200 HP NA cars? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-17-2013, 11:15 AM   #1
Gettysburg150
Gettysburg150's Avatar
Fan#: 97408
What I Drive: 08 Silverfrost Metallic SE, 5 speed
Points 1,255, Level 19
Points: 1,255, Level: 19 Points: 1,255, Level: 19 Points: 1,255, Level: 19
Level Up 55% Completed
FF Reputation: 2 Gettysburg150 Good Standing Member
200 HP NA cars?
I want about 200 WHP from my car. I did a search but couldn't find much info on getting to 200 with a 2.0. Has anyone done this? I'd like to hear some opinions and see some results.
Thanks!
Sedan Revolution Two Three Zero
FRPP, "Stealth" CAI, Debadged, wider tires, louder stereo, turbo mainfold in the wrong place...
Gettysburg150 is offline
Old 10-17-2013, 11:22 AM   #2
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,701, Level 76
Points: 13,701, Level: 76 Points: 13,701, Level: 76 Points: 13,701, Level: 76
Level Up 13% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
http://cosworth.com
felixthecat is offline
Old 10-17-2013, 11:54 AM   #3
tb1999
tb1999's Avatar
Fan#: 44261
What I Drive: '05 ZX3 D2.3 & '03 Jag S-TYPE 4.2L
Points 24,558, Level 95
Points: 24,558, Level: 95 Points: 24,558, Level: 95 Points: 24,558, Level: 95
Level Up 21% Completed
FF Reputation: 47 tb1999 Great Standing Member
Buy-Sell-Trade Rating: (7)
Check out my thread for the build on my race engine. Its not that difficult to do but expensive. I got 215 to the wheels using a stock intake and TB. You can hit that number a little easier if you upgrade the intake. Most high power nap duratecs use individual Thottle bodies but the cossie intake or eBay clone. The biggest problem is you will have to spin the engine to very high RPM's. Which means you'll need some exotic lower end parts and oiling system. Cus words has all the details worked out and it's an awfully good engine but you need deep pockets....
Sent from my XT1030 using FF Mobile
213 whp / 160 wtq D23 NA with stock intake and TB.
Inventor of "The $0 Thunder Throttle" & "Focuzdax-7" brake swap.
I like the same qualities in women and pistons; Lightweight, fast, and with the smallest skirts possible...
tb1999 is online now
Old 10-17-2013, 12:24 PM   #4
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,883, Level 59
Points: 7,883, Level: 59 Points: 7,883, Level: 59 Points: 7,883, Level: 59
Level Up 67% Completed
Forum Activity 30%
FF Reputation: 24 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
OP,
Most of the 200hp n/a builds start to get expensive, with plenty of people chiming in to stay go FI. Always a cool idea and i like seeing them but hard to justify the costs for the gains vs going turbo.
would have loved to see what you could have done if you werent restricted to stock intake/tb. your video of the car backing up in your drive way with out the exhaust is still one of my favorite duratec vids, sounded amazing. You should rebuild it
rambleon84 is offline
Old 10-17-2013, 01:00 PM   #5
Gettysburg150
Fan#: 97408
Thanks guys, thats kinda what I figured. I'm still toying with the idea of a budget turbo build but a stage 2 from fswerks is probably worth the investment in time savings / parts mixing
Old 10-17-2013, 02:38 PM   #6
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
What I Drive: 72 Skylark, '12 Mustang
Points 28,295, Level 98
Points: 28,295, Level: 98 Points: 28,295, Level: 98 Points: 28,295, Level: 98
Level Up 95% Completed
Level up: 95% Level up: 95% Level up: 95%
FF Reputation: 39 Buickboy Great Standing Member
Buy-Sell-Trade Rating: (29)
Wasnt there a rev limit for the stock ECU? Something just north of 8k? That would stop a high HP 2.0 id imagine
==2012 Kona Blue Mustang V6==
==1995 Light Iris Neon Coupe==
==1972 Skylark==
Buickboy is offline
Old 10-17-2013, 03:15 PM   #7
tb1999
tb1999's Avatar
Fan#: 44261
Yep, 8300 is max the real time CPU can count before it loses synch for the 35-1 tooth count... And if you don't have a custom file like I do its limited to 8000, regardless of what values you set using SCT's software...
Old 10-17-2013, 03:19 PM   #8
tb1999
tb1999's Avatar
Fan#: 44261
My next move was going to be building a megasquirt 2...
Old 10-17-2013, 03:40 PM   #9
SlickWilly
SlickWilly's Avatar
Fan#: 116476
What I Drive: 2009 Ford Focus SES Sangria Red
Points 5,279, Level 46
Points: 5,279, Level: 46 Points: 5,279, Level: 46 Points: 5,279, Level: 46
Level Up 65% Completed
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
FF Reputation: 6 SlickWilly Good Standing Member
I believe you can do a rear mount turbo for about 1k or less. I had one completely ready for my Camaro that I built for 780$. You can also do a conventional turbo set up for cheaper if you build it yourself.
I think I was on FSWERKS page on FB and it showed a turbo build vs a N/A build and the Turbo build made a lot more power, the down fall of the turbo was the N/A turned 7800 RPM's, which must be fun as hell!
09 4F27E - K&N Intake - Magnaflow Exhaust - F2 Header - CFM Race Pulleys - VF Engineering Mounts - Nitrous Express Proton EFI - NX Launch Control & Progressive timer - NOS Window Switch
SlickWilly is offline
Old 10-17-2013, 11:39 PM   #10
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 100%
[QUOTE=tb1999;4903577]My next move was going to be building a megasquirt 2...
And will that motor be built in the kitchen, Tom? LOL
