bogging & hesitation - Focus Fanatics
Old 09-27-2013, 09:10 AM   #1
zx3hero
zx3hero's Avatar
Fan#: 119289
What I Drive: 2002 Yellowstone zx3
FF Reputation: 1 zx3hero Good Standing Member
I have a 2002 zx3 5spd
I changed the fuel filter because of bogging and hesitation, the car ran like new. The next day it was back to bogging and hesitating....
Is there something in the tank? Or is my pump bad?
This is my first post I'm new to this forum and this is my first FORD I used to only buy Chevy. :) thanks for any input.
zx3hero is offline
Old 09-27-2013, 10:14 AM   #2
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Moved to General Technical Chat.
Could be fuel pump going. Depending on the year there was a TSB for bad pumps.
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is online now
Old 09-27-2013, 08:25 PM   #3
CotyM
CotyM's Avatar
Fan#: 85558
What I Drive: blue, y2k, 5spd ZX3, zetec inside
FF Reputation: 3 CotyM Good Standing Member
Any check engine light? If so grab the codes... if not I'd assume the fuel pump if it hasn't been replaced already.
And yes I got root, on all my Android devices
Hatch Nation #32
I'm mad! Your mad! We're all mad here!
CotyM is offline
Old 09-27-2013, 09:59 PM   #4
zx3hero
zx3hero's Avatar
Fan#: 119289
I have a slight idea that its the wrong flow path on filter. I have it going to what seems like the line towards the motor from the gas tank.
I'm switching it tomorrow morn. To check.
I found a wrecked focus with low miles. I was thinking buying the tank and pump for the same price as a new pump. Just to be sure its a clean(er) tank. Or should I get a replacement pump. Or an inline pump and bypass tank pump.
zx3hero is offline
Old 09-27-2013, 10:01 PM   #5
zx3hero
zx3hero's Avatar
Fan#: 119289
no check engine light
zx3hero is offline
Old 09-28-2013, 12:53 AM   #6
Leora83
Fan#: 69136
What I Drive: 2003 ZX5 chrome yellow
FF Reputation: 1 Leora83 Good Standing Member
How bad was the filter you took out? Unless it was totally clogged, I'd guess the tank is fine and your pump is going. Never replaced the one in my 01 ZX3 (394k kms) or the 03 ZX5 (370k kms), so I don't know how common pump failure is.
Coil/plugs/wires/air filter all good? Any of those could cause similar symptoms, and wouldn't necessarily throw a CEL.
Check the new fuel filter to see if it's full of gunk already...if so, you have enough crap in your tank to foul the system. If not, leave the tank alone and test the pump. Also check the wires to the pump for corrosion that could be interrupting the current.
Leora83 is offline
Old 09-28-2013, 05:23 PM   #7
zx3hero
zx3hero's Avatar
Fan#: 119289
I took power off.... Aka reset computer. It ran great again. Now after driving for 10min its back to power loss. Not really bogging but you can tell its hesitating and not all the power is there
Sent from my SPH-L710 using FF Mobile 4
zx3hero is offline
Old 09-28-2013, 05:43 PM   #8
zx3hero
zx3hero's Avatar
Fan#: 119289
Mass air sensor? I cleaned it. Again... Let's see . but I may need a new 1
zx3hero is offline
Old 09-29-2013, 12:33 PM   #9
Leora83
Fan#: 69136
So it's not necessarily related to swapping the fuel pump then.
PCV hose? Those tend to get sucked flat at the bend.
Leora83 is offline
Old 10-02-2013, 01:02 PM   #10
Roadkiller
Roadkiller's Avatar
Fan#: 118593
What I Drive: 2002 Copper Focus ZTS Mach Audio
FF Reputation: 1 Roadkiller Good Standing Member
I had the same problem. It was a bad ignition coil. Search this forum for "hesitation and Sputter during Acceleration Fixed" to see what I did.
Roadkiller is offline
