anyone have a fogging issue? - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-29-2013, 06:15 PM   #21
Spitfire22
Spitfire22's Avatar
Fan#: 120066
What I Drive: 2012 Focus SEL SGM HB
FF Reputation: 1 Spitfire22 Good Standing Member
not in my focus, but in my freestar, that thing fogs over like crazy, it's like driving in a sauna sometimes
Current Rides:
2012 Taurus SE
Spitfire22 is offline
Old 10-29-2013, 06:22 PM   #22
2kwik4u
Fan#: 102523
What I Drive: '12-Sonic Blue-5dr/5spd/203A/Roof
Points 1,642, Level 23
Points: 1,642, Level: 23 Points: 1,642, Level: 23 Points: 1,642, Level: 23
Level Up 43% Completed
FF Reputation: 1 2kwik4u Good Standing Member
Mine fogs VERY easily.....until I clean the windows. Then it's acceptable for a few weeks. Clean the windows meticulously and see if that helps. Use a good non-ammonia based cleaner, and some paper towels to insure there is zero grease/oils left on the window. If I do that, it stays pretty clear regardless of weather. If I get a few nice days and drive with the windows down for a bit, I get enough dirt/dust on there to induce the fogging again.
2kwik4u is offline
Old 11-01-2013, 02:47 PM   #23
ctbale
Fan#: 118346
What I Drive: 2013 Gray SE 5 Door 5 Speed Manual
Points 118, Level 2
Points: 118, Level: 2 Points: 118, Level: 2 Points: 118, Level: 2
Level Up 36% Completed
Forum Activity 4%
FF Reputation: 1 ctbale Good Standing Member
My 2013 se 5sp fogs more than any car I have ever owned. I had a 96 taurus that has a recirc door stuck in recirc, but I think this one operates. ac good. its really bad. I will watch this thread.
ctbale is offline
Old 11-01-2013, 03:40 PM   #24
Tytanium
Fan#: 109829
What I Drive: 2012 Ford Focus Titanium
Points 108, Level 2
Points: 108, Level: 2 Points: 108, Level: 2 Points: 108, Level: 2
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
FF Reputation: 1 Tytanium Good Standing Member
Originally Posted by PratoN View Post
Does your AC work / make the car cold?
This. The A/C has to be on in order for it to dehumidify the air. If it's discharged or not working, then it's not going to defrost your windshield.
Also, fogging can get bad if you use any of that dash plastic protector spray/wipes. Evaporates and leaves an oily residue on the windshield.
Tytanium is offline
Old 11-02-2013, 01:14 AM   #25
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,726, Level 78
Points: 14,726, Level: 78 Points: 14,726, Level: 78 Points: 14,726, Level: 78
Level Up 69% Completed
Forum Activity 12%
FF Reputation: 16 Elizabeth Great Standing Member
Here in Wisconsin cars can get the dreaded fogging all the time in Winter.
One help is to NOT close the doors of the car right away after driving in the cold.
The interior is warm and hold a ton of moisture from human bodies, breath.. Then you stop and lock up the car, All that has to drop out of the air as it get colder in car. so it collects in the carpet , seats etc.Gradually it becomes Hell.
Try leaving the doors open until all the interior air is blown out and cold air has entered. Then lock the car up. 30 seconds???
If you can, leave it windows fully/partially open all night (on a clear cold night) at least one or two nights. the dry Winter air will dry up the interior of your car.
If you have a moonroof, leave it cracked tilted up if in a safe place, and no rain/snow coming (I do this all the time.)
Some of the fog is from 'bad' habits. some is really stuff is not working right.
But maybe these ideas can help a little.
Elizabeth is online now
Old 11-02-2013, 09:28 AM   #26
ctbale
Fan#: 118346
Points 118, Level 2
Forum Activity 4%
good tips. This wont apply (I hope to a 2012-2014 models) but if your heater core is leaking that will do it too. Thats what I thought it was with my 96' Taurus. But it ended up being my recirc door stuck in recirc.
This car is strange because when I jump in (usually in the AM before sunrise and the car is outside) the windows are clear, but when I set the fan to 2 and set the discharge to the window/floor setting and have the recirc not selected, the front windows fog up within 3 seconds, then takes 3 or 4 mins for the heat to cook it off. cant drive it, I have to sit there, very annoying. This is 40 to 45 outside temp with 90% humidity. But like I said in a past post, never had a car or truck do this. I believe the AC compresser is running anytime the defrost is set like in most cars even though the AC light is off. In my Honda Element you could program the controls to only enable the AC pump when the AC button is pushed. That was nice, but for most people the car companies want that pump running for defrost to improve performance. On my for ranger I unplug the AC compressor under the hood. I have read that many cars the AC pump is inhibited below 50F. But the ranger I can hear/feel it cycle to I take it out in the winter for drivability performance reasons.
ctbale is offline
Old 11-02-2013, 10:00 AM   #27
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
Points 3,070, Level 34
Points: 3,070, Level: 34 Points: 3,070, Level: 34 Points: 3,070, Level: 34
Level Up 14% Completed
Forum Activity 2%
FF Reputation: 12 dan50 Great Standing Member
Maybe your issue has been resolved, but are you sure your HVAC system isn't set to "recirculate"? This would keep dryer, outside air from entering the car and would contribute to fogging.
dan50 is offline
Old 11-08-2013, 06:38 PM   #28
FordService
Official Ford Rep
FordService's Avatar
Fan#: 79824
What I Drive: Ford Focus
Points 3,469, Level 36
Points: 3,469, Level: 36 Points: 3,469, Level: 36 Points: 3,469, Level: 36
Level Up 80% Completed
Forum Activity 18%
Hi everyone,
I'd like to remind you all that I'm here to help if needed. If you decide to visit your local dealer for the fogging issue, please let me know and I'll look into next steps.
Todd
FORD SERVICE
p: 800.392.FORD
FordService is offline
Old 11-09-2013, 09:13 AM   #29
PratoN
PratoN's Avatar
Fan#: 88058
Points 3,077, Level 34
Points: 3,077, Level: 34 Points: 3,077, Level: 34 Points: 3,077, Level: 34
Level Up 18% Completed
Forum Activity 3%
FF Reputation: 15 PratoN Great Standing Member
I wouldn't rule it out, could explain leaking coolant if the issue is not the radiator. Also, a lot of new Cruzes seem to have this issue.
PratoN is online now
