Keeping fog lights on with highbeams - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-14-2013, 03:02 PM   #1
Miztaken1312
Miztaken1312's Avatar
Fan#: 74993
What I Drive: 2008 Black Coupe SES
Points 1,431, Level 21
Points: 1,431, Level: 21 Points: 1,431, Level: 21 Points: 1,431, Level: 21
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
Forum Activity 2%
FF Reputation: 2 Miztaken1312 Good Standing Member
As the title states, is there a way to change this behavior? I can understand maybe why you would do this with halogen bulbs with the stock housings, but since I've switched to HIDs for my headlights and foglights with lower energy usage, I want to keep them both on.
FSWerks Turbo Kit @ 8psi , Stealth Exhaust, & Lower Stress Bar | Projectors w/5000K HIDs, LED Tails with Lamin-X Tint
Steeda Short Throw & Upper Strut Bar| FRPP Suspension & CFM Lower Mount |
Miztaken1312 is offline
Old 10-14-2013, 04:08 PM   #2
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,749, Level 78
Points: 14,749, Level: 78 Points: 14,749, Level: 78 Points: 14,749, Level: 78
Level Up 75% Completed
Forum Activity 14%
FF Reputation: 16 Elizabeth Great Standing Member
It is illegal (in most states) to have fog lights and high beams on. (at least on a public highway/street)
The only possible desire for both on at the same time is 'bling'.
There is no other reason for both on.
How ever i am not saying you can't.. just you should not.
Elizabeth is online now
Old 10-14-2013, 04:10 PM   #3
Gav-O-SVT
I Like Red
Gav-O-SVT's Avatar
Fan#: 113561
What I Drive: '02 Infra-Red SVT
Points 3,483, Level 36
Points: 3,483, Level: 36 Points: 3,483, Level: 36 Points: 3,483, Level: 36
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
Forum Activity 99%
FF Reputation: 6 Gav-O-SVT Good Standing Member
I know you can do that with the MK1s by taking out the fog relay in the engine bay and running a jumper wire. That makes it so you can turn on the fogs with just the parking lights on and so they will stay on even when you switch to high beams. Not sure if you can do it on MK2s but its worth a try. There is a page on here that shows how to do the MK1 fog light hack, the only difference is that I used a inline fuse as the jumper with the same rating fuse in it as the fog light fuse under the dash just to be safe. Good luck.
Gav-O-SVT is online now
Old 10-14-2013, 04:18 PM   #4
novus
novus's Avatar
Fan#: 107022
What I Drive: '12 Tuxedo Black Focus SEL
Points 933, Level 16
Points: 933, Level: 16 Points: 933, Level: 16 Points: 933, Level: 16
Level Up 33% Completed
Forum Activity 2%
FF Reputation: 5 novus Good Standing Member
And this is the first of many "it's illegal" comments.
novus is offline
Old 10-14-2013, 05:15 PM   #5
VonKrause
Unicorn Owner
VonKrause's Avatar
Fan#: 72283
What I Drive: 2009 Ice Blue 5 speed 4 door FoFo
Points 36,103, Level 100
Points: 36,103, Level: 100 Points: 36,103, Level: 100 Points: 36,103, Level: 100
Level Up 0% Completed
FF Reputation: 7 VonKrause Good Standing Member
I know for a fact that if it didn't come stock with fog lights it's really easy, however if it came with them I'm not %100. When installing fog lights you splice a wire into a orange white wire in the steering column which turns the fogs off when high beams are turned on, if I had to guess (don't have a full wiring diagram on hand) this orange white wire has something to do with it.
I wrote a fog light install a few years back if you want to check it out, it's in the "how to archive".
As always check with local laws on this topic before going at it.
Ps mine work whith high beams, but it didn't come with them.
Get your trunk or hatch LED conversion kits here http://www.focusfanatics.com/forum/showthread.php?p=4542652#post4542652
"2nd Gen problems"
I've spent too long looking into the abyss. It's starting to look back.
SR #233
VonKrause is offline
Old 10-15-2013, 02:27 AM   #6
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
Points 8,540, Level 62
Points: 8,540, Level: 62 Points: 8,540, Level: 62 Points: 8,540, Level: 62
Level Up 30% Completed
FF Reputation: 9 crice8 Good Standing Member
Buy-Sell-Trade Rating: (13)
Wire them to an AUX Switch. Mine didn't come with fogs, so when I installed the factory ones I wired them to a toggle switch.
Galatians 6:14
crice8 is offline
Old 10-15-2013, 07:17 AM   #7
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
What I Drive: 2002 SVT, 2001 SE (Rusty)
Points 58,328, Level 100
Points: 58,328, Level: 100 Points: 58,328, Level: 100 Points: 58,328, Level: 100
Forum Activity 14%
FF Reputation: 49 02fordsvt Great Standing Member
Buy-Sell-Trade Rating: (11)
For MK1. It may be worth a shot on your MK2: http://www.focusfanatics.com/howtos/foglight/
Hatch Nation #13 : Rally Revolution #13 : ROTM Jan '13
It's Bryan, not Brian
RSVT-170 Build in Progress
Derusting Rusty Build in Progress
02fordsvt is offline
Old 10-15-2013, 10:13 AM   #8
Miztaken1312
Fan#: 74993
Forum Activity 2%
Thanks for the help guys. As for the legality of it, I can honestly say I don't really care. It's not like I'm going to be flashing cops as I drive by.
Old 10-15-2013, 07:18 PM   #9
Gav-O-SVT
I Like Red
Gav-O-SVT's Avatar
Fan#: 113561
Forum Activity 99%
This is what I did. Except I used a inline fuse as the jumper and crimped on the tabs to plug into the slots. This makes it a little safer as the reg way will eventually burn out the jumper wire. Thats what happened to me before I used the inline fuse (amp rating is the same as the fog fuse under the dash). And I used very large gauge wire... The inline tucks nicely in the empty area to the left of the relays. Heres some pics...
Old 10-16-2013, 07:45 AM   #10
02fordsvt
Meh.
02fordsvt's Avatar
Fan#: 84654
Forum Activity 14%
I've been running my jumper for 3 years and never had a problem, but a fuse never hurts either.
