LED lights in trunk - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
View Poll Results: what do you guys think?
Great! I would consider this mod. 11 84.62%
A waste of time! Not interested in this mod. 2 15.38%
Voters: 13. You may not vote on this poll
Old 11-01-2013, 09:15 PM   #1
dbenney
Fan#: 1195
What I Drive: 2012 Tuxedo Black SEL
Points 968, Level 16
Points: 968, Level: 16 Points: 968, Level: 16 Points: 968, Level: 16
Level Up 68% Completed
FF Reputation: 5 dbenney Good Standing Member
LED lights in trunk
I bought a led strip on ebay for some projects with the poor lighting in this car. The trunk lighting is lacking, as well as the lack of lighting in the glovebox and console. the leds i bought were a 300 led premade strip. they were set up cutable every 3 leds, 3 leds in series and connected to each subsequent set of 3 in parallel with a 150 OHM resistor at the start of each series.
i cut at the 10th series set(30 leds), put them in clear vinyl tubing and sealed the ends with hot glue. i tapped the + and - leads for the strip into the existing trunk light harness so they would come on when the trunk opens and go off when it closes. What a difference in lighting. if you guys need a detailed write up let me know...i plan on doing videos when I add switched lighting to the glovebox/console in case anyone else is interested in doing the same.
if you do this make sure you make your calculations to make sure you dont overdraw on current... the 30 leds with my configuration and resistors used only draw 795 mA(.795A) I am an electrical apprentice so if you need help with calculations I can help you out or point you in the right direction.
dbenney is offline
Old 11-01-2013, 09:48 PM   #2
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,910, Level 76
Points: 13,910, Level: 76 Points: 13,910, Level: 76 Points: 13,910, Level: 76
Level Up 65% Completed
Forum Activity 8%
FF Reputation: 45 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (18)
Welcome to the club
SkyPilot is online now
Old 11-01-2013, 10:22 PM   #3
SilverPony2001
SilverPony2001's Avatar
Fan#: 27073
What I Drive: 2013 SGM Sedan SE
Points 6,760, Level 54
Points: 6,760, Level: 54 Points: 6,760, Level: 54 Points: 6,760, Level: 54
Level Up 5% Completed
Forum Activity 3%
FF Reputation: 9 SilverPony2001 Good Standing Member
SilverPony2001 is online now
Old 11-01-2013, 10:24 PM   #4
SilverPony2001
Fan#: 27073
Forum Activity 3%
Interested in seeing this.
Old 11-01-2013, 10:41 PM   #5
dbenney
Fan#: 1195
Ok...as soon as I figure out what type of switch I want to use and where I'm gonna mount it I'll get this done and post a link to some videos.
dbenney is offline
Old 11-02-2013, 06:53 AM   #6
bshin352
bshin352's Avatar
Fan#: 114147
What I Drive: 2013 Tux Black Ti Sedan, DCT
FF Reputation: 1 bshin352 Good Standing Member
I am watching this thread...
#teamdct
bshin352 is offline
Old 11-02-2013, 11:07 AM   #7
CunFFS13
CunFFS13's Avatar
Fan#: 117411
What I Drive: 2013 Sterling Gray Ford Focus S MT
Points 2,400, Level 29
Points: 2,400, Level: 29 Points: 2,400, Level: 29 Points: 2,400, Level: 29
Level Up 67% Completed
FF Reputation: 6 CunFFS13 Good Standing Member
Subscribing
CunFFS13 is offline
Old 11-02-2013, 11:38 AM   #8
bama_focus
bama_focus's Avatar
Fan#: 117648
What I Drive: 2012 focus sedan sel
Points 264, Level 5
Points: 264, Level: 5 Points: 264, Level: 5 Points: 264, Level: 5
Level Up 28% Completed
FF Reputation: 2 bama_focus Good Standing Member
Yeah pretty neat id consider that
2012 Focus SEL sedan tuxedo black
2005 GMC Envoy XUV
bama_focus is online now
Old 11-06-2013, 08:27 PM   #9
2012SEVT
Fan#: 103856
What I Drive: 2012 Metallic Grey Focus SE
FF Reputation: 1 2012SEVT Good Standing Member
Trunk lights were definitely not bright enough from factory.
The 2 different way's I've done it. Wife & I both have a sedan so I get use one as a test mule (mine) and her's gets the final result.
Option 1:
194 bulb from ebay that is an LED with like 10-15 smd's to it and thats pretty bright. Fits on the oem socket and cover.
example:http://www.ebay.com/itm/6-x-T10-20-S...24dd0d&vxp=mtr
Option 2:
Very simular to whats been shown but I nabbed a 12" LED strip off ebay (china) for $4-5 and unplugged the 194 bulb and re-wired the strip to the oem wires and since it's 3M on the other side it just sticks to the underside of the trunk in a very low profile. No ohm resistors due to the thought that LED's were drawing less juice then a normal bulb..... I'm not an electrician so I may be wrong in doing it this way but it works so far.
example:http://www.ebay.com/itm/HID-Xenon-30...24706d&vxp=mtr
2012SEVT is offline
Old 11-08-2013, 08:30 PM   #10
dpando1
Fan#: 92144
What I Drive: 2012, Grey, Focus SE Sport Package
Points 225, Level 4
Points: 225, Level: 4 Points: 225, Level: 4 Points: 225, Level: 4
Level Up 50% Completed
FF Reputation: 2 dpando1 Good Standing Member
I am definitely interested as well. I need all the help I can get
dpando1 is offline
