Help required - wet fuse box - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-27-2013, 03:43 PM   #1
ajfaccini
Fan#: 120224
What I Drive: 2006 grey 1.6 TDCI
Points 44, Level 1
Points: 44, Level: 1 Points: 44, Level: 1 Points: 44, Level: 1
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 ajfaccini Good Standing Member
Hi guys,
After a little bit of help, had a problem with my mk 2 focus the other day, Seems that after going through a large puddle flooding the road I've ended up with some water in the fuse box. This wasn't noticed at first and got home, shut the car up and went to bed...
The problems started the next morning, noticed the battery was flat so charged it, now that issue is sorted the battery was put back in place and the car starts etc, moves and all the electronics work as they should when running.
however when the car is shut down Im having problems with the windscreen wipers juddering and moving by their own accord, the internal light of the car stays on or comes on randomly, the bleep that you get when you aren't wearing a seatbelt randomly sounds...
Just to save the battery for tonight I've unplugged the battery to stop all the problems and to stop it draining the battery but does anyone have any idea if,
A) There is a weakness anywhere that might let water in to the fuse box,
B) There is an easy way to dry the fuse box other than just leaving it to dry on its own,
C) If there is a fix to stop this happening again,
D) Have any idea if any long lasting damage can/has been caused.
Many thanks in advance for any help you can offer and just to add this is the fuse box on the passenger side of the car, not the one next to the battery compartment under the bonnet.
ajfaccini is offline
Old 10-27-2013, 04:43 PM   #2
Bogey
Bogey's Avatar
Fan#: 104241
What I Drive: 2012, Ingot Silver SE
Points 1,696, Level 23
Points: 1,696, Level: 23 Points: 1,696, Level: 23 Points: 1,696, Level: 23
Level Up 96% Completed
FF Reputation: 1 Bogey Good Standing Member
Rice is very good at absorbing, possibly put some rice in a coffee filter and leave it in the fuse box?
Bogey is offline
Old 10-28-2013, 03:09 PM   #3
Miller88
Fan#: 73790
What I Drive: 2011 Focus SE 5 Speed
Points 1,764, Level 24
Points: 1,764, Level: 24 Points: 1,764, Level: 24 Points: 1,764, Level: 24
Level Up 64% Completed
Forum Activity 3%
FF Reputation: 5 Miller88 Good Standing Member
How deep did you go through?
It may be too late, but you are going to need to disconnect ALL harnesses from the fuse box, along with all fuses and relays.
You will need to spray it all out very quickly with air, and possibly even 99% rubbing alcohol to help extract the moisture. Rice, silica gel (from shoe store) will also help.
Unfortunately, it's likely you will always have electrical gremlins after this as the corrosion has already begun to set in.
2011 Focus SE 5 Speed 36k - Blue Flame Metallic - Added Rear Swaybar
2000 Jeep Cherokee Sport 115k - Lifted with mud tires.
Miller88 is online now
Old 10-28-2013, 03:35 PM   #4
ajfaccini
Fan#: 120224
Points 44, Level 1
Hi guys thanks for the replies! It seems to be fine now (Touch wood) Just have to be careful now with puddles.
I couldn't actually see how wet it got but did disconnect the main wiring harnesses from the fuse box and allowed it to dry as much as possible. Also I got in to it with a few cans of compressed air and a hair dryer etc!
It does seem as though there is a weakness somewhere, its just a case of trying to find how and where water had got in.
Thanks for your help!
Old 10-29-2013, 02:46 AM   #5
SKimpy007
Fan#: 111599
What I Drive: 2009 Silver Focus SES 4 Door
FF Reputation: 1 SKimpy007 Good Standing Member
Which fuse box? Maybe a dehumidifier?
SKimpy007 is offline
Old 10-29-2013, 01:17 PM   #6
Miller88
Fan#: 73790
Forum Activity 3%
It still may come back to haunt you. I'd continue to pull everything apart once or twice more to make sure.
Definitely see if you can get some silica gel for it.
