adjusting valves - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-06-2013, 09:34 PM   #1
Texas Ranger
Fan#: 119390
What I Drive: 2001 dark red ZX4
Points 146, Level 2
Points: 146, Level: 2 Points: 146, Level: 2 Points: 146, Level: 2
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
FF Reputation: 1 Texas Ranger Good Standing Member
adjusting valves
I would like to know if anyone knows how to adjust the valve clearances on a 2001 spi. I have a tick coming from the camshaft. Pictures would be greatly appreciated, thanks!
Texas Ranger is offline
Old 10-07-2013, 04:42 PM   #2
crazy_urn
Capt. Urn
crazy_urn's Avatar
Fan#: 1986
What I Drive: 77 F-250, 10 HHR, 08 Outlook
FF Reputation: 5 crazy_urn Good Standing Member
A quick search indicates that the valves on the SPI cannot be adjusted. Haven't looked into it personally, but that has been the conclusion of a few different threads through the years.
http://www.focusfanatics.com/forum/s...=adjust+valves
Defending the reputation of the red-headed step-child of the focus world for far too long.
crazy_urn is offline
Old 10-07-2013, 05:44 PM   #3
amc49
Fan#: 96610
Points 3,360, Level 36
Points: 3,360, Level: 36 Points: 3,360, Level: 36 Points: 3,360, Level: 36
Level Up 7% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
You don't adjust hydraulic lifters. The tick says bad lifter or enough wear in valvetrain to open up clearance past what the lifter takes up travel wise. Occasionally a screwy wear pattern can tick even if parts not loose.
amc49 is offline
Old 10-09-2013, 04:11 PM   #4
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,618, Level 31
Points: 2,618, Level: 31 Points: 2,618, Level: 31 Points: 2,618, Level: 31
Level Up 12% Completed
If the valve is hanging open a bit, it will create excess lash that you may hear as ticking.
You might have a valve seat halfway out.
2.3, home fabbed Mustang GT brakes, SVT suspension
67 Chevelle SS-496, owned since 1991
elsolo is offline
Old 10-10-2013, 12:04 AM   #5
amc49
Fan#: 96610
Forum Activity 40%
I suppose one could even be hearing a loose seat banging back up into head as it tries to fall.
amc49 is offline
Old 10-10-2013, 12:30 AM   #6
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
I agree there is no adjustment on the valves for an SPI but...... I thought I saw numbers stamped on the rocker arms maybe indicating varying heights?
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
Old 10-11-2013, 07:06 AM   #7
amc49
Fan#: 96610
Forum Activity 40%
If like most other hydraulic lifter engines the lifter has about .060"-.080" travel in it, that is enough to make up for errors in rockers, stand heights, cam base circles and the like. The rockers run down to hit solid and lifter should end up somewhere in the middle of that travel to run quietly.
We used to take old school engines and do the 'back off lifter till it taps and then tighten to stop plus 1/4 turn' thingie and you got about 90% of an antipumpup lifter then, with no travel left to pump up, you could rev the piss out of the engine. We freely revved all kinds of engine to way past 7000 rpm doing that and using stock off the shelf doggy lifters.
amc49 is offline
