2 subwoofers on one channel - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-22-2013, 06:40 AM   #11
ferret15
ferret15's Avatar
Fan#: 83494
What I Drive: 03 zx3 and a screeming yellow eap
Points 605, Level 12
Points: 605, Level: 12 Points: 605, Level: 12 Points: 605, Level: 12
Level Up 10% Completed
FF Reputation: 2 ferret15 Good Standing Member
I want to start and say this is just such a terrible idea, but I think you should learn for yourself since the speakers you got probably didn't cost you anything. Plus you never you know when your going to get luck. You would be better off Using 1 and make a sweet tuned box. So here we go.
Basically find out the ohm load, SVC is simple it says what it is. If its a DVC find out what it says it is, which is really the rating of the individual coils, then wire parallel for 1/2 or series for the sum.
Example 2ohm DVC in parallel, is 1 ohm parallel and 4 ohms series.
You wire subs Positive wire to positive wire, and Neg to neg. So If your using a 2ohm SVC and a 4 ohm DVC (wired in parallel) that still comes out to a 2ohm load on your amp. If you have a 4 ohm SVC you will want a 2ohm DVC (wired in series) to get a 2ohm load on your amp. Once again wire the 2 subs together in series + to + to amp and - to - amp. I assume your amp is hooked up with atleast 2awg and is rated for 800rms. Any options for different combos outside the examples I just gave you can do the math because you get high or low of the recommend impedance of most amps you will find and That is usually bad for your amp. Run with a low ohm and it probably burns out your amp and if its to high it will probably burn out your coils
ferret15 is online now
Old 10-22-2013, 12:22 PM   #12
Speshulldroo
Speshulldroo's Avatar
Fan#: 85488
What I Drive: 2008 Red MTX Sedan
Points 202, Level 4
Points: 202, Level: 4 Points: 202, Level: 4 Points: 202, Level: 4
Level Up 4% Completed
FF Reputation: 1 Speshulldroo Good Standing Member
I definitely see where you're coming from. Thanks for the heads up.
Speshulldroo is offline
Old 10-22-2013, 12:27 PM   #13
SlickWilly
SlickWilly's Avatar
Fan#: 116476
What I Drive: 2009 Ford Focus SES Sangria Red
Points 5,269, Level 46
Points: 5,269, Level: 46 Points: 5,269, Level: 46 Points: 5,269, Level: 46
Level Up 60% Completed
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 6 SlickWilly Good Standing Member
A box makes all the difference in the world OP. One sub in a great box will out perform two in a conventional box.
09 4F27E - K&N Intake - Magnaflow Exhaust - F2 Header - CFM Race Pulleys - VF Engineering Mounts - Nitrous Express Proton EFI - NX Launch Control & Progressive timer - NOS Window Switch
SlickWilly is offline
Old 10-22-2013, 01:43 PM   #14
Speshulldroo
Fan#: 85488
Points 202, Level 4
Do you recommend building a box to the manufacturer specs, or is there more of a science to it? For what it's worth, I've always been an SQ guy, so I tend to lean toward sealed boxes. They've always sounded cleaner in my experience (which obviously isn't much).
Old 10-22-2013, 02:50 PM   #15
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,772, Level 54
Points: 6,772, Level: 54 Points: 6,772, Level: 54 Points: 6,772, Level: 54
Level Up 11% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
Yes.
That is what the T/S Parameters are all about. You can download WinISD for free. Play around with it. There is loads of of online support for it as well.
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 10-22-2013, 02:54 PM   #16
SlickWilly
SlickWilly's Avatar
Fan#: 116476
Forum Activity 15%
I like sealed boxes too, but there is ways to get a sealed sound with the efficiency of a ported box. I had one made for my L5 that sounded sealed, but hit like it was ported. Very sharp, punchy, accurate bass with awesome lows.
Uploaded with ImageShack.us
Old 10-23-2013, 01:37 PM   #17
Speshulldroo
Fan#: 85488
Points 202, Level 4
This is some awesome info guys. Y'all have me thinking a whole new way. Time to do some research!
