Please help... :*( - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-26-2013, 05:32 PM   #1
t.foley42@gmail.com
Fan#: 120100
What I Drive: 2008 Red Ford Focus SDS
FF Reputation: 1 t.foley42@gmail.com Good Standing Member
Please help... :*(
I have an 08 ford focus ses. I was opening my door and something internal broke. Now the drivers side handle is limp and wont open. I believe I know how to fix it, if I can just crack the damn thing open!!!
I can NOT get the interior door to pop off. I've looked on youtube and on here. EVERYONE talks about a little tab behind the interior handle that you need to pry off and take off the last screw (there was 1 in the side of the door, 2 on the bottom, 3 in the arm rest, all those are out). But there is NO TAB. Not anywhere. I've pried off the little triangle where the power window adjustment toggle was...There's nothing else I can take off!
Please please please....someone help me.
t.foley42@gmail.com is offline
Old 10-26-2013, 05:40 PM   #2
t.foley42@gmail.com
Fan#: 120100
Old 10-26-2013, 07:47 PM   #3
02 wagon
Fan#: 99149
What I Drive: 2002 red wagon
Points 40, Level 1
Points: 40, Level: 1 Points: 40, Level: 1 Points: 40, Level: 1
Level Up 80% Completed
FF Reputation: 1 02 wagon Good Standing Member
I cannot get the pictures to load
Door Trim Panel — Front Printable View
NOTE: RH side shown, LH side similar.
NOTE: Four door shown, 2 door similar.
Item Part Number Description
1 17K709 Front door sail panel
2 22620 RH/ 22621 LH Front door inside handle finish panel
3 N805651 Front door inside handle bolt
4 22600 RH/ 22601 LH Front door inside handle
5 23712 RH/ 23713 LH Front window control switch panel
6 22670 RH/ 22671 LH Front door pull handle screw cover
7 W505584 Front door pull handle screw (2 required)
8 N805651 Front door trim panel middle screw (power windows only)
9 W708412 Front door trim panel screws (2 required — 4 door) (3 required — 2 door)
10 — Front door trim panel side screw cover
11 W708412 Front door trim panel side screw
12 23942 RH/ 23943 LH Front door trim panel
All vehicles
Remove the front door sail panel.
If equipped, disconnect the electrical connector.
NOTE: LH front door trim panel shown, RH front door trim panel similar.
Remove the front door inside handle finish panel.
Pull the front door inside handle outward.
Using a suitable tool, pull the front door inside handle finish panel outward at the location shown.
Remove the front door inside handle bolt.
Manual windows
NOTE: Use a suitable tool to remove the clip.
Remove the window regulator handle.
Power windows
Remove the front window control switch panel.
Lift upward at the rear of the front window control switch panel.
Disconnect the electrical connector.
Remove the middle door trim panel screw.
All vehicles
NOTICE: Pull the front door pull handle screw cover at the rear of the front door pull handle screw cover. Otherwise, damage to the front door pull handle screw cover may occur.
Remove the front door pull handle screw cover.
Pull the rear of the front door pull handle screw cover away from the door.
Remove the 2 front door pull handle screws.
To install, tighten to 3 Nm (27 lb-in).
2 door
Remove the 3 front door trim panel screws.
4 door
Remove the 2 front door trim panel screws.
All vehicles
Lift the front door trim panel side screw cover and remove the front door trim panel side screw.
NOTE: To help with the removal of the front door trim panel, the location of the front door trim panel retaining clips on the backside of the front door trim panel are shown.
Remove the front door trim panel.
Pull the front door trim panel away from the door to release the front door trim panel retaining clips.
Lift the front door trim panel upward over the door lock knob.
If equipped, remove the wire harness from the front door trim panel.
If equipped, disconnect the door lock electrical connector.
Remove the front door handle cable from the front door trim panel.
Pull the front door handle cable from the front door inside handle cable retainer.
Lift the front door handle cable upward from the front door inside handle.
To install, reverse the removal procedure.
To install, make sure to align the trim panel retaining clips to the retaining clip holes in the body.
02 wagon is offline
Old 10-26-2013, 09:23 PM   #4
t.foley42@gmail.com
Fan#: 120100
oh THANK YOU!!!!!! Is there any way you can send me the URL so i can look at the pictures that wouldn't load? Thank you thank you!
Old 10-27-2013, 02:52 AM   #5
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,142, Level 74
Points: 13,142, Level: 74 Points: 13,142, Level: 74 Points: 13,142, Level: 74
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
Forum Activity 30%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (46)
Moved to "MK2 Focus".
zetecDon is offline
Old 10-27-2013, 04:14 AM   #6
ak609
Fan#: 116022
What I Drive: 2008 black focus coupe
FF Reputation: 1 ak609 Good Standing Member
Let me know I took my door off and now I need a entirely new mechanism.
Sent from my SAMSUNG-SGH-I537 using FF Mobile
ak609 is offline
Old 10-31-2013, 10:47 PM   #7
ak609
Fan#: 116022
131$ for the part gonna install this weekend will let you know how it goes
ak609 is offline
Old 11-01-2013, 05:54 PM   #8
badazz2010focus
Fan#: 78166
What I Drive: 2010 ingot silver 2 dr 5 speed
Points 19,182, Level 87
Points: 19,182, Level: 87 Points: 19,182, Level: 87 Points: 19,182, Level: 87
Level Up 67% Completed
Forum Activity 7%
FF Reputation: 7 badazz2010focus Good Standing Member
what part was it?
badazz2010focus is offline
Old 11-01-2013, 09:32 PM   #9
ak609
Fan#: 116022
Not at home right now will let you know when I get there though.
ak609 is offline
Old 11-02-2013, 01:14 AM   #10
ak609
Fan#: 116022
ak609 is offline
