how to bleed a.b.s? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-03-2013, 07:59 PM   #1
burke_024
burke_024's Avatar
Fan#: 94039
What I Drive: 2000 focus zx3, almost boosted : )
Points 1,562, Level 22
Points: 1,562, Level: 22 Points: 1,562, Level: 22 Points: 1,562, Level: 22
Level Up 62% Completed
FF Reputation: 1 burke_024 Good Standing Member
how to bleed a.b.s?
So i was unaware this zx3 had a.b.s , so i just let it drain i was replacing the master cylinder anyways , but apparently the a.b.s has solenoids that are dry now and i don't know how to prime/fill them ,any ideas or experience,whether or not its an open or closed circuit ,like whether the wires together activate them or apart ? i dont have the sensors anymore .........
burke_024 is offline
Old 10-03-2013, 08:48 PM   #2
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,718, Level 94
Points: 23,718, Level: 94 Points: 23,718, Level: 94 Points: 23,718, Level: 94
Level Up 37% Completed
Level up: 37% Level up: 37% Level up: 37%
Forum Activity 12%
so you deleted the ABS then?
mikebontoft is offline
Old 10-03-2013, 09:04 PM   #3
burke_024
burke_024's Avatar
Fan#: 94039
The abs system is all there except the sensors on each wheel
Old 10-03-2013, 09:29 PM   #4
mikebontoft
Aurelius Pardus
Fan#: 58647
Forum Activity 12%
oh OK. only way to truly bleed it is to find someone with a scan tool that does more than read codes. I had to use OEM Land Rover diagnostics today to bleed the ABS on a Discovery after running the system dry.
Old 10-03-2013, 10:04 PM   #5
burke_024
burke_024's Avatar
Fan#: 94039
Sct?
Old 10-04-2013, 06:00 AM   #6
amc49
Fan#: 96610
Points 3,359, Level 36
Points: 3,359, Level: 36 Points: 3,359, Level: 36 Points: 3,359, Level: 36
Level Up 6% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
Try bleeding first without doing anything. Many ABS are transparent to the braking system when off, they are sealed up from it until valves open. I used to never bleed ABS on my Contour at all and never had a problem ever even though the lines were emptied of all fluid to change it.
Now if it activated with air in lines, yeah, you'll need to power it up to be able to bleed through it.
amc49 is offline
Old 10-04-2013, 09:43 AM   #7
burke_024
burke_024's Avatar
Fan#: 94039
Ok my question is in circuitry ,usually wires connected is on disconnected is off ,or vise versa,I'll keep bleeding but since the sensors are gone I should be able to cross wires and bleed the abs unless this is something completely different like a single leg circuit where the ground/power comes from elsewhere,I'll keep on bleeding Lol only did about four bleeds per wheel Lol just didn't wanna ruin anything
