Time for new wheel bearings? - Page 2 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Brakes, Suspension & Body Chassis
Old 11-06-2013, 07:17 PM   #11
elsolo
elsolo's Avatar
Fan#: 96835
I had bad front wheel bearing in my Focus just a week ago.
Dragging screachy brakes sound when going straight.
Turn left is got quiet, turn Right it got louder.
The amount of wiggle is negligible without using a dial indicator, but the feel of the rotating hub (without rotor on there) was a dead giveaway, felt like a 1970's rollerskate wheel with uncaged bearings.
2.3, home fabbed Mustang GT brakes, SVT suspension
67 Chevelle SS-496, owned since 1991
elsolo is offline
Old 11-06-2013, 08:33 PM   #12
scott7278
Fan#: 100021
What I Drive: 2012 Red Candy SEL Hatchback
FF Reputation: 5 scott7278 Good Standing Member
Originally Posted by South03SVT View Post
I should have been more clear. The sound im talking about is the constant humming throughout the vid. The clunking sound was me going over a bridge lol. The humming sound starts out as a low growl at low speeds and becomes a steady hum once I get up to speed. I noticed when I turn my wheel to the right enough (mainly when getting off the highway on exit ramps) the sound will go away.
That would be the wheel bearings...the growl becomes continuous.
scott7278 is offline
Old 11-06-2013, 08:47 PM   #13
paulg127
Fan#: 55998
What I Drive: 2003 Black SVT
FF Reputation: 3 paulg127 Good Standing Member
Can you tell where it's coming from?
The passenger side half shaft has a bearing also. Mine started making noise, then the wheel bearings went, so I did the half shaft and wheel bearings together. Big improvement in noise. The wheel bearings take 5 bolts (not counting the wheel lugs) to take out.
surprisingly easy.
paulg127 is offline
Old 12-03-2013, 06:41 PM   #14
SVT54
Fan#: 119231
What I Drive: 2003 Black EAP SVT Focus
FF Reputation: 1 SVT54 Good Standing Member
You probably already figured it out, but I will post this for future people with this issue. When a wheel bearing goes, it will almost always make more noise with a load on it. Meaning if it is louder when you turn right, it's the left bearing. Louder when you turn left, it's the right bearing.
SVT54 is offline
Old 01-18-2014, 05:41 PM   #15
kingbedhead
Fan#: 114015
What I Drive: 2002 red svt
FF Reputation: 1 kingbedhead Good Standing Member
Just from reading that, I'm almost positive it's my bearings then since it does go away when im turning right. I haven't paid attention if it goes away when I turn left or not. That I'll have to check out.
Im replacing mine tomarrow jack car up see if wheel shakes when u wiggle it if it moves in anyway from side to side and up n down its barrings
kingbedhead is offline
Old 01-20-2014, 12:53 PM   #16
sxydevl69
sxydevl69's Avatar
Fan#: 132273
FF Reputation: 1 sxydevl69 Good Standing Member
I'm having the same problem but when I jacked the car up and grab the wheel it doesn't rock but it does have the brake drag when I spin it. Also when I accelerate the front passenger side engages faster and more aggressively. Could that be caused by the wheel bearing as well
sxydevl69 is offline
