"Sync My Ride's" update is outa sync! - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-28-2013, 12:07 AM   #11
dave mc g
Fan#: 120049
What I Drive: 2013 blue se
FF Reputation: 1 dave mc g Good Standing Member
when I took my car into ford and had the warranty my Sync system and reprogram it they had to physically replace the USB input I'm not sure what happened as I have never removed the USB that I had located in the console to my iPodI have a feeling there will be a recall on the USB parts in the car .possibly they used cheap USB input partswhen I was in having mine worked on they were also to other people with the same problem so I'm not surprised to hear of another unfortunately I hope you can get something figured out I'll let you know if I come across any new information about it as mine has defaulted twice to line in since I had it in the shop I was able to remove my USB cable reconnect it and use voice command to select USB input and was able to use it again
dave mc g is offline
Old 10-28-2013, 12:32 AM   #12
Lite12
Lite12's Avatar
Fan#: 118069
What I Drive: 2013 Race Red Focus SE 5dr
Points 131, Level 2
Points: 131, Level: 2 Points: 131, Level: 2 Points: 131, Level: 2
Level Up 62% Completed
FF Reputation: 1 Lite12 Good Standing Member
Wow, that was a long sentence :)
But yeah, I'm not sure what's up yet. I don't think mine has anything to do with the physical connection because it's always available without having to reconnect it, but just have to set it back to the USB about once a week.
2013 SE 5dr w/sport appearance, race red, 5mt
Amber LED frt markers, LED backups
Lite12 is offline
Old 10-28-2013, 09:11 AM   #13
Stream
Fan#: 114682
What I Drive: 2013 SE sedan Ingot Silver Metallic
Points 84, Level 1
Points: 84, Level: 1 Points: 84, Level: 1 Points: 84, Level: 1
Level Up 68% Completed
FF Reputation: 1 Stream Good Standing Member
Originally Posted by Lite12 View Post
Well so much for that, went back to line-in tonite. Oh well, at least it IS up to date FWIW.
Might try a different flash drive, using a Lexar 32GB nano drive now but got a PNY 16GB "normal" sized drive to test drive just to see if it matters.
I just like the tiny ones because you don't have to worry about breaking anything because of it sticking up in the console. If the full size 16GB works I'll get a 16GB nano, maybe it has to do with the size of it (capacity, not physical).
Thanks for the follow up.
I've tried several brands and capacities of flash drives, with the same unacceptable result--default to line-in on restart. I'm currently using a 32GB SanDisk Cruzer Fit (nano size), which I like because it's sits relatively flush. Very annoying to have to reset to USB input all the time.
When I got my car, I had the line-in default issue using my iPhone via BlueTooth, and called SYNC customer support, who told me this was something they did because people were having issues with it defaulting to BT even when no BT device was available. They told me I should use a USB flash drive and would have no issue. Wrong.
I've spoken to SYNC support several times and requested they file this as a customer complaint, and suggest you (and everybody else having the issue) do the same, to increase the probability of them fixing it.
Stream is offline
Old 02-03-2015, 09:24 PM   #14
Lite12
Lite12's Avatar
Fan#: 118069
Points 131, Level 2
Well over a year in now and best I can do is just remember to turn off the radio before shutting the car off, otherwise it's a crapshoot as to staying on the USB input when I start the car next time.
I'm just in the habit now of shutting off the radio before turning off the car.
Lite12 is offline
