Help Quick Disconnect - Anderson Power Pole - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-02-2013, 11:10 PM   #1
mwalt2
Fan#: 118464
What I Drive: 2013 Silver SE Hatch
Points 346, Level 6
Points: 346, Level: 6 Points: 346, Level: 6 Points: 346, Level: 6
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
FF Reputation: 1 mwalt2 Good Standing Member
I am trying to make it easy to disconnect my sub/amp to free up space in my hatch when needed. I ran 4 gauge power and ground wires and bought a 175A #4 AWG Anderson Connector to use as a quick disconnect for the power and ground wires. Now I need to figure out how to attach the wires to the power poles for use in the connector. They're pretty big and about 1" of bare wire goes inside the connector. I've attached some pictures to show the size.
I don't really want to crimp the wires because 1) I don't have a crimper sufficient for #4 AWG and 2) if I misshape the power pole too much, it probably won't fit correctly in the connector. I tried putting solder inside the power pole, heating the whole power pole up, and shoving the wire in. This did not work too well when I first tried it...probably because I did not put enough solder in. The bare wire doesn't really fit in the power pole too easily and gets mangled if you try to shove it in quickly with several strands of wire bunching at the bottom of the power pole (not to mention melting the insulation off of the wire).
There have been many great threads on here that helped me with the rest of the install, so I'm hoping someone will have a good idea on how to go about attaching the power poles to the wire (should've just went with 8 gauge wire lol). Is adding more solder and pushing the wire in still the best bet?
Edit - after searching more, it appears there are crimpers out there for these (LINK). I doubt I'll spend $90 to use it 4 times, so any other ideas would be welcome. :)
mwalt2 is offline
Old 11-03-2013, 04:35 AM   #2
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 3,052, Level 34
Points: 3,052, Level: 34 Points: 3,052, Level: 34 Points: 3,052, Level: 34
Level Up 2% Completed
Forum Activity 3%
FF Reputation: 9 emsvitil Good Standing Member
Pre-tin the end of the wire so it's saturated with solder before inserting into connector.
Let solidify, and make sure you can slide it into the connector (you may have to file off solder blobs).
Put wire into connecter and solder.
Plus you need a high output soldering gun or iron to heat things up enough
Ed
emsvitil is offline
Old 11-03-2013, 08:45 AM   #3
DoogieB
DoogieB's Avatar
Fan#: 101748
What I Drive: 2012 Red Candy SE Sport
Points 1,000, Level 16
Points: 1,000, Level: 16 Points: 1,000, Level: 16 Points: 1,000, Level: 16
Level Up 50% Completed
FF Reputation: 2 DoogieB Good Standing Member
emsvitil is right on the money. Because of the wire size, it's going to be difficult if you don't have a soldering iron with active temp control, but a butane powered iron is handy for situations like this and they get hotter than H*ll.
DoogieB is offline
Old 11-03-2013, 10:57 AM   #4
mwalt2
Fan#: 118464
Points 346, Level 6
Thanks for the replies. I'm new to soldering, so I have a few more questions. Are you saying that by pre-tinning the end of the wire, that will be enough solder to hold things in place? Am I understanding correctly that I would add lots of solder to the end of the wire, let it cool, shape to fit in the powerpole, put it in the powerpole and then heat the powerpole enough to melt the solder again? I have a propane torch to heat things up enough, though I'm sure there are better tools out there.
mwalt2 is offline
Old 11-03-2013, 11:30 PM   #5
Lite12
Lite12's Avatar
Fan#: 118069
What I Drive: 2013 Race Red Focus SE 5dr
Points 118, Level 2
Points: 118, Level: 2 Points: 118, Level: 2 Points: 118, Level: 2
Level Up 36% Completed
FF Reputation: 1 Lite12 Good Standing Member
May I ask where you got the connectors? I just got my powered sub installed today and want to do the same thing.
2013 SE 5dr w/sport appearance, race red, 5mt
Amber LED frt markers, LED backups
Lite12 is offline
Old 11-04-2013, 01:27 AM   #6
emsvitil
Fan#: 50210
Forum Activity 3%
You also add solder when the connector gets hot enough. (test hotness with the solder, it will melt into connector when things are hot enough)
The flux in the solder helps melt everything together.
Add solder until the connector gets full.
Ed
emsvitil is offline
Old 11-04-2013, 08:31 PM   #7
mwalt2
Fan#: 118464
Points 346, Level 6
I bought them from Ebay. It was the cheapest I could find and came with everything you need to make the connection (2 connectors and 4 powerpoles). I think the seller has other sizes/colors. LINK
Thanks again
mwalt2 is offline
Old 11-05-2013, 02:32 PM   #8
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,573, Level 53
Points: 6,573, Level: 53 Points: 6,573, Level: 53 Points: 6,573, Level: 53
Level Up 12% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Buy-Sell-Trade Rating: (23)
A simple distribution block makes this really simple to accomplish.
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 11-05-2013, 03:00 PM   #9
clayton89
Fan#: 108214
What I Drive: 2006 Sonic Blue ZXW
Points 527, Level 10
Points: 527, Level: 10 Points: 527, Level: 10 Points: 527, Level: 10
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
FF Reputation: 1 clayton89 Good Standing Member
I'd agree here with you but I think he is looking for a really quick disconnect. I know a distribution block wouldn't take much time at all, but I'm sure he is looking to not have to dig out any tools.
I do have to say though I hope you are securing down your subwoofer box. Taking quick corners, hitting hard bumps, quick acceleration/deceleration can send the subwoofer box sliding and possibly rolling around which is never good.
clayton89 is online now
Old 11-05-2013, 05:39 PM   #10
ViperThreat
Dat boxer rumble
ViperThreat's Avatar
Fan#: 66026
What I Drive: '06 WRX Wagon 285whp/292wtq
Points 7,726, Level 58
Points: 7,726, Level: 58 Points: 7,726, Level: 58 Points: 7,726, Level: 58
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 9 ViperThreat Good Standing Member
Solder is your best bet. Also makes for a really clean looking install.
Moderator For: Socal Fanatics | SVT Focus | Mk1 Focus | Audio & Electronics | General Chat
"Ford Focus ST - the official car of message-board circle-jerks"
-Regular Car Reviews
ViperThreat is offline
