just a quick note: - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-30-2013, 07:11 AM   #1
badazz2010focus
Fan#: 78166
What I Drive: 2010 ingot silver 2 dr 5 speed
Points 18,945, Level 87
Points: 18,945, Level: 87 Points: 18,945, Level: 87 Points: 18,945, Level: 87
Level Up 19% Completed
Forum Activity 7%
FF Reputation: 7 badazz2010focus Good Standing Member
just a quick note:
To those of us who are considering LED'S in the rear bumper and have a fairly power full system dont do it. Reason being is over time if the subs are facing back they'll beat the hell out of the connection and you'll wind up having to either hit the bumper to get them to turn on and not even that works sometimes or get new ones. I've learned the hard way and I dont think I have moisture in there either at least not that I can see.
badazz2010focus is offline
Old 10-30-2013, 11:53 AM   #2
SlickWilly
SlickWilly's Avatar
Fan#: 116476
What I Drive: 2009 Ford Focus SES Sangria Red
Points 4,994, Level 45
Points: 4,994, Level: 45 Points: 4,994, Level: 45 Points: 4,994, Level: 45
Level Up 22% Completed
Forum Activity 13%
FF Reputation: 6 SlickWilly Good Standing Member
It wont matter what way your subs are facing. The best you can do is lay a 1" thick (I mean thick in density) under the sub box, face the subs to the front, and seal off the trunk from the back of the box. Meaning there is no open area above the box. If you do that your bass will be louder, a lot cleaner, your car won't rattle, your plate, lights and everything will stay together better.
Or just don't cheaply mod your car
K&N Intake - Magnaflow Exhaust - F2 Header - CFM Race Pulleys - VF Engineering Mounts - N2O
SlickWilly is online now
Old 10-30-2013, 04:24 PM   #3
popwarhomie
popwarhomie's Avatar
Fan#: 94974
What I Drive: 10 Focus coupe / 94 Lightning
Points 1,265, Level 19
Points: 1,265, Level: 19 Points: 1,265, Level: 19 Points: 1,265, Level: 19
Level Up 65% Completed
Forum Activity 4%
FF Reputation: 1 popwarhomie Good Standing Member
I have no problems with mine. 42draftdesigns leds.
2010 Focus SE coupe 5 speed
Pioneer 80prs/(2)AQ2200D/BK800.4/6 SQ pro mids/4 SQ supertweets/AlphaDamp/Projector retrofit/LED tails/ Walled with 2 SQ HDC3 18s.
94 Lightning
A lot of mods.
popwarhomie is online now
Old 10-30-2013, 11:07 PM   #4
soundFocus
soundFocus's Avatar
Fan#: 97713
What I Drive: 2011 Sangria Red SES
Points 451, Level 9
Points: 451, Level: 9 Points: 451, Level: 9 Points: 451, Level: 9
Level Up 2% Completed
FF Reputation: 1 soundFocus Good Standing Member
I think it's just a general issue with how they fit. The factory bulb that went out and lead to the LED's was also the right. Further playing with it shows it's a bad connection. It takes some fussing but for some reason it seems like that mount doesn't make very good electrical contact after a certain time frame because it just uses pressure to fit in (both the bulb and the bulb mount in the reflector). Just how that design happens to work; I have the same issue with my Corolla's dome light from time to time which uses the same bulb type (non LED though).
soundFocus is offline
Old 10-31-2013, 07:32 AM   #5
badazz2010focus
Fan#: 78166
Forum Activity 7%
Yeah I know the two ends make intermitent contact even when I try to spread them apart on the lamp.
