Keeping fog lights on with highbeams - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-22-2013, 03:58 PM   #11
SKimpy007
Fan#: 111599
What I Drive: 2009 Silver Focus SES 4 Door
FF Reputation: 1 SKimpy007 Good Standing Member
I was wondering with the jumper can you turn the fogs off or are they always on with headlights?
SKimpy007 is offline
Old 10-22-2013, 09:34 PM   #12
Gav-O-SVT
I Like Red
Gav-O-SVT's Avatar
Fan#: 113561
What I Drive: '02 Infra-Red SVT
Points 3,103, Level 34
Points: 3,103, Level: 34 Points: 3,103, Level: 34 Points: 3,103, Level: 34
Level Up 36% Completed
Forum Activity 99%
FF Reputation: 6 Gav-O-SVT Good Standing Member
You can turn them off, all it does is allow them to be turned on with the parking lights and they stay on with the high beams on. If you turn off the fogs the other lights work like normal.
Gav-O-SVT is online now
Old 10-24-2013, 03:48 PM   #13
Miztaken1312
Miztaken1312's Avatar
Fan#: 74993
What I Drive: 2008 Black Coupe SES
Points 1,389, Level 20
Points: 1,389, Level: 20 Points: 1,389, Level: 20 Points: 1,389, Level: 20
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
FF Reputation: 2 Miztaken1312 Good Standing Member
Originally Posted by Gav-O-SVT View Post
This is what I did. Except I used a inline fuse as the jumper and crimped on the tabs to plug into the slots. This makes it a little safer as the reg way will eventually burn out the jumper wire. Thats what happened to me before I used the inline fuse (amp rating is the same as the fog fuse under the dash). And I used very large gauge wire... The inline tucks nicely in the empty area to the left of the relays. Heres some pics...
That is very clean. I like it. I'm gonna try and get to this on the weekend.
My car came with fogs pre-installed, so I hope this works. When I turn my light switch, I can turn it once for just parking lights, and then I can pull it out to turn on the fogs. So it's either parking lights or parking lights with fogs. The second turn turns on the headlights.
FSWerks Turbo Kit @ 8psi , Stealth Exhaust, & Lower Stress Bar | Projectors w/5000K HIDs, LED Tails with Lamin-X Tint
Steeda Short Throw & Upper Strut Bar| FRPP Suspension & CFM Lower Mount |
Miztaken1312 is offline
Old 11-01-2013, 02:27 PM   #14
Miztaken1312
Fan#: 74993
So I'm about to attempt this today. Should I screw up... what's the worst that could happen? Blown fuse somewhere?
Old 11-01-2013, 02:46 PM   #15
SKimpy007
Fan#: 111599
Ya. I'm gonna need someone with our fuse box to show me this one.. I'm looking through the manual and fog lights aren't even on the engine fuse box list.
Old 11-01-2013, 02:50 PM   #16
Miztaken1312
Fan#: 74993
I'll check my shop manual when I get off work at about 5:30.
Old 11-01-2013, 08:03 PM   #17
Gav-O-SVT
I Like Red
Gav-O-SVT's Avatar
Fan#: 113561
Forum Activity 99%
Nothing will happen, all you are doing is bypassing the relay. Just be sure to use large guage wire for the jumper, like you saw in my pics, a inline fuse is perfect. Make sure to use two male connectors crimped on the ends of the inline so they slide into the relay slots nice and snug. Also be sure to use the same amp rated fuse as the fogs use, I believe its a 20. If you use too small of gauge wire for the jumper you can burn it out. The lights and fuses will still b ok but the wire itself will essentialy melt... Use what I did and you will be ok. As far as where the relay is on a MK2, im not sure but when you find it the process will be exactly the same. Good luck!
Old 11-05-2013, 11:00 PM   #18
Miztaken1312
Fan#: 74993
So update...
There is no relay under the hood for the foglights. It's controlled by a computer signal. So now I need to figure out how to trick the computer by changing the way a circuit is routed. All I know is I need to find some orange/white wires and bring them together...
Old 11-25-2013, 08:45 PM   #19
johnriii44
johnriii44's Avatar
Fan#: 72948
What I Drive: 2006 Light Tundra ZX3
FF Reputation: 2 johnriii44 Good Standing Member
So update...
I installed the fogs after I bought the car and could only find one part of the wiring harness to wire it up so I had to do it off of the wiring book that I bought for my 06. I'm on my phone right now but if you need any pictures if anything from the wiring book let me know. I'll also see if I can take a look at my wiring if it gets a bit warmer and see if I can snap some pics.
HatchNation [#71]
johnriii44 is offline
Old 11-25-2013, 08:47 PM   #20
Miztaken1312
Fan#: 74993
Its quite a bit different since the 08 has a lot more electronics
Sent from my Galaxy S3
