Focus Ti's Sport mode rolling downhill - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-03-2013, 10:31 PM   #1
narkotskyb
Fan#: 91412
What I Drive: 2012 Silver Focus Titanium
Points 777, Level 14
Points: 777, Level: 14 Points: 777, Level: 14 Points: 777, Level: 14
Level Up 77% Completed
FF Reputation: 1 narkotskyb Good Standing Member
Here is the scenario:
Pick a long and quite steep downhill (say 5 degrees and more)
Accelerate to about 40-50 miles before downhill starts then just let car roll downhill in "D" (do not touch accelerator) - it will stay in 6th gear and just roll and will most likely accelerate due to the grade.
Try the same thing in "S" and car will downshift after about 5-10 secs into either 4 or in my case 3 gear (engine will obviously rev up) and will drive like this all the way down - it will perform automatic engine braking.
So the ? being is DCT behaving as designed or not? I asked dealership and was told it is but somehow/somewhere it still reeks of BS for me. This is just a regular car - I would understand engine braking programmed into heavy duty trucks' transmission but Focus?
Anyone else came across this or willing to try to reproduce it?
narkotskyb is offline
Old 11-03-2013, 10:43 PM   #2
scott7278
Fan#: 100021
What I Drive: 2012 Red Candy SEL Hatchback
Points 1,485, Level 21
Points: 1,485, Level: 21 Points: 1,485, Level: 21 Points: 1,485, Level: 21
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
FF Reputation: 5 scott7278 Good Standing Member
It will do that with cruise control, too. I'm not really a fan of it, to be honest.
scott7278 is online now
Old 11-03-2013, 10:49 PM   #3
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 25,263, Level 95
Points: 25,263, Level: 95 Points: 25,263, Level: 95 Points: 25,263, Level: 95
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
Forum Activity 3%
This x2. Performing as intended, whether we like it or not.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is offline
Old 11-03-2013, 11:15 PM   #4
TKG26
Fan#: 117681
What I Drive: 2013/Grey/Ti-Focus
Points 486, Level 9
Points: 486, Level: 9 Points: 486, Level: 9 Points: 486, Level: 9
Level Up 72% Completed
FF Reputation: 1 TKG26 Good Standing Member
Believe its normal... In sport mode t keeps the revs up
Sent from my SAMSUNG-SGH-I747 using FF Mobile
TKG26 is online now
Old 11-03-2013, 11:39 PM   #5
NickCornell
NickCornell's Avatar
Fan#: 97233
What I Drive: 2012 Race red Focus SEL
Points 13,814, Level 76
Points: 13,814, Level: 76 Points: 13,814, Level: 76 Points: 13,814, Level: 76
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
Forum Activity 3%
FF Reputation: 12 NickCornell Great Standing Member
It's downshifting so you can accelerate quicker since you're on a sport mode
#SonicsMK3Crew
Follow #projectstreetdevil on IG @BBNickC
BUILD THREAD: http://www.focusfanatics.com/forum/showthread.php?t=323533
NickCornell is offline
Old 11-03-2013, 11:40 PM   #6
NickCornell
Fan#: 97233
Forum Activity 3%
Wait what? It does not do this with CC on my car
#SonicsMK3Crew
Old 11-03-2013, 11:53 PM   #7
scott7278
Fan#: 100021
It does with mine on a long, steep hill...I have to cancel it to get it to stop. I understand the purpose, but it is so loud that it's embarrassing, like the transmission broke or something.
It did it coming back from a Mizzou game with my Dad - the look on his face was priceless. He thought the engine was going to blow up.
Old 11-03-2013, 11:55 PM   #8
NickCornell
Fan#: 97233
Forum Activity 3%
If you're in CC with the car in select shift mode in 6th gear the car will absolutely not downshift
#SonicsMK3Crew
Old 11-04-2013, 12:33 AM   #9
Romans5.8
Fan#: 119488
What I Drive: 2014 Tuxedo Black Ford Focus SE
Points 582, Level 11
Points: 582, Level: 11 Points: 582, Level: 11 Points: 582, Level: 11
Level Up 64% Completed
FF Reputation: 4 Romans5.8 Good Standing Member
First off, big trucks don't engine brake. At least, not like your car does. We're talking about an engine that is about to explode when it hits 3,000 RPM's and a TON of weight behind it. They do use 'jake brakes' though, which stay at the same RPM (no downshift needed) but use a series of valves to basically turn the engine into a giant (and noisy) air compressor to give it the resistance needed to actually slow the truck down and prevent overheating the brakes.
Second, in sport mode, it's not a normal car. Normal, every day driving is for normal, every day mode. Sport driving is for... well you can take it from here!
And yes, it's the way it's programmed, and for 'sport' driving, it's the way it SHOULD behave. Keeping the engine revs up and in the powerband so the power is there instantly, should you need it. Just hit the accelerator, and go.
Finally, engine braking is something people have done, even in small cars and even on motorcycles (nearly all motorcycles are manual transmission) for a long time. Personally, I think brakes are cheap and a piece of cake to change. BUT, some people like to engine brake. Engine braking is not generally to 'increase' your braking performance. The brakes applied to the drive wheels will stop a lot harder than the engine will. Engine braking is to ease up on your brakes. It IS useful on long, steep grades (like coming down a mountain), to keep your brakes from overheating and/or rotors from warping. If you select the right gear you should be able to maintain a more/less constant speed with minimal throttle inputs and no brake while going down a steep grade.
2014 Ford Focus SE, Tuxedo Black (Sport pkg, 5spd manual)
2014 Ford Mustang Premium Convertible
2006 Kawasaki Vulcan 900 Classic LT, Thunder Blue / Graphite Two-Tone
2011 Honda Shadow Aero, Candy Red (Wife's Bike)
Romans5.8 is offline
Old 11-04-2013, 06:59 AM   #10
Joeywhat
Strichmädchen & Koks
Joeywhat's Avatar
Fan#: 85247
What I Drive: 2014 Mustang 3.7L SGM
Points 7,940, Level 59
Points: 7,940, Level: 59 Points: 7,940, Level: 59 Points: 7,940, Level: 59
Level Up 95% Completed
Level up: 95% Level up: 95% Level up: 95%
Forum Activity 8%
FF Reputation: 11 Joeywhat Great Standing Member
Sport mode, not select shift.
Hatch Nation #29
Joeywhat is offline
