shift tower?!?! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-04-2013, 08:04 PM   #1
wsharp
Fan#: 117557
What I Drive: 2004 silver svt/2000 jeep tj on 33s
Points 565, Level 11
Points: 565, Level: 11 Points: 565, Level: 11 Points: 565, Level: 11
Level Up 30% Completed
FF Reputation: 1 wsharp Good Standing Member
Exclamation shift tower?!?!
i have an 04 svt im 99% sure the tower is bad, all the bushings looked good to me but i think the ford OEM tower was like $500?!?!?! does anyone know of any cheaper places??
wsharp is offline
Old 11-04-2013, 09:26 PM   #2
NJSVTGUY
NJSVTGUY's Avatar
Fan#: 46519
What I Drive: 86 GN, 11.1@128, 20 psi
Points 4,555, Level 43
Points: 4,555, Level: 43 Points: 4,555, Level: 43 Points: 4,555, Level: 43
Level Up 3% Completed
Level up: 3% Level up: 3% Level up: 3%
Forum Activity 2%
FF Reputation: 8 NJSVTGUY Good Standing Member
Buy-Sell-Trade Rating: (10)
Where is the shift tower located? I have trans parts
NJSVTGUY is offline
Old 11-05-2013, 07:44 PM   #3
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 red mazdaspeed3 w/tech package
Points 4,236, Level 41
Points: 4,236, Level: 41 Points: 4,236, Level: 41 Points: 4,236, Level: 41
Level Up 44% Completed
Forum Activity 4%
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
Usually peeps refer to the shift tower that the driver would shift. What symptoms are you experiencing? If it's play in the lever the cables may need to be adjusted.
I now drive a Japanese Ford.
macdiesel is offline
Old 11-07-2013, 04:23 PM   #4
wsharp
Fan#: 117557
Yea side to side play is terrible and I couldn't find out how to tighten them a lot of people told me that that's not it... I still wana try but like I said I couldn't find out how to do to and did t wana brake it as its my daily driver
wsharp is offline
Old 11-07-2013, 06:42 PM   #5
jwgstang
Fan#: 116398
What I Drive: 04 Sonic Blue Focus SVT
Points 1,754, Level 24
Points: 1,754, Level: 24 Points: 1,754, Level: 24 Points: 1,754, Level: 24
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
Forum Activity 9%
FF Reputation: 1 jwgstang Good Standing Member
mine has a lot of play in it also you might want to check your trans bushings where the cables hook up to the tranny mine went bad and couldn't use some gears
jwgstang is online now
Old 11-07-2013, 07:34 PM   #6
wsharp
Fan#: 117557
Already checked as stated above
wsharp is offline
Old 11-08-2013, 09:17 AM   #7
NJSVTGUY
NJSVTGUY's Avatar
Fan#: 46519
Forum Activity 2%
^^ Thanks, hard to keep up with the terms.
If it's excessive side to side motion it's the cable that mounts horizontally on the trans, the first one you see looking down by the fuse box. Since your up and down isn't a problem I think you can isolate the shifter block/bushings. For the cable I would check that the lock collar is secure. I've seen them loosen quite a bit. Look for the orange square on the cable and follow it towards the pass side. Here the cable locks into it's bracket with a round plastic threaded collar. Size of a child cap on a medicine bottle. Check that collar.
NJSVTGUY is offline
Old 11-18-2013, 08:25 AM   #8
wsharp
Fan#: 117557
Bump
wsharp is offline
Old 11-18-2013, 09:09 AM   #9
qweesy
qweesy's Avatar
Fan#: 12042
What I Drive: 2004 focus Duratec 2.3 RS (DEAD)
Points 3,257, Level 35
Points: 3,257, Level: 35 Points: 3,257, Level: 35 Points: 3,257, Level: 35
Level Up 38% Completed
Forum Activity 18%
FF Reputation: 4 qweesy Good Standing Member
Buy-Sell-Trade Rating: (6)
Get the Delrin Square block or for a temp fix twist the OEM one 90 degrees, also replace the bushing on the side of the shifter arm and replace the shifter arm. most of the play will come from that little square block though, ask Steve about the delrin block.
spowell@tasca.com or call the dedicated toll free forum line at 1-800-598-1484
Block Im talking about
http://forums.focaljet.com/ford-svt-...o-sixth-5.html
qweesy is offline
