Should I Replace Lifters With Cams? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-16-2013, 08:36 AM   #1
homey55
homey55's Avatar
Fan#: 54911
What I Drive: 2003, Silver, ZX3 2.3 5-speed
Points 1,161, Level 18
Points: 1,161, Level: 18 Points: 1,161, Level: 18 Points: 1,161, Level: 18
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
Forum Activity 2%
FF Reputation: 4 homey55 Good Standing Member
Since my car has about 160k on the odometer, should I be worried about wear on the lifters ruining my cams when I replace them? I have a new set of Crower stage I cams that I want to install but I was worried that worn lifters may prematurely wear the new cams. What are your thoughts on this? If I have to replace the whole valvetrain then the cams arent really worth the hastle to me,
Autolite 103's, Cosworth CAI, FRPP Suspension, Strut Bars, DIY Short Shifter, SVT Air Dam, BSD, Poly Trans Mount, Borla 2.5", Roush Wheels, Tune...
homey55 is offline
Old 10-16-2013, 09:34 PM   #2
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,954, Level 74
Points: 12,954, Level: 74 Points: 12,954, Level: 74 Points: 12,954, Level: 74
Level Up 26% Completed
Forum Activity 99%
I'd install the cams. Enjoy the response.
felixthecat is offline
Old 10-16-2013, 09:54 PM   #3
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,576, Level 30
Points: 2,576, Level: 30 Points: 2,576, Level: 30 Points: 2,576, Level: 30
Level Up 84% Completed
Forum Activity 8%
No, don't start changing the buckets unless you do a valve job and the valve stem height changes.
2.3, home fabbed Mustang GT brakes, SVT suspension
67 Chevelle SS-496, owned since 1991
elsolo is offline
Old 10-17-2013, 08:44 AM   #4
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,852, Level 100
Points: 51,852, Level: 100 Points: 51,852, Level: 100 Points: 51,852, Level: 100
Level Up 0% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
Buy-Sell-Trade Rating: (28)
I wouldnt change them just to be changing them , you will need to check your valve clearances with the new cams you cant just put the cams in and go so you may need to change a few to all of them to get proper valve clearances
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 10-17-2013, 11:05 AM   #5
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 99%
The base circle of the aftermarket cams should be the same as the oem ones & yeah, like said above its good to check the clearence. As some cams have varies spec's vs the stock spec's. I installed a set of cranes & checked & were in spec for cranes.
Old 10-23-2013, 08:57 AM   #6
amc49
Fan#: 96610
Points 3,270, Level 35
Points: 3,270, Level: 35 Points: 3,270, Level: 35 Points: 3,270, Level: 35
Level Up 47% Completed
Forum Activity 9%
The base circle is SUPPOSED to be the same but you are making a mistake by assuming so. The parts need to be measured like Tom says, they may well work but you could be off as far as ideal clearances. Sloppy work that could decrease the mileage of parts. I've never worked on an engine where you could leave all the same, that would be a rare bird indeed. Usually at least 2-3 need to change or swap around.
amc49 is offline
Old 10-23-2013, 07:28 PM   #7
elsolo
elsolo's Avatar
Fan#: 96835
Forum Activity 8%
If he hasn't sunk a valve, and the new cam has the same base circle (it should), then no need.
But remember rule #1 with working with engine internals:
Measure, check, and recheck. Never assume anything.
elsolo is offline
