Easy way to replace Antenna Rubber on ZXW - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-25-2013, 12:17 PM   #1
Saiyajinss
Fan#: 118568
What I Drive: 2005 Liquid Metallic Grey ZXW
FF Reputation: 1 Saiyajinss Good Standing Member
When I bought my ZXW the antenna was really noisy in the wind at freeway speeds. When I checked it out the rubber around the Spring at the base of the antenna had literally started to flake off and it was whipping around like crazy.
I decided to try to replace the rubber instead of buying a whole new antenna. I had some 3/4 inch diameter heat shrink from Home Depot left over from my Subwoofer power wire installation so I cleaned off all the old rubber and used my heat gun to add the heat shrink. And done. You can use a Black Paint Pen to black out the letters if you buy heat shrink that has them.
I also added a little bit to the top to replace the end bit that fell off too. I put on extra and just cut it off where I wanted it to get the right size. It's now been a month and it's holding up well even in the Florida sun and heat.
Much Cheaper than a new ford Antenna and After Market ones rust easily here by the beach. Here are some Pics
Saiyajinss is offline
Old 10-27-2013, 11:55 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,826, Level 73
Points: 12,826, Level: 73 Points: 12,826, Level: 73 Points: 12,826, Level: 73
Level Up 94% Completed
Forum Activity 99%
Good "McGuyver" fix - Kudos!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
