strut replacement--one or both? - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-14-2013, 03:20 PM   #31
fearfeasog
Fan#: 122137
What I Drive: Silver (grey) 2004 Focus ZTW
FF Reputation: 1 fearfeasog Good Standing Member
Originally Posted by rambleon84 View Post
I would suggest seeing if the endlinks are bad first...try disconnecting them and see if the noise goes away (jack car up, take off wheel, unbolt one of the endlinks. Put car the wheel back on, drop the car and test drive.) If it is, replacing those easy. Although after this many miles and years, good chance the front/rear struts need to be replaced soon.
Going back over this I realized I didn't quite get what you said here. the end links are part of what--the anti-sway bar? is that what the guy in this vid is working on in this vid: (It starts right at about 4:33)
YouTube Video
ff
fearfeasog is offline
Old 11-14-2013, 03:29 PM   #32
Miztaken1312
Miztaken1312's Avatar
Fan#: 74993
What I Drive: 2008 Black Coupe SES
Points 1,389, Level 20
Points: 1,389, Level: 20 Points: 1,389, Level: 20 Points: 1,389, Level: 20
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
FF Reputation: 2 Miztaken1312 Good Standing Member
This is an endlink.
FSWerks Turbo Kit @ 8psi , Stealth Exhaust, & Lower Stress Bar | Projectors w/5000K HIDs, LED Tails with Lamin-X Tint
Steeda Short Throw & Upper Strut Bar| FRPP Suspension & CFM Lower Mount |
Miztaken1312 is offline
Old 11-14-2013, 03:30 PM   #33
fearfeasog
Fan#: 122137
Ah, thanks! good pic. :)
Old 11-14-2013, 03:32 PM   #34
Miztaken1312
Fan#: 74993
There's a good thread on FocalJet about how to handle them.
Old 11-14-2013, 03:47 PM   #35
fearfeasog
Fan#: 122137
just signed up there so i could search, but do you have a link?
Old 11-18-2013, 02:39 PM   #36
fearfeasog
Fan#: 122137
Ok, gonna wave my noob flag proudly here! Questions to follow. To remind anyone who doesn't want to read this whole thread, I have a clunking noiise coming from the front passenger side, most loudly when I am nearly slowed to a stop and turning right to left, as while straightening the wheels while entering a parking spot.
I went exploring the front suspension etc during today's lunch break. All I had was the jack that you get with the car, so I wasn't able to play with loading the suspension with the wheel off. That said, this is what I found--
Passenger side (the side where my clunk is coming from)
  • End link felt solid
  • strut felt solid
  • axle had some play (subjectively--3/16's of an inch) when I grabbed it and pushed it back and forth along its axis
Driver's side (the quiet side)
  • strut felt solid
  • axle had some play (subjectively 1/16th of an inch), but not as much as the passenger's side axle
Questions:
  1. would I be able to tell anything about anything this way? For example, if the end links were bad, would having negative load on the suspension make it impossible to tell?
  2. Would a bad strut mount be obvious either with or without negative or positive load on the suspension?
  3. Is the axle supposed to have play along its axis? could that be my problem, and not the strut mount as the guys at Firestone said?
  4. Is there a way to tell if the strut mount is actually the problem without removing the strut?
Thanks all! ff
Old 11-18-2013, 03:08 PM   #37
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,342, Level 20
Points: 1,342, Level: 20 Points: 1,342, Level: 20 Points: 1,342, Level: 20
Level Up 43% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
Focus endlinks will "clunk" when driving over bumps/potholes at normal speed, not what you're describing. The play in your axles sounds normal, and a strut is a heavy duty item that's not gonna budge much by tugging on it unless you have the forearms of Popeye. Although you don't like Firestone's price, their diagnosis sounds right.
you might be in a little over your head on this one. if your experience to date is limited to replacing windshield washer hoses and lights, then a strut job is a giant leap and you might wanna grab an experienced buddy for the afternoon and do the job together.
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
Old 11-18-2013, 03:22 PM   #38
fearfeasog
Fan#: 122137
Thanks. I think I'll be able to handle it, but good advice anyway, sir. I'm pretty handy as long as I have the right tools. I do have a friend who can advise me, a neighbor, so he's close at hand. And he used to work as a mechanic so he's fully equipped. bonus!
ff
Old 11-18-2013, 05:52 PM   #39
Miztaken1312
Fan#: 74993
Just be very careful while doing this job. Serious injury is entirely possible if its done wrong. Most of the work can be done alone, but don't try and tackle disassembly of the strut alone. When using the spring compressors don't put your fingers in the coils and don't put your face over the assembly until you are 100% sure its tightened.
Sent from my Galaxy S3
Old 11-18-2013, 06:21 PM   #40
fearfeasog
Fan#: 122137
I'm not planning to build the strut. I'll buy the kit pre assembled from rockauto.com. So hopefully no need to worry! My face and fingers are too important to me...not that the face is much to look at.
if you watch the vid I posted earlier, you'll understand how I plan to go about it.
ff
