Throttle bodies? - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Third Generation > DURATEC Ti-VCT Performance (2012-Current)
Old 11-07-2013, 12:58 AM   #1
tallted
tallted's Avatar
Fan#: 113572
What I Drive: 2012 Sonic Blue Ford Focus SEL
Points 449, Level 8
Points: 449, Level: 8 Points: 449, Level: 8 Points: 449, Level: 8
Level Up 98% Completed
Forum Activity 2%
FF Reputation: 1 tallted Good Standing Member
Throttle bodies?
Was browsing the net and found this:
http://www.twinkam.co.uk/shop/articl...3DSC240.001%26
Looks like they are offering crate engines with their own engine management system. What really interested me was the quad throttle body setup and 200 bhp rating. Wonder if they would sell those throttle body set ups individually...since its electronic Im assuming tuners would need to reprogram the throttle controls for it?
tallted is offline
Old 11-07-2013, 09:39 AM   #2
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,459, Level 75
Points: 13,459, Level: 75 Points: 13,459, Level: 75 Points: 13,459, Level: 75
Level Up 53% Completed
FF Reputation: 45 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (17)
That sure is purdy.
But the description doesnt say a damn thing about the ITB setup that you see in the pics, and in the other picture at the bottom is shows the stock plastic intake which one would assume is using the stock TB. which is electronic btw.
SkyPilot is offline
Old 11-07-2013, 09:45 AM   #3
GhostTribute
GhostTribute's Avatar
Fan#: 107929
What I Drive: 2001 Mazda Tribute (2.0L Zetec)
Points 279, Level 5
Points: 279, Level: 5 Points: 279, Level: 5 Points: 279, Level: 5
Level Up 58% Completed
Forum Activity 2%
FF Reputation: 1 GhostTribute Good Standing Member
If you click on the induction system drop down menu it gives you the option to go with the multi-throttle application @ $7638.00 + S&H USD. Not to mention it states that this item cannot be ordered at this time. Probably no longer in production.
You should contact them @ 01953 859785 for more information...
GhostTribute is online now
Old 11-07-2013, 10:41 AM   #4
Roadworthy
Fan#: 109039
What I Drive: 2012 SGM MK3 Titanium
FF Reputation: 1 Roadworthy Good Standing Member
Love the 4 direct throttle bodies!...except for routing to filters wouldn't be fun. I'm thinking someone can check out the Ford Racing site, Rousch or other Ford part numbers to find one that will connect up to our harness, or at least close. A larger TB and wider piping to the air box (wider maf opening too) should give some pretty good gains.
Back when I had my NA 2.3 Mazda 6, there was a user who would hone the stock TB to make it wider and clean off the flapper arm to allow for more airflow. Can be done on ours.....
2012 SGM Ti DCT Stock and loving it
OEM multispoke 17" with stock rubber summer-X-ice 3's on stuck rims = awesomesauce
Roadworthy is offline
Old 11-07-2013, 10:54 AM   #5
GhostTribute
Fan#: 107929
Points 279, Level 5
Forum Activity 2%
You could go with a different engine management that doesn't require a MAF sensor. That way you can run individual filters and tune using Alpha N, TPS/RPM based tuning or a mixture of MAP and Alpha-N. there are a number of options out there
Or you could construct/buy an air box to fit over the throttles and run a MAF. I have done both with equally good results. Ether way the key is the tuning hardware and software have used to make it happen.
Old 11-07-2013, 01:11 PM   #6
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 50,944, Level 100
Points: 50,944, Level: 100 Points: 50,944, Level: 100 Points: 50,944, Level: 100
Level Up 0% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
Buy-Sell-Trade Rating: (28)
Short of something like a 6000.00+ T6 or bigger you wont get anything less to run the 2012 and newer engines in a Focus
The UK focus ( pre 2012 ) comes with MAP change over the wiring and ECU , I am tuning a ITB Focus now with stock ECU and MAP , I have tuned a bunch of these NA and I am tuning a Turbo MAP Focus ECU as well which I tuned NA with the cosi intake
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 11-07-2013, 04:00 PM   #7
GhostTribute
Fan#: 107929
Points 279, Level 5
Forum Activity 2%
You're tuning using speed density.... blasphemy! ....lol
Old 11-07-2013, 05:17 PM   #8
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 31%
Yea I know it SUCK but thats what many of the UK Focus Duratecs came with , they actually do fueling by RPM more then MAP or TPS
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 11-08-2013, 02:52 AM   #9
tallted
tallted's Avatar
Fan#: 113572
Points 449, Level 8
Forum Activity 2%
Originally Posted by SkyPilot View Post
That sure is purdy.
Read the second to last sentence. The quad throttle bodies are an option. However in another area it says that this engine is currently not available. I may shoot them an email and see whats up.
tallted is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Cadillac ATS-V, Ford Fusion and Acura TLX. You can find all Ford Focus and Focus ST related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
