Rattiling sound on start up - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-27-2013, 10:34 AM   #1
Rahaindy
Fan#: 115553
What I Drive: 2002 Black SVT
Points 49, Level 1
Points: 49, Level: 1 Points: 49, Level: 1 Points: 49, Level: 1
Level Up 98% Completed
FF Reputation: 1 Rahaindy Good Standing Member
My 2002 SVT with 25,000 miles (bought mid summer 2013) makes a loud rattle when started when cold. Seems to be coming from the left (Driver's) side, saw some other threads that said it seems to be normal? But is there any issues to be concerned about?
Any help would be great, still not sure about why the car had so few miles when I bought it but it seems to be 1 issue after another. Had to replace clutch after I had it for 2 months ~ 1500 miles.
Rahaindy is offline
Old 10-27-2013, 10:47 AM   #2
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,703, Level 94
Points: 23,703, Level: 94 Points: 23,703, Level: 94 Points: 23,703, Level: 94
Level Up 36% Completed
Forum Activity 17%
Activity: 17% Activity: 17% Activity: 17%
does it go away when warmed up or almost instantly?
mikebontoft is online now
Old 10-27-2013, 11:10 AM   #3
maxwell_bud
maxwell_bud's Avatar
Fan#: 117818
What I Drive: 2003 Black ZX3
Points 423, Level 8
Points: 423, Level: 8 Points: 423, Level: 8 Points: 423, Level: 8
Level Up 46% Completed
FF Reputation: 1 maxwell_bud Good Standing Member
based on the low mileage it most likely sat without being driven for a very long time so that explains having multiple issues after one another. As for the rattle, does it only happen when you start it and then that's it? Or does it seem to happen only at low RPM's?
maxwell_bud is offline
Old 10-27-2013, 11:21 AM   #4
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
It might be "normal" if it's an exhaust shield. In that case, you might be able to replicate the problem at will, and then find the rattle.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 10-27-2013, 07:36 PM   #5
Mmalloian
Fan#: 89527
What I Drive: 2003 silver svt
FF Reputation: 1 Mmalloian Good Standing Member
Funny, I just dealt with this issue after replacing the clutch. A tin rattle drove me crazy but I found out one nut that secures the rear heat shield behind the engine was loose. I tightened it and the noise went away. Also, I previously found the front header shield loose at the bottom. There are 2 small bold that we're no longer securing the shield because the holes eroded away. I used bigger flat washers and it works fine. Depending on the type of noise, it may also be caused by a bad trans mount. Check the rubber on the top and bottom trans mounts and if it's bad, replace both. Good luck.
Mmalloian is offline
