Cheap and Easy Manual Shifter Bushing Fix - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-18-2013, 05:59 PM   #1
danvhp
Fan#: 113780
What I Drive: 2002 Silver Ford Focus SE
FF Reputation: 1 danvhp Good Standing Member
I searched the FF forum and could not find an easy solution to fix the cable shifter bushing problem on the 2000 to 2004 SPI manual transmission. So I came up with one on my own. The manual trans shifter in my Focus was very sloppy between gears. I removed the cover on the trans and found the bushing was missing from the end of the shifter cable. Ford will not sell you a replacement bushing. You have to buy the shifter cable set and it isn't cheap. Plus, it is a pain to replace.
With the linkage cover off, I noticed that shifter cable end looked like the shifter cable from a Dodge Neon. The Neon suffers from the same problem when the bushings harden and then fall apart. The solution on the Neon is called Booger Bushings. The website for ordering these bushings is: http://www.boogerracing.com/boogerbushings.html
I ordered a set that included a small and a large bushing because I wasn't sure which one would fit. The two bushing set costs $12 and that includes shipping. I used the small bushing and it fits perfectly. Just put a little grease on the linkage shaft and snap the bushing in place. Now the shifts are nice and crisp with no sloppiness. Plus, they come in an array of colors. Happy motoring!
danvhp is offline
Old 10-18-2013, 09:24 PM   #2
qweesy
qweesy's Avatar
Fan#: 12042
What I Drive: 2004 focus Duratec 2.3 RS (DEAD)
Points 3,177, Level 34
Points: 3,177, Level: 34 Points: 3,177, Level: 34 Points: 3,177, Level: 34
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
Forum Activity 11%
FF Reputation: 4 qweesy Good Standing Member
Buy-Sell-Trade Rating: (6)
did the SPI use the MTX 75?....I know Wungun made a solid bushing for the Getrag SVT...
qweesy is offline
Old 10-18-2013, 09:30 PM   #3
danvhp
Fan#: 113780
Somebody with more knowledge than I regarding which trans is used by the SPI engine will have to chime in for that answer.
danvhp is offline
Old 10-19-2013, 05:09 PM   #4
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
No, the SPI had the IB5 transmission.
Hatch Nation #90
TboneZX3 is offline
