Thinking of buying a car with issues...Advice Please!!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 10-20-2013, 01:21 AM   #1
SVT54
Fan#: 119231
What I Drive: 2003 Black EAP SVT Focus
Points 48, Level 1
Points: 48, Level: 1 Points: 48, Level: 1 Points: 48, Level: 1
Level Up 96% Completed
FF Reputation: 1 SVT54 Good Standing Member
I went and looked at an 03 SVT Focus EAP today. The car has 206k on the clock, but the guy makes a 90 mile highway round trip to work, and has owned it since 06. The car is pretty clean, interior is in great shape, new tires. Now on to the issue. I searched, but didn't find a post with this issue, where the person actually came back to tell what fixed it...
When you start the car, it idles a little high just like it should. After a couple of minutes, the idle drops down. Shortly after that it starts to stumble for about 20-30 seconds then dies. It took a few tries to start again after that. Out on the road, it drives fine. Cruises well, and feels strong under WOT. When I turned around, I stopped for a bit in a parking lot, and let it idle, and sure enough it went back to stumbling. I blipped the throttle and it quit. I went to pull onto the road again, and it bogged as I tried to accelerate. I let off, and tried again and it bogged again. I pulled to the side, blipped the throttle a few times, and off it went. Once again, it drove great all the way back. I have a bluetooth OBDII module, and the CEL was on. I checked it, and it had a bank1 sensor 1 lean code.
The owner says he has replaced the 02 sensor. Does this sound like a vacuum leak, PCV, fuel filter, MAF, TPS, or something else?
The car has high miles, but it is $1500 cheaper than any other SVTF I have found, and I have been looking for nearly a month. I would like to buy this car, and don't have any trouble working on it. I can put anything back together if I take it apart. I just want to make sure you all don't think it something more serious, and if I do buy it, where to start looking first.
Thanks, and sorry for the long post.
SVT54 is offline
Old 10-20-2013, 09:19 AM   #2
Jon_SVT
Jon_SVT's Avatar
Fan#: 34787
What I Drive: 2002 Silver SVT Focus
Points 639, Level 12
Points: 639, Level: 12 Points: 639, Level: 12 Points: 639, Level: 12
Level Up 78% Completed
FF Reputation: 2 Jon_SVT Good Standing Member
if I were you I would start by cleaning the IAC..... its located on the back of the intake manifold... its a bit of a hassle to get in but not impossible. 2 screws, not super tight.... dont drop them, you'll spend more time finding them than you will trying to get the thing out!
I've replaced like 4 TPS' and can tell you that issues with the TPS are very apparant. Start the car and it'll rev to the sky OR rev very
high... yea, sounds like this one has to do with a "closed loop" idle problem..... once it enters closed loop it fails. If the IAC is clogged or getting sticky it won't be able to open (or open fast enough) when the car enters idle..... thus not letting air through causing the car to stumble and eventually die. Thats my guess..... Check out that IAC! Upon failing that (due to the codes) maybe have the owner maybe replace BOTH sensors at the same time? or you do it? www.rockauto.com has very cheap ones (like $30ish) and they're pretty easy to replace...
doesn't sound like spark plugs or fuel filter or anything like that... if it was a fuel delivery problem it wouldn't idle fine when you first started it nor would it drive good at WOT. WOT + Fuel delivery problems = stumbly WOT.... PCV could be checked.... its super easy to get to and costs under $5 to change. It's on the right side of the motor near the thermostat housing. I've had the little 90degree elbow hose break on me which caused issues also. (I've since removed PCV all together and have moved to an oil catch can).
I really want to say IAC so check that one out.... I recall seeing a writeup about cleaning it in the HOW TO archive on here. Good luck with your purchase!
Loyal Focus Owner!!!
First: 2003 Ford Focus ZX5
Second: 2002 Ford Focus SVT (#2808 of 4788)
Jon_SVT is offline
Old 10-21-2013, 12:51 AM   #3
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,157, Level 74
Points: 13,157, Level: 74 Points: 13,157, Level: 74 Points: 13,157, Level: 74
Level Up 77% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (46)
Moved to "Ford Focus & General Car Chat".
zetecDon is offline
Old 10-21-2013, 09:08 AM   #4
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
Seems that you actually do.
None of us can see the car so we'd simply respond with the typical 'it could be xxx' responses. Bring it to a certified mechanic and have them look it over.
iminhell is offline
Old 10-21-2013, 04:59 PM   #5
flyboyike
Fan#: 98206
What I Drive: 2012 Race Red SE sedan
Points 335, Level 6
Points: 335, Level: 6 Points: 335, Level: 6 Points: 335, Level: 6
Level Up 70% Completed
Forum Activity 7%
FF Reputation: 3 flyboyike Good Standing Member
A car with issues is like a car with issues.
flyboyike is offline
Old 10-21-2013, 05:14 PM   #6
crazy_urn
Capt. Urn
crazy_urn's Avatar
Fan#: 1986
What I Drive: 77 F-250, 10 HHR, 08 Outlook
FF Reputation: 5 crazy_urn Good Standing Member
I know SVTs are hard to find... but typically if there is one obvious issues, it is an indication of how the car was taken care of. Either it is a minor issue and the owner just never cared enough about the care to get it fixed, or it is a major issue that the can't or don't want to fix.
To me, either is a warning sign about the car. Sometimes you can't pass up a great deal, but I would assume going in that there is a lot more wrong with the car than meets the eye.
I second the suggestion to take it to a mechanic. But even then, I would be wary of other issues that may surface down the road.
Defending the reputation of the red-headed step-child of the focus world for far too long.
crazy_urn is offline
Old 10-22-2013, 01:29 PM   #7
RedDogAB
RedDogAB's Avatar
Fan#: 107829
What I Drive: 2007, Silver, ZX5 SES - modified
Points 35, Level 1
Points: 35, Level: 1 Points: 35, Level: 1 Points: 35, Level: 1
FF Reputation: 1 RedDogAB Good Standing Member
No way would I buy (or date) anything with "issues", never mind any vehicle with that mileage on it. Move on.
RedDogAB is offline
Old 11-22-2013, 12:00 AM   #8
SVT54
Fan#: 119231
Points 48, Level 1
I forgot to come back and update.. I bought the car. Took me 15 minutes and a can of carb cleaner to diagnose it. PCV was cracked. New one fixed the problem. I now had $2409 in a perfectly fine running car. I have since replaced the timing belt, tensioner, and idler, for peace of mind. Changed the plugs and put a double din, touch screen Clarion in with the factory sub and steering controls hooked up. I also polished and sealed the factory HIDs.
So far I love the car. It's fun to drive. So here are a couple of pics from the day I picked it up.
SVT54 is offline
Old 11-22-2013, 06:08 AM   #9
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
More power to ya bro!
Feel your way around the SVT Performance forum and see what things you can look for in the future as far as possible issues. I know I'd advise you to check that IMRC clip, some people call it the DSI clip (intake manifold runner control, and dual stage intake respectively). I don't own an SVT, so I don't know what it looks like.
Now you know one of the reasons I liked Fords when I was buying used cars- usually simple issues that people freak out on. If it was a VW or something, they'd think it was normal. When it's a Ford you get "OMG it's going to explode tomorrow! Sell today!"
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 11-22-2013, 06:31 PM   #10
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,417, Level 75
Points: 13,417, Level: 75 Points: 13,417, Level: 75 Points: 13,417, Level: 75
Level Up 42% Completed
Forum Activity 99%
Good deal on a nice car, glad it worked out for you!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
