what to do next need help? - Page 2 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > DURATEC Ti-VCT Performance (2012-Current)
Old 11-11-2013, 04:56 PM   #11
calebstubstad
Chef Boyardee
calebstubstad's Avatar
Fan#: 103240
What I Drive: 2000 Atlantic Blue LX
FF Reputation: 4 calebstubstad Good Standing Member
search the forums, a few companies have tunes released. all of them have reported better performance, and they take advantage of the higher air flow and larger diameter exhaust.
Rally Revolution #43
[HOONIGAN]
Originally Posted by matmatician View Post
Not the bear the zoo deserves, but the bear the zoo needs.
calebstubstad is offline
Old 11-11-2013, 06:13 PM   #12
njfocus1992
njfocus1992's Avatar
Fan#: 119997
What I Drive: 2012 Blaze Yellow SE sports package
FF Reputation: 1 njfocus1992 Good Standing Member
What does it do to your warranty?
Sent from my DROID RAZR using FF Mobile
2012 se yellow blaze metallic tricoat sports package
fswerks race exhaust steeda cold air intake
eibach sportline springs cobb rear motor mount
st replica spoiler turbo tech upper motor mount
njfocus1992 is offline
Old 11-11-2013, 06:16 PM   #13
suss6052
suss6052's Avatar
Fan#: 95752
FF Reputation: 23 suss6052 Great Standing Member
It nominally voids it on your engine and transmission should you have a problem with either component after tuning. If it can be determined to have been caused by an attempt to increase performance.
An example from the Ecoboost 3.5L V6 TSB 10-2-6
Unauthorized calibration modifications may or may not be detectable using standard tools (Integrated Diagnostic System (IDS), Portable Diagnostic Software (PDS), NGS+ VCM). Changes can be made to the calibration and flashed to the PCM through the OBD port. Physical modifications to the hardware may or may not be present. If aftermarket power/torque-increasing modifications are suspected, care should be taken to record and store the following items: Permanent Diagnostic Trouble Codes (DTCs), Pending DTCs, Freeze Frame Data, Mode 6 and Mode 9 data. The data should be printed and attached to the repair order for later reference.
The DTCs, freeze frame data, Mode 6 and 9 data can be obtained by using the IDS, PDS or NGS+VCM under tool box selection. The Powertrain tab will provide the OBD Test Modes tab and Mode 6 and 9 data selection after the vehicle has been identified.
Attempting to increase the engine output via recalibrating the PCM may result in poor drivability, DTCs, or component failures. A partial list of calibration induced component failures is given below:
Piston damage.
Spark over-advanced (knock-induced damage).
Insufficient enrichment.
http://www.fordtechservice.dealercon...USA&tsb=10-2-6
That being said a tuner that knows what they are doing it's less likely that you would have long term durability concerns due to the tuning, but they don't spend the same amount on R&D as the vehicle manufacturer does.
suss6052 is offline
