Fuel pump replaced, still no fuel - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-03-2013, 02:59 PM   #1
tclundin
Fan#: 120437
What I Drive: 2001 Focus ZX3 2.0L Zetec
FF Reputation: 1 tclundin Good Standing Member
I'm working on my sister's 2001 Focus ZX3, Zetec engine. She left it with me for a while, was running fine. One day filled it up with gas, and it died before I left the station and hasn't run since. It'll start on starter fluid. Did a lot of research here and elsewhere and immediately saw all the issues with the fuel pump. Couldn't hear the fuel pump run when turning on the key. Confirmed that the fuse was good, that the passenger compartment inertia switch hadn't been triggered. So I dropped the fuel tank and replaced the fuel pump (NAPA brand, $65; fuel pump only, not entire assembly) and the fuel filter. Reinstalled everything; can now hear the fuel pump run when key is turned. But still no fuel reaching the engine. Pulled the hose off of the fuel rail; no fuel. Pulled the hose off of the fuel filter and tried sucking some fuel through; only a trickle. I don't see a way to check the fuel pressure on the Zetec engine (no pressure check valve on the fuel rail). I'm about to give up and have it towed to a garage. Would greatly appreciate any help or suggestions. I've read many posts on here about the fuel pump problems; sorry if this has been addressed and I missed a thread. Thanks.
tclundin is offline
Old 11-04-2013, 11:59 AM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,780, Level 100
Points: 51,780, Level: 100 Points: 51,780, Level: 100 Points: 51,780, Level: 100
Level Up 0% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
Buy-Sell-Trade Rating: (28)
With just the pump and not the assy what did you use to connect the fuel pump to the cannister assy , hose and clamps ?
I have seen a dozen times they use hose and clamps then when its put together the hose gets kinked and no fuel goes to the engine
If you can hear the pump running then I would look at how you have the hose tucked away when you put it together
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 11-05-2013, 07:32 PM   #3
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 12,994, Level 74
Points: 12,994, Level: 74 Points: 12,994, Level: 74 Points: 12,994, Level: 74
Level Up 36% Completed
Forum Activity 33%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moved to "General Technical Chat".
zetecDon is offline
