Replaced starter motor, Nothing happens - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-29-2013, 05:43 PM   #1
shpaco86
Fan#: 118753
What I Drive: 2002 svt focus
FF Reputation: 1 shpaco86 Good Standing Member
Hello, I just replaced the starter motor on my 02 focus SVT. the old starter would just spin without the armature engaging, and wouldn't stop until the battery was disconnected. I've been push starting it (the most annoying thing ever). I replaced the starter with a used on i got off ebay. I checked it at autozone, and it was a good known starter prior to install. I have no engagement, no clicking, i don't even think that the relay is operative. It's frustrating as all get out. I've replaced numerous starters and a variety of cars and i've never had this problem. Also the battery connection is tight, and from a visual inspection of the cable, appears to be corrosion free. I can still pop the clutch and she starts up. Any ideas or suggestions?! Please help!
shpaco86 is offline
Old 10-29-2013, 11:54 PM   #2
waraya
Fan#: 114416
What I Drive: 2003 Ford Focus SVT (black)
Points 189, Level 3
Points: 189, Level: 3 Points: 189, Level: 3 Points: 189, Level: 3
Level Up 78% Completed
FF Reputation: 1 waraya Good Standing Member
you sure the little cable is seated in the connector correctly???
waraya is offline
Old 10-30-2013, 01:44 PM   #3
cheap sleeper
cheap sleeper's Avatar
Fan#: 59848
What I Drive: 2001 black zx3
Points 917, Level 16
Points: 917, Level: 16 Points: 917, Level: 16 Points: 917, Level: 16
Level Up 17% Completed
FF Reputation: 5 cheap sleeper Good Standing Member
if your'e getting absolutely nothing, I would suspect a connection isn't re-hooked. Ground side maybe? Dumb I know, but I've had stoner moments like that. Also, is your power wire from the batt to it burned/ melted anywhere along the way? That was a common issue.
cheap sleeper is online now
