No Power to Radio Wiring Harness - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-24-2013, 08:42 AM   #1
builtbybama
Fan#: 120118
What I Drive: 2000 Focus LX
FF Reputation: 1 builtbybama Good Standing Member
Hello All, I am new here and am looking for help on installing my Kenwood HU into my focus. I have installed HU before, so I am not new. In fact, I just installed this unit in my truck before deciding to put it in the Focus.
Background- 2000 Focus LX Base. Power nothing. Manual Tranny, Manual Windows and Locks.
Using a Schoche Wiring Harness I pulled off the existing aftermarket Sony HU that was in the car. Was working.
Problem- no power to the wiring harness.
I checked the fuses inside the car and even replaced them with known good fuses even though they were not blown. I used a Multimeter at the fuse panel and verified I am getting voltage (12.68V).
I checked voltage on the car side wiring harness on all pinouts and get no voltage.
My question is, what could cause this? Not aware of any security features that would shut off the power there. And, again, it was working with the exisiting HU. All I did was disconnect it. I did nothing else to or in the car.
Looking for any recommendations of what else to check or how to proceed before I decide to just hardwire.
Thanks, Matt
builtbybama is offline
Old 10-24-2013, 09:13 AM   #2
FocusedSlayer
has a screw loose
FocusedSlayer's Avatar
Fan#: 59042
What I Drive: 2007 CD Silver Sedan SE w/Sap
Points 7,824, Level 59
Points: 7,824, Level: 59 Points: 7,824, Level: 59 Points: 7,824, Level: 59
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
Forum Activity 19%
FF Reputation: 34 FocusedSlayer Great Standing Member
Buy-Sell-Trade Rating: (4)
Hello Matt,
Welcome to Focus Fanatics , If everything is checking out good in the car and your using the same wiring harness that you had in your other vehicle more than likely its the harness. Could be that 1 of the connections has slipped out of place and not making the proper contact .
Team Duratec #01,Sedan Revolution#4, Elder FocusedSlayer, Gump Crew 21
February 2012 Sedan of The Month
FocusedSlayer is online now
Old 10-24-2013, 11:18 AM   #3
builtbybama
Fan#: 120118
Thanks, FocusedSlayer.
I guess I will just hard wire it smartly. Not what I was hoping to do. But, worse things could happen. At least everything is easily accessible to do so since the opening is rather large and I can find a ground.
Matt
Old 10-24-2013, 01:51 PM   #4
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,581, Level 53
Points: 6,581, Level: 53 Points: 6,581, Level: 53 Points: 6,581, Level: 53
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 51%
Activity: 51% Activity: 51% Activity: 51%
Buy-Sell-Trade Rating: (23)
Is there continuity through the wire of the Schoche harness?
Hatch Nation #140
Caeci caecos ducentes
freemind is online now
Old 10-24-2013, 03:18 PM   #5
builtbybama
Fan#: 120118
Just went to test it and there is continuity.
Old 10-24-2013, 05:44 PM   #6
freemind
freemind's Avatar
Fan#: 67513
Forum Activity 51%
Between the fuse and the OEM harness?
Hatch Nation #140
Old 10-24-2013, 07:58 PM   #7
builtbybama
Fan#: 120118
Between the fuse panel and the harness, no. I test at the fuse panel and get voltage (~12.5V) But, not on any of the pinouts.
Old 10-25-2013, 11:06 AM   #8
FocusedSlayer
has a screw loose
Fan#: 59042
Forum Activity 19%
Do it the right way and instead of hard wiring it , just go out and snatch up a new harness and if that doesn't work take the harness back and tell them it didn't work and then proceed to hard wire it .
I read all over the net that my new 13 Fiesta had to be hard wired and after doing some searches there was actually a harness that did work and plugged right into the factory harness so I didn't have to do any cutting and splicing.
Old 10-25-2013, 11:08 AM   #9
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
What I Drive: 2013 F150 4x4 5.0, 2014 HD 883 Iron
Points 4,517, Level 42
Points: 4,517, Level: 42 Points: 4,517, Level: 42 Points: 4,517, Level: 42
Level Up 84% Completed
FF Reputation: 9 Kipp Good Standing Member
did you check fuses in the engine bay as well. can't remember for sure, but most cars the 12v fuse for the stereo is under the hood and the acc fuse is inside.
2013 F150 4x4 SCrew XLT 5.0L
Midwest Crew #22
Official FocusFest Event Planner
Kipp is offline
Old 10-25-2013, 11:19 AM   #10
builtbybama
Fan#: 120118
I will check under the hood but figured I would not be getting power to the Passenger compartment fuse block if there was one blown in there. Worth a look though.
