Hypothetical Top Speed calculations - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-05-2013, 11:42 PM   #11
turbosvtfocus04
turbosvtfocus04's Avatar
Fan#: 100806
What I Drive: 2004 black svt
Points 233, Level 4
Points: 233, Level: 4 Points: 233, Level: 4 Points: 233, Level: 4
Level Up 66% Completed
FF Reputation: 1 turbosvtfocus04 Good Standing Member
With lowering the car will help when it comes to high speed. Also with about 300whp you can too out the focus. It will take some time but if you do it on a closed track you are fine.
turbosvtfocus04 is offline
Old 11-06-2013, 12:14 AM   #12
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,933, Level 87
Points: 18,933, Level: 87 Points: 18,933, Level: 87 Points: 18,933, Level: 87
Level Up 17% Completed
Forum Activity 11%
Buy-Sell-Trade Rating: (4)
The Texas Mile does follow recommended safety protocol of LSR --> http://www.texasmile.net/pdf/TexasMi...-2-Edition.pdf
due note that EVERY car needs a roll bar.
'Street car' can be used pretty loosely here.
The thing you'll find very quickly is that RPM will be your friend,
https://docs.google.com/spreadsheet/...Wc&usp=sharing
Play around and you'll see what I mean.
I raised my limiter to 8,500rpm for this very reason. In the 1/4 mile I had to shift to 4th and every time I'd loose 3/10ths.
Plus the less you have to shift you gain the advantage of the TQ multiplication of the gear ratios. If you can avoid 5th you really want to ... and you also have to factor into your math that 5th is below a 1:1 ratio. meaning that you have to multiply your expected power by that factor to recoup losses.
And speedometers be damned.
There's a reason all top speed runs are timed and not based on a speedo or GPS.
iminhell is online now
Old 11-06-2013, 12:45 PM   #13
ViperThreat
Dat boxer rumble
ViperThreat's Avatar
Fan#: 66026
What I Drive: '06 WRX Wagon 285whp/292wtq
Points 7,819, Level 59
Points: 7,819, Level: 59 Points: 7,819, Level: 59 Points: 7,819, Level: 59
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
Forum Activity 13%
FF Reputation: 9 ViperThreat Good Standing Member
Also, lowering a car will NOT help with speed. You still have the same coefficient of drag.
Moderator For: Socal Fanatics | SVT Focus | Mk1 Focus | Audio & Electronics | General Chat
"Ford Focus ST - the official car of message-board circle-jerks"
-Regular Car Reviews
ViperThreat is offline
Old 11-06-2013, 01:01 PM   #14
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,911, Level 59
Points: 7,911, Level: 59 Points: 7,911, Level: 59 Points: 7,911, Level: 59
Level Up 81% Completed
Level up: 81% Level up: 81% Level up: 81%
Forum Activity 38%
Activity: 38% Activity: 38% Activity: 38%
FF Reputation: 24 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
I'm trying to wrap my head around this but why wouldn't a lower ride height be advantageous to a top speed? Not sure how measurable this is but wouldn't a lower car decrease the area of the tires exposed? I doubt this will have any effect on regular driving but perhaps at a top speed scenario it may be the difference of a tenth or hundredth of an mph lol
At least the lower/stiffer springs/shocks should provide some improved stability at those speeds. I bet alignment for those speeds is super important too
rambleon84 is online now
Old 11-06-2013, 01:11 PM   #15
ViperThreat
Dat boxer rumble
Fan#: 66026
Forum Activity 13%
Lowering a car will definitely help with the stability, however it wont make any difference in terms of drag. Basically, air hitting the center of the front bumper has 4 different paths to take. Up, Down, Left, or Right. Air will follow the path of least resistance, which in some-cases is down. The less room there is under the car for air-flow, the more of a vacuum it creates, which increases down-force on the car, which in turn helps improve stability. Either way though, you are fighting the balance of stability over drag.
Old 11-06-2013, 02:09 PM   #16
turbosvtfocus04
Fan#: 100806
Points 233, Level 4
Lowers center of gravity.
You are acting as if there is so much drag that you will up lift or lose control after 100mph. Quit over thinking it.
I've gone 150mph in my svt. Stock suspension(obviously a little stiffer and lower than regular non svt suspension) guess what, no shakes, no losing control, nothing.
If your wheel is shaking after a certain speed, now you have a wheel balance issue or alignment issue.
Old 11-06-2013, 02:21 PM   #17
ViperThreat
Dat boxer rumble
Fan#: 66026
Forum Activity 13%
I'm not over-thinking it. I spent 4 years in school for aerospace engineering. Aerodynamics are kind of my thing.
Ive been up to 140 in my SVT as well. I can assure you that it is nowhere near as stable as 140 in a BMW or Corvette.
Old 11-06-2013, 02:28 PM   #18
turbosvtfocus04
Fan#: 100806
Points 233, Level 4
Cool story bro.
Of course comparing a completely different car that is made to go 200mph will
Handle better at high speeds. Maybe you can compare a focus to a formula 1. Lol
And yes my car was very stable. It was more stable than my srt4 was.
Old 11-06-2013, 02:51 PM   #19
teamDFL
teamDFL's Avatar
Fan#: 92060
What I Drive: 2001 ZX3, 2012 SE Sport Hatchback
FF Reputation: 6 teamDFL Good Standing Member
Lowering the car will help top speed. See the first post of this thread and the equation. Notice the words "frontal area". Lowering the car lowers the effective frontal area.
Rich aka Dr. Bilkenstein, the three footed hobbit
Rally Revolution #21
teamDFL is offline
Old 11-06-2013, 02:57 PM   #20
ViperThreat
Dat boxer rumble
Fan#: 66026
Forum Activity 13%
Yes, because making the car lower to the ground somehow changes the shape of the car.
Edit.. nvm. not worth my time lol
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Audi S3, Mazda MX-5 Miata and Acura TLX. You can find all Ford Focus, Focus ST and Focus RS related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
