BBK 65mm TB - Page 2 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus First Generation > ZETEC Performance (2000-2004)
Old 10-23-2013, 03:07 PM   #11
GhostTribute
GhostTribute's Avatar
Fan#: 107929
What I Drive: 2001 Mazda Tribute (2.0L Zetec)
FF Reputation: 1 GhostTribute Good Standing Member
A 5mm 6 point socket/wrench will also work to remove those studs.
GhostTribute is offline
Old 10-23-2013, 03:12 PM   #12
Magus2727
Magus2727's Avatar
Fan#: 62897
a 5 mm is almost as common as the inverse TQ bits also... but you can usually buy the 5mm standalone where the inverted TQ are usually in sets.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 10-23-2013, 03:30 PM   #13
GhostTribute
Fan#: 107929
Guess it all depends on the tools you have in your arsenal. I don't have any reverse tq tools. I work on more metric engines and vehicles than standard, so that probably explains why I have a couple 5mm sockets in my box.
5mm socket for $2.50 or $3.00 at Sears.
Old 10-24-2013, 06:57 AM   #14
Logrim
Fan#: 119686
What I Drive: 2000 Pitch Black ZX3
FF Reputation: 1 Logrim Good Standing Member
Rgr, thanks again for all the info guys. I will try and post pics this weekend if I can do the swap.
Logrim is offline
Old 10-24-2013, 10:00 PM   #15
GhostTribute
Fan#: 107929
If you are going to pull out the porting tools you could also look into cleaning up the rough castings and harsh transition from the tube on the BBK. I wasn't really all that impressed with mine so I put a better transition on it and polished it up a bit.
Before;
After;
Old 10-29-2013, 10:24 AM   #16
Logrim
Fan#: 119686
Before;
After;
That TB looks a ton better. I didn't have time for the install this past weekend bcuz I am moving into our new home. House takes precedence... perhaps I will have a bit of time just to polish up my TB this weekend.
Logrim is offline
Old 10-29-2013, 10:27 AM   #17
Logrim
Fan#: 119686
Did you guys see any gains from the TB install? Or just a snappier throttle response and the ability to engine brake? please let me know.
Logrim is offline
Old 10-29-2013, 10:35 AM   #18
Magus2727
Magus2727's Avatar
Fan#: 62897
A TB is not really a bottle neck in the air intake system on our cars. There are other items. on a Dyno you might see some increase in power however in real world application you wont feel any more power. The throttle may be a little "snappier" But I think some have said that that also can be a placebo effect.
Hatch Nation #42
Old 10-29-2013, 11:22 AM   #19
GhostTribute
Fan#: 107929
That stock throttle body is laughable... What's up with that ridiculous plastic wedge throttle plate design? That wedge on it's own is a resistance to flow. Then you take into account the odd angle inlet..... WTF? Not sure who designed something like that but it is less than optimum for any kind of performance!
I agree that the TB isn't as much of a restriction as the very small diameter intake runners are on the Zetec.
Not sure about a stock head. However, with a set of cams and port matched intake the 65mm throttle body is much snappier and that is not a placebo. There are also gains to be had if you tune for the change.
Old 11-03-2013, 09:03 PM   #20
Logrim
Fan#: 119686
Problems
Okay, so I went to do the install and my linkage does not match up with the TB. All the pics that I have brought up, including Ghost Tribute's, indicate that I have the right TB, just not the right linkage???? I don't understand? I matches with my old TB. Perhaps the model year is off? I will post some pics soon, maybe you gents have some input. I dunno......
Logrim is offline
