Help with hesitation above 3000 rpm - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-27-2013, 11:35 AM   #11
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 3,482, Level 36
Points: 3,482, Level: 36 Points: 3,482, Level: 36 Points: 3,482, Level: 36
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
Forum Activity 27%
Activity: 27% Activity: 27% Activity: 27%
Originally Posted by Mattdiem View Post
was the car ever fixed? having same issue
Have you been to the dealer for this concern? You may locate one and schedule an appointment here.
Let me know if you have questions.
Todd
FORD SERVICE
p: 800.392.FORD
FordService is offline
Old 11-27-2013, 11:38 AM   #12
FordService
Official Ford Rep
Fan#: 79824
Forum Activity 27%
Hey Mattdiem,
Have you been to the dealer for this concern? You may locate one and schedule an appointment online here.
Todd
OOPS! Double post. My B.
FORD SERVICE
p: 800.392.FORD
Old 11-27-2013, 12:01 PM   #13
Mattdiem
Fan#: 122801
What I Drive: 03' black svt focus
FF Reputation: 1 Mattdiem Good Standing Member
No not yet but considering it... I've never been to a car dealer for work in my life. But I'm getting to that point. I bought the vehicle from my father in law and have all his records. This car had been there for every oil change and had all sorts of work and TSB's done so I guess it got that firmware update. Anyway, I'm considering going in and letting them scan the shit out of it and maybe reflash. Just scared of insane prices.
Mattdiem is offline
Old 11-27-2013, 01:32 PM   #14
FordService
Official Ford Rep
Fan#: 79824
Forum Activity 27%
If and when you do decide to go, let me know how everything pans out.
I'm here if you have questions.
Todd
FORD SERVICE
p: 800.392.FORD
Old 12-07-2013, 09:00 PM   #15
LiciouzSVT
LiciouzSVT's Avatar
Fan#: 83568
What I Drive: 2013 Performance Blue ST
Points 1,170, Level 18
Points: 1,170, Level: 18 Points: 1,170, Level: 18 Points: 1,170, Level: 18
Level Up 70% Completed
FF Reputation: 1 LiciouzSVT Good Standing Member
Buy-Sell-Trade Rating: (6)
Yes I finally fixed it. Fuel pump. I had to use a box cutter blade to cut the old bracket out. I then had to use a shop vac to clean out the tank. The car runs like it is brand new now.
2003 Screamin' Yellow SVT - Wrecked
2004 Silver SVT- Sold
2013 Performance Blue ST- BEASTY
LiciouzSVT is offline
Old 12-14-2013, 06:15 PM   #16
Mattdiem
Fan#: 122801
For two days it ran perfect, then like flipping a switch, back to shitty. It was actually worse. Fell on its face a few times. Really seems like a fuel issue. I changed out the fuel pump and the sock attached to the pump was totally covered with brown crap. Anyway. No change. Didn't help. Wtf
Mattdiem is offline
Old 12-14-2013, 06:44 PM   #17
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
Any trouble codes present?
SVT does not use the same fuel pump as a normal Focus, FYI. So odds are the parts store pump isn't correct (it doesn't have the required fuel flow volume) but will probably work ... I'm pushing more fuel than a SVT pump out of my update pump, so the potential is there.
A trouble code is really going to help here.
Could be DSI error, VCT error or ignition troubles. Need more info.
iminhell is offline
Old 12-14-2013, 11:10 PM   #18
Mattdiem
Fan#: 122801
That's always been one of the things driving me crazy. Just like the op, no codes with this issue. I've been following and posting on a several forums about these similar types of stumble/miss, and read a bunch in the past. Most were never resolved or at least there was no follow up post with what the problem was, and some were fixed by things that didnt work for me. Here's the background info.... No work had been done to the car, wasn't a new tank of possibly bad gas. Was driving along one day and when leaving the next traffic light it started bucking and missing. Stalled when I pushed the clutch in. That was actually the worst. Started up fine and ran ok but had a part throttle cruising hesitation, that sort of progressed to a stumble only under load and only between 3000-4000 rpms. No cel at all.. Started changing and checking things and it's been better some days and really bad like today. Almost undriveable. So far I've replaced the coil, plugs, wires, the coil harness recall has been done and looks good, checked the coil capacitor, replaced tps, pcv valve, upstream oxygen sensor, and fuel filter. Found a cracked vacuum line, didn't help. Cleaned the maf. Cleaned and put back the vct solinoid. I guess it's working. The car was a slug with it unplugged, although I will say it wasn't missing when it was slow like that. I read that they usually snap off or leak if they fail. I did finally get a cel and some codes the other day. It stumbled really bad and stalled Was rolling and when I let the clutch out and refired the cel came on. I got sensor 1 lean condition, tps not agreeing with maf, and vct was retarded I think. Not sure which codes were real and which were me pulling harnesses and stuff. So far cel hasnt come back, and it's certainly bucking and missing. I've mostly read about the vct solinoid telling the tale of botched timing belt installs or vct gear springs snapping. Can they just start freaking out and causing issues? It's kind of pricey but I might have to try one. Next purchase for sure are new crank position and cam position sensors.
As far as the fuel pump goes I got it from rockauto. Your right, it's probably not the legit high flow svt focus. Although it was listed for the DOHC vin 5 motor, trying to research it was so annoying because every link was to an argument about what focus pump to put in a mustang. The specs showed it flow a shit-ton. More then the one I had in my mustang or grand national so I figure it might run. Lol. Anyway I can throw back in the stocker at some point if I have to since it wasn't the issue. Although it wasn't green on top or something like that I remember reading. Maybe it wasn't original. The one I put in was airtex 2386
Mattdiem is offline
Old 12-20-2013, 09:40 PM   #19
Mattdiem
Fan#: 122801
Fixed. Changed the cam and crank sensors.. Was better for 2 days and then came back. New MAF. And now it's perfect.
Mattdiem is offline
