key made from vin. cost? - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus SVT > Focus SVT
Focus SVT The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the MK1 2002-2004 Focus SVT.
Old 10-06-2013, 04:45 PM   #1
2003SBSVTF
Fan#: 118982
What I Drive: 2003 Sonic BLue SVT Focus
FF Reputation: 1 2003SBSVTF Good Standing Member
so I just realIzed the key for my ignition does not work for the doors or hatch of my 03 svt 5dr. How much does it cost to have a key made from the vin number? And would I be able to rekey the ignition to match the doors? Thanks
2003SBSVTF is offline
Old 10-07-2013, 02:02 PM   #2
Elizabeth
Elizabeth's Avatar
Fan#: 89280
What I Drive: '12 Yellow Focus SE stick, 17"rims
FF Reputation: 14 Elizabeth Great Standing Member
If you have any DIY skills you can take the door locks out and have THEM changed to match the key you have. Ditto hatch.
When i had my purse stolen, I took the door locks out (1997 Mercury Mystique) and just had the pins swapped so it was not possible for the thief to open the doors.
that way no cost and kept other good key. with fob.
Then i had a cheap non fob key cut for doors and stuck that under car. So that key could not start car.
Worked for me.
Probably similar for your car.
So just take the door locks out and have CAR lock guy change them back to fit the key you got.
Ordinary locksmiths may baulk at doing this. Always some specialized automotive locksmith in major cities..
you cannot buy just part of a lockset unless from a junkyard. The doors are way easier to change out than the steering ignition lock.
Elizabeth is online now
Old 10-08-2013, 06:00 AM   #3
boardliquid01
boardliquid01's Avatar
Fan#: 114884
What I Drive: 2003 Silver Ford Focus SVT EAP
FF Reputation: 1 boardliquid01 Good Standing Member
The dealer has the possibility to look up the key punch code for a VIN, however it only goes back so far and I believe that is 2005 or 2006.
boardliquid01 is offline
Old 10-11-2013, 12:39 PM   #4
TWINSCRW
Fan#: 119492
What I Drive: 2002 silver SVT
FF Reputation: 1 TWINSCRW Good Standing Member
I've had keys made by vin for a 2002 Lincoln. I think the cost was around $20 per key but that did not include programming of the chip.
TWINSCRW is offline
Old 10-11-2013, 01:38 PM   #5
2003SBSVTF
Fan#: 118982
Where? Locksmith said $100
Old 10-11-2013, 01:47 PM   #6
TWINSCRW
Fan#: 119492
Actually that was a Lincoln dealer in Florida.
The dealer has the tool to punch out the key based on the code a locksmith is going to have to take a blank and spend a lot of time filing to make a key and it is labor intensive that way.
TWINSCRW is offline
Old 10-11-2013, 01:50 PM   #7
TWINSCRW
Fan#: 119492
The best and easiest way to get a key when you have no original is to go to your local dealer with your VIN and have them make it. Most dealers do require proof of ownership such as a title or valid registration with your name on it and your ID, of course.
TWINSCRW is offline
Old 10-11-2013, 02:20 PM   #8
2003SBSVTF
Fan#: 118982
the dealer does not go back as far as 2003. The route I think I'm going is taking the door lock tumbler out and taking it to the locksmith the only charges $15 a tumbler. Should be under $100 with second key cut and programmed.
Old 10-11-2013, 02:45 PM   #9
TWINSCRW
Fan#: 119492
I'd try a different dealer because I've had keys made at ford dealers for earlier years.
TWINSCRW is offline
Old 10-17-2013, 12:29 PM   #10
TWINSCRW
Fan#: 119492
I just spoke with my local dealer about the keys from VIN and I was told tha after 10 years they are purging the old information from the computer system. Looks like you are right on the edge of the cut off with a 2003.
TWINSCRW is offline
