Idle Issue Replaced IDLE SPEED CONTROL - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-10-2013, 09:24 AM   #1
FordFocus2002
Fan#: 113754
What I Drive: 2002 Green Ford Focus LR (MK1)
FF Reputation: 1 FordFocus2002 Good Standing Member
Hi Guys,
I recently replaced my IDLE SPEED CONTROL valve as I was having an idle issue plus other sensors but since the IDLE SPEED CONTROL valve was replaced with a new one it has developed a new issue. When starting the car for the first time each day the engine will kick over run then cut out real quick I then have to try and start again but this time it stays running as it should and no trouble for the rest of the day. This only happens for the first start of the day.
The one thing I noticed when when I removed the old IDLE SPEED CONTROL was that it had no gasket from what I could see but the new one came with a gasket and was installed with the new IDLE SPEED CONTROL.
Any help would be great.
FordFocus2002 is offline
Old 11-10-2013, 09:53 AM   #2
GreySkorpion
saved from the grave
GreySkorpion's Avatar
Fan#: 94674
Points 6,225, Level 51
Points: 6,225, Level: 51 Points: 6,225, Level: 51 Points: 6,225, Level: 51
Level Up 38% Completed
FF Reputation: 11 GreySkorpion Great Standing Member
Hmm, IAC should not affect starting, that is either a spark of fuel issue. Start with the 2 easiest things first, spark plugs and fuel filter.
What other sensors were replaced? MAF, or O2 sensors?
GreySkorpion is offline
Old 11-10-2013, 10:04 AM   #3
FordFocus2002
Fan#: 113754
I have replaced the O2 sensor, crank case hoses & PCV valve, throttle body & throttle sensor, leads & spark plugs. But these do not co in side with the issue it only started with the IAC being replaced straight away.
Old 11-10-2013, 08:44 PM   #4
paulg127
Fan#: 55998
What I Drive: 2003 Black SVT
Points 3,316, Level 35
Points: 3,316, Level: 35 Points: 3,316, Level: 35 Points: 3,316, Level: 35
Level Up 78% Completed
Forum Activity 2%
FF Reputation: 3 paulg127 Good Standing Member
IAC controls the air into the engine during starting. It is set to a desired AM for the given conditions.
Try starting it with you foot on the gas pedal, but only a very small amount.
If the IAC is doing something strange, it should stay started with the throttle.
Where did you get the IAC? The calibration for the IAC is tailored to the original part for the vehicle. Make sure you get a DIRECT replacement.
paulg127 is offline
Old 11-11-2013, 03:38 AM   #5
FordFocus2002
Fan#: 113754
It is a direct replacement for my engine. It was brought off ebay in the UK as here in Australia the a bunch of rip off merchants here.
I started it today and it didn't cut out but dropped in idle then rose up to a litle over 1000rpms it seems temp is a factor in this as I had parked it in my front yard over night and it was nice a warm this morning then the last few weeks of cold weather.
Old 11-11-2013, 04:42 AM   #6
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,700, Level 100
Points: 140,700, Level: 100 Points: 140,700, Level: 100 Points: 140,700, Level: 100
Level Up 0% Completed
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
Moved to the Technical Chat area
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 11-11-2013, 09:55 AM   #7
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,374, Level 20
Points: 1,374, Level: 20 Points: 1,374, Level: 20 Points: 1,374, Level: 20
Level Up 74% Completed
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
that's the answer
the only thing I would add is a reminder to reset the ECU by disconnecting the battery for a few minutes. Those new sensors you replaced are begging to be calibrated.
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
Old 11-18-2013, 08:37 AM   #8
FordFocus2002
Fan#: 113754
Originally Posted by my_beautious_ZX3 View Post
that's the answer
Yep did that didn't help still doing what it does. But now that our weather is warming up here it has stopped cutting out but still the revs drop right down to almost cutting out but goes to 1000rpms till it warms up then drops to about 800 to 780rpms.
The only difference is the gasket the new one came with a grey gasket and I am finding out about a O shaped rubber gasket I think that rubber gasket might still be on there with the new grey gasket will have to go through the pains of removing it again to find out.
Old 11-18-2013, 12:00 PM   #9
my_beautious_ZX3
Fan#: 32386
don't bother - if the gasket were to blame, you'd be having crappy idle all the time, not a one-off problem that goes away after a restart.
Many of the folks on this forum have complained that their aftermarket IAC valve was faulty. Some brands seem to be better than others, but I don't remember them; you might have some luck if you use the forum search box. The expensive Motorcraft part might be your only option, unless you want to gamble with a junkyard part. Alot of us (me included) fixed the problem by cleaning & reinstalling the old IAC.
don't say that, now I hate you. yesterday we had rain+70mph winds and tonight our temperature is predicted to drop to -2C.
Old 11-18-2013, 07:51 PM   #10
amc49
Fan#: 96610
Points 3,390, Level 36
Points: 3,390, Level: 36 Points: 3,390, Level: 36 Points: 3,390, Level: 36
Level Up 27% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
You can run the paper gasket on top of the rubber one and runs fine, don't screw with it. Everybody thinks there is no gasket on it; 9 times out of 10 it sticks to the intake.
amc49 is online now
