what just happend - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-27-2013, 03:03 AM   #1
epicskater96
Fan#: 101630
What I Drive: 2002, svt focus, red
FF Reputation: 1 epicskater96 Good Standing Member
what just happend
i was driving down a highway at 55mph, i started slowing down and didnt let off the gas. i pushed the gas down more and my car bogged down and then i procceded to down shift to 5th gear and still did the same thing. i put it in netural and it just died. i pulled it off to the side of the road and tried to start it again and it didnt sound quite right and i heard a loud knock and quit. what happend??
epicskater96 is offline
Old 09-27-2013, 04:31 AM   #2
JRichens
Fan#: 96401
What I Drive: 2006 Light Blue, 1.8 TDCi Focus
FF Reputation: 1 JRichens Good Standing Member
First thing i'd do is get it checked for any Error Codes sitting underneath, could be fuel pressure.
JRichens is offline
Old 09-27-2013, 05:57 AM   #3
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,754, Level 78
Points: 14,754, Level: 78 Points: 14,754, Level: 78 Points: 14,754, Level: 78
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 13%
FF Reputation: 16 Elizabeth Great Standing Member
First thought is fuel pump died.
If the battery can still spin the engine (like starting) but it does not start.. then at least you know the engine can still turn freely. So it is NOT main bearings NOR some mjor internal engine failure. Also not the charging system. Though it could be no spark.
I still would say first bet is the fuel pump is gone.
One loud knock is probably one cylinder ready to fire as engine stopped and a backfire from that cylinder. No big issues from that happening usually.
Elizabeth is online now
Old 09-27-2013, 07:44 AM   #4
amc49
Fan#: 96610
Points 3,368, Level 36
Points: 3,368, Level: 36 Points: 3,368, Level: 36 Points: 3,368, Level: 36
Level Up 12% Completed
Forum Activity 49%
If starter sounded somewhat different from normal you may have lost the timing belt, on SVT the more you try to start the engine the more valves you will bend.
You can check fuel pump spin up by carefully listening as you turn the key till lights come on, you will hear the pump spin up for like a second, if so pump probably OK.
amc49 is offline
Old 09-27-2013, 07:44 AM   #5
CJohn364
GoKart and Me!!!
CJohn364's Avatar
Fan#: 49277
What I Drive: 2K5 ZX4 SEt (ATX) French Blue, Met
Points 73,703, Level 100
Points: 73,703, Level: 100 Points: 73,703, Level: 100 Points: 73,703, Level: 100
Level Up 0% Completed
FF Reputation: 119 CJohn364 Excellent Standing Member CJohn364 Excellent Standing Member
The last time I had a car lose power like that, it was out of oil.
-Carl-
Sedan Revolution #61 / NW Posse #2
FF Moderator
Member Rules
Buy-Sell-Trade Rules
Complete 'How-To' Archive
General Racing Thread Rules
CJohn364 is offline
Old 09-27-2013, 09:52 AM   #6
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Forum Activity 13%
This too. The fuel pump makes a soft wrrr when you turn on the key. Maybe you know the sound?
Anyway ?? Wouldn't the engine have made a variety of 'bad' sounds when it was losing power.. basically bending valves etc.. (if the timing belt went??)
Old 09-27-2013, 10:26 AM   #7
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
Points 626, Level 12
Points: 626, Level: 12 Points: 626, Level: 12 Points: 626, Level: 12
Level Up 52% Completed
FF Reputation: 15 mikeeshaq Great Standing Member
How many miles does your SVT have?
When was the last time the timing belt was changed?
mikeeshaq is offline
Old 09-27-2013, 01:59 PM   #8
swansong
swansong's Avatar
Fan#: 83576
What I Drive: 2008 Saab 9-3 Aero SportCombi XWD
Points 2,305, Level 29
Points: 2,305, Level: 29 Points: 2,305, Level: 29 Points: 2,305, Level: 29
Level Up 4% Completed
FF Reputation: 12 swansong Great Standing Member
Buy-Sell-Trade Rating: (4)
Sounds like what happened to me a few months ago. Click for details. My problem was just shitty gas, which may or may not have killed my fuel pump. Fuel pump and filter got replaced, and I had to burn off that tank of gas to get it to run right again.
That said, the safest thing to do is to NOT try start it up again til you check the timing belt. If it looks ok, do the fuel pump key check, keep in mind that its pretty quiet so do this check in a silent garage if possible. If that seems ok, see if you are getting fuel pressure, you'll probably need a handheld tuner or some other tool to do so. Consider replacing the fuel filter, it's cheap and easy as long as you don't have rust issues. Then check spark plugs for spark and damage, or just replace them to be safe. If it still won't start or run right, just try to drain the tank and replace it with good gas. Cheap to try. Then look at replacing the fuel pump, or look elsewhere.
Good luck!
Mine: 2008 Saab 9-3 Aero SportCombi XWD: 92k, Black, Manual, JZW Stage 1. 320hp/400tq.
Gone: 2002 SVT, #1654
Hers: 2010 Focus SES: 84k, Ebony, Auto, Moon and Tune
swansong is online now
Old 10-05-2013, 03:49 AM   #9
epicskater96
Fan#: 101630
so yea it was the timing belt.... blew out my head :( 2 weeks ill have it back and 2500 dollars later. but ill have it back on the road. thanks guys
Old 10-05-2013, 03:50 AM   #10
epicskater96
Fan#: 101630
btw the loud knock was my intake manifold popping off and the car has never had a timing belt done at i just broke 100,000 miles
