Shorted out LOC? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-29-2013, 08:13 PM   #1
Speshulldroo
Speshulldroo's Avatar
Fan#: 85488
What I Drive: 2008 Red MTX Sedan
Points 200, Level 3
Points: 200, Level: 3 Points: 200, Level: 3 Points: 200, Level: 3
Level Up 50% Completed
FF Reputation: 1 Speshulldroo Good Standing Member
Shorted out LOC?
Hey guys. I'm wondering if it's possible to short out an LOC and/or is it common to get a bum one out of the box?
I'm currently attempting to upgrade amps. While I had my old amp wired into the high freq input plug through the factory hear unit, the new amp doesn't have such an input. I then bought a line output converter to make it work. However, upon wiring it in, both amps will power up but send no signal to any sub I try (3 so far). If I wire the original one back in with the high freq plug, it works perfectly. Any ideas?
Speshulldroo is offline
Old 10-30-2013, 09:49 AM   #2
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
What I Drive: 2013 F150 4x4 5.0, 2014 HD 883 Iron
Points 4,517, Level 42
Points: 4,517, Level: 42 Points: 4,517, Level: 42 Points: 4,517, Level: 42
Level Up 84% Completed
FF Reputation: 9 Kipp Good Standing Member
any electronic component can be shorted and yes it's def possible to have a bad one out of the box. for the loc you'll need to connect to the speaker outputs from the headunit if you don't already. it's also possible that the new amp could be bad. you can take a multimeter and test the ac output from the rca's coming out of the loc to see if you're getting signal from there or not.
2013 F150 4x4 SCrew XLT 5.0L
Midwest Crew #22
Official FocusFest Event Planner
Kipp is offline
Old 10-30-2013, 10:22 AM   #3
Speshulldroo
Fan#: 85488
Points 200, Level 3
I had the high freq plug wired into the speaker wired off the factory head unit for a while now. I'm thinking that because the old amp still received/sent a signal off the high freq plug after I took the LOC back out, it's gotta be the converter. Wiring a new one in over lunch break today, so I guess we'll find out...
Old 10-30-2013, 09:59 PM   #4
Speshulldroo
Fan#: 85488
Points 200, Level 3
Turns out the solution was pretty weird. I originally had the high freq plug wired into the speaker wires just before the b-pillar. After a couple hours with a test light and wiring diagram, I wound up splicing into the rear speaker wires at the speaker plug inside the door panel and it worked. Same two wires, just after the b pillar plug. I'm not sure what the difference is, but it works now.
