Valves - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-22-2013, 06:46 PM   #1
lostsoul23m
lostsoul23m's Avatar
Fan#: 119006
What I Drive: 2007 Screaming Yellow ZX3
FF Reputation: 1 lostsoul23m Good Standing Member
Valves
When I do upgrade my cams, should I also have the valves changed out? I am at 87k miles, getting ready to get a tune and running an SRI, header, and race exhaust with more mods to come.
lostsoul23m is offline
Old 10-22-2013, 08:27 PM   #2
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,615, Level 31
Points: 2,615, Level: 31 Points: 2,615, Level: 31 Points: 2,615, Level: 31
Level Up 10% Completed
You don't just "change out" valves
If you really want to, then remove the head, take it to a machine shop to have them vacuum test the combustion chambers to check the valve to head seal. If necessary, they will regrind the valves and seats. this is expensive, a good valvejob is labor intensive. Unless you have good reason to think there is an issue, don't bother.
Valve springs on the other hand, perhaps, depending on what the new cam needs for seat pressure and on the nose pressure. But overhead cam motors run weak springs to begin with unless you are going absolutely nuts with the new cams, not needed.
2.3, home fabbed Mustang GT brakes, SVT suspension
67 Chevelle SS-496, owned since 1991
elsolo is offline
Old 10-22-2013, 08:49 PM   #3
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,690, Level 76
Points: 13,690, Level: 76 Points: 13,690, Level: 76 Points: 13,690, Level: 76
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
Why would you need to change out your valve's? Are you going w/ bigger ones or what? I'd install the cams & enjoy. What cams do you have?
felixthecat is offline
Old 10-23-2013, 08:29 AM   #4
amc49
Fan#: 96610
Points 3,357, Level 36
Points: 3,357, Level: 36 Points: 3,357, Level: 36 Points: 3,357, Level: 36
Level Up 5% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
You don't have to mess with valves, but you should know that most all engines do begin to show some exhaust valveseat wear around 100K miles. The parts now are better than days of old but my zetecs show they could use exhaust valve grinding around that mileage. Engine will still run fine without it but you DO pick up some small amount of power when they are recut that you will feel when stomping on it. The intakes are not a problem, they pretty much are just like new. 100% unleaded fuel is hard on exhausts though, they still try to recede and the sealing surfaces will get a little rough by around 100K.
You can check that with a compression leakdown test which is different from a standard compression test. And without pulling head.
amc49 is offline
