Rod bearing replace from below? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-14-2013, 01:06 AM   #1
yatipope
Fan#: 110588
What I Drive: 2000 yellow ZX3
FF Reputation: 1 yatipope Good Standing Member
A friend of mine has a 2005 ZX3 which has what most certainly is a knocking rod bearing. Can these be inspected/replaced from below by just removing the oil pan? I know the crankshaft journal may be scored and damaged so that needs inspection of course,..BUT just wondering if this style engine permits replacing rod bearings from below! Anybody?
yatipope is offline
Old 10-14-2013, 11:20 AM   #2
Trapper L
Fan#: 54336
What I Drive: 2006 Focus ZX4
FF Reputation: 3 Trapper L Good Standing Member
Yeah, but removing the pan is only going to let you gauge the bearing and not the damage from lack of oil on the ring for that cylinder. The oil to the rings is sprayed from the crank cap/rod onto the cylinder walls. Any leakage or a spun bearing means no oil is getting to the ring. It won't last long like that. If it has a bad bearing, it also has a bad piston ring. It's a decent place to start but expect a full rebuild if the bearing is bad.
Trapper L is offline
Old 10-15-2013, 12:42 AM   #3
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,521, Level 30
Points: 2,521, Level: 30 Points: 2,521, Level: 30 Points: 2,521, Level: 30
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 11%
I don't know about that.
Most engines don't have oil squirters and their rings last just fine, they are mostly for piston cooling not throwing excess oil on the cylinder walls for the oil rings to scrape off.
You can do the rod bearings in car, but you better take a good inspection of the damage or it will be a temporary fix. Usually a spun rod bearing chews up that crank journal enough to require a regrind, and the rod's big end may no longer be true.
2.3, home fabbed Mustang GT brakes, SVT suspension
67 Chevelle SS-496, owned since 1991
elsolo is offline
