Rough idle nightmare - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-30-2013, 02:17 AM   #11
Okusfocous
Fan#: 120297
What I Drive: 2004 yellow zx5 2.3 pzev
FF Reputation: 1 Okusfocous Good Standing Member
Originally Posted by waraya View Post
whats the code?
po411
Okusfocous is offline
Old 10-30-2013, 02:20 AM   #12
amc49
Fan#: 96610
Points 3,357, Level 36
Points: 3,357, Level: 36 Points: 3,357, Level: 36 Points: 3,357, Level: 36
Level Up 5% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
These commonly crack at the PCV hose under intake to leak. If problem mainly at idle/off idle.
Cleaning MAF by spraying with some sort of solvent and then letting it completely dry before powering it up usually works. Carb cleaner or dedicated MAF cleaner. Either works.
amc49 is offline
Old 10-30-2013, 11:02 AM   #13
Highball116
Fan#: 112564
What I Drive: 2005 Red ZX4
Points 650, Level 12
Points: 650, Level: 12 Points: 650, Level: 12 Points: 650, Level: 12
Level Up 50% Completed
Forum Activity 5%
FF Reputation: 3 Highball116 Good Standing Member
I second the PCV hose. On the Duratec it's a very difficult hose to see, but if you take a flashlight and look through the intake manifold at all angles, you'll see it smashed in there. You can also catch glimpses of it from underneath, but getting your hand in there to feel it is a task fit for Houdini. Ford apparently has a $600 deal on PCV valve and hose replacement, which they do with special tools while the manifold is still in place. Doing it yourself requires removal of the manifold, which is a process.
Toby
Highball116 is offline
Old 10-30-2013, 01:18 PM   #14
cheap sleeper
cheap sleeper's Avatar
Fan#: 59848
What I Drive: 2001 black zx3
Points 917, Level 16
Points: 917, Level: 16 Points: 917, Level: 16 Points: 917, Level: 16
Level Up 17% Completed
FF Reputation: 5 cheap sleeper Good Standing Member
Toby
Wow that is crazy that the pcv is like that on that motor :/
Well at least you have a code now to narrow it down a bit.
cheap sleeper is online now
Old 11-03-2013, 02:31 AM   #15
Okusfocous
Fan#: 120297
I apologize for taking so long to reply to all of your posts... Thank you all for your suggestions. They are much appreciated and very helpful.
Old 11-03-2013, 09:16 PM   #16
jebiruph
Fan#: 116084
What I Drive: 2004 ZX3
Points 38, Level 1
Points: 38, Level: 1 Points: 38, Level: 1 Points: 38, Level: 1
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
FF Reputation: 1 jebiruph Good Standing Member
Don't know what work you've done so far, but these are the same symptoms I had on my 2004 2.3 pzev with a bad coil. Mine was running ok until I replaced the old platinum plugs with the copper 103s. With the 103s installed, I had rough idle and hesitation. After alot of swapping coils and plugs around, I found that one of the coils didn't work with the 103 plugs.
jebiruph is offline
