: 103345
What I Drive: 2010 Sangria Red SES
Points 866, Level 15
Points: 866, Level: 15 Points: 866, Level: 15 Points: 866, Level: 15
Level Up 66% Completed
Forum Activity 2%
FF Reputation: 1 z4nder Good Standing Member
I have a a stupid question lol. I'm thinking about getting 18x8 wheels and currently running 17x7 with 21545R17 tires. I'm thinking about going with 23540R18 tires for the 18x8 wheels. Would the diameter change? Would I have less wheel gap or would it be the same as my current set up? I was wondering because on very rare occasions if I hit a bad dip my front rubs and was curious if the 18x8 wheels would be worse in that situation or the same.
Thanks, alex
Sedan Revolution #287
Tennessee Focus Owner #12
z4nder is offline
Old 11-14-2013, 09:20 AM   #2
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,883, Level 59
Points: 7,883, Level: 59 Points: 7,883, Level: 59 Points: 7,883, Level: 59
Level Up 67% Completed
Forum Activity 30%
FF Reputation: 24 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
Use a tire calculator like this:
http://www.miata.net/garage/tirecalc.html
Those would be pretty close to the same diameter, wheel gap will not change. Where is your front rubbing now and how bad? Might not be a bad idea to figure that out and possible roll your fenders some, if needed then.
rambleon84 is offline
Old 11-14-2013, 10:38 AM   #3
Dgc333
Fan#: 85422
What I Drive: 2012, candy blue, SEL
Points 750, Level 14
Points: 750, Level: 14 Points: 750, Level: 14 Points: 750, Level: 14
Level Up 50% Completed
FF Reputation: 1 Dgc333 Good Standing Member
Here is a Focus ST with stock 18" wheels
The tires are within a couple of 1/10" of being the same diameter as the stock 16" or stock 17" tire/wheel combo. The tires sre sized to keep the outside diameter the same. The tires yiu are running are smaller in diameter than the stock 17"ers that came on the Focus. The stock tire is a 215/50-17.
The 225/50-17" winter tires I am running on my ST actually fill the wheel wells more than the 235/40-18s that came with the car. So if you want to fill the wheels more you need a larger diameter tire regard less of the wheel diameter.
Dgc333 is offline
Old 11-14-2013, 10:51 AM   #4
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Forum Activity 30%
He drives a 2010, his tires are sized correctly for 1st and 2nd gen Focus.
Old 11-14-2013, 01:32 PM   #5
z4nder
z4nder's Avatar
Fan#: 103345
Forum Activity 2%
Thanks guys, I'm pretty sure because of my Sportlines being soft, I'm rubbing on the liner when hitting a bad dip on the interstate. I can see where the tires skimmed the liner. I used the calculator that you provided, and compared the size of my stock tire to the tire sizes I'm thinking about getting for the 18x8 wheels. Like you said there wasn't much change in the sidewall or diameter. It was only either .1 or .2in difference. If that's the case I should be fine. I do want to upgrade to coilovers or a fixed platform and maybe roll the fenders a bit.
z4nder is offline
Old 11-14-2013, 02:27 PM   #6
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Points 36,605, Level 100
Points: 36,605, Level: 100 Points: 36,605, Level: 100 Points: 36,605, Level: 100
Level Up 0% Completed
Forum Activity 3%
Not only will it nit get rid of gap it will lift the car up a bit more.
I have 18s on my mk1 I've lowered the car so it has no wheel gap but it had more ground clearance than if I was running a smaller wheel.
With 18s I can lean my cell phone against the front lip, on my winter 15s I can just about lean my key fob against it.
TheGlassMaker is offline
Old 11-14-2013, 06:09 PM   #7
z4nder
z4nder's Avatar
Fan#: 103345
Forum Activity 2%
Yeah that's one reason why I'm looking at the 18s I want to be low and eliminate wheel gap but still have some clearance. Plus I just want a set Of 18s and 17s to switch off during summer and winter. Kind of a bad time since it's the start of winter to get new wheels because my 18s will have summer tires and already have all season tires on my current set up lol. The winters where I live barely get a inch of snow but do get ice every now and then.
z4nder is offline
