Zetec SE clouds of white smoke - no coolant loss - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-26-2013, 08:54 AM   #1
Jayx21
Fan#: 112991
What I Drive: Mk1 focus
FF Reputation: 1 Jayx21 Good Standing Member
Hey so my cars just started pouring cloouds of white smoke from the exhaust..
Symptoms
-no coolant loss
-clouds of white smoke
-pulled plugs and theyre all black (fitted new ones 1 week ago)
-engine is pullin and struggling when setting off
-oil is empty (filed it up less than 6 months ago)
-doesnt over heat
- no management lights on dash
Any ideas... Maybe head gasket? But why would theyre be no coolant loss
Jayx21 is offline
Old 09-26-2013, 10:26 AM   #2
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,314, Level 77
Points: 14,314, Level: 77 Points: 14,314, Level: 77 Points: 14,314, Level: 77
Level Up 66% Completed
Forum Activity 20%
Activity: 20% Activity: 20% Activity: 20%
FF Reputation: 15 Elizabeth Great Standing Member
What does the smoke smell like?
I would guess the smoke is oil, from the description of the plugs and loss of oil.
Elizabeth is online now
Old 09-26-2013, 10:52 AM   #3
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
Definitely oil burning. It should be "blue" oil smoke, not "white" steam from coolant burning.
Check your PCV and do a compression test.
Hatch Nation #90
TboneZX3 is offline
Old 09-26-2013, 12:12 PM   #4
Jayx21
Fan#: 112991
Definitely white smoke
Definitely oil - put tissue over exhaust let it build up and it was black.. Smelled it and definitely oil
Why its white is a mystery
Any more ideas of a route cause?
Will be doing a compression test asap
Jayx21 is offline
Old 09-26-2013, 12:20 PM   #5
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,576, Level 30
Points: 2,576, Level: 30 Points: 2,576, Level: 30 Points: 2,576, Level: 30
Level Up 84% Completed
Forum Activity 8%
I never understood the "white or blue" smoke thing, they both look white to me, maybe I am colorblind and don't know it.
One is smoke, the other is steam
One smells like burning oil, the other smells like sweet antifreeze
2.3, home fabbed Mustang GT brakes, SVT suspension
67 Chevelle SS-496, owned since 1991
elsolo is offline
Old 09-27-2013, 12:22 AM   #6
amc49
Fan#: 96610
Points 3,267, Level 35
Points: 3,267, Level: 35 Points: 3,267, Level: 35 Points: 3,267, Level: 35
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 7%
Well, if you ran the oil to totally 100% empty it should be pretty obvious what's happened............when it finally runs dry you have one minute or less then permanent damage.
amc49 is offline
Old 09-27-2013, 03:54 AM   #7
Jayx21
Fan#: 112991
Engine seizing?
Still cant explain the white smoke but if it is:
I cant understand how the oil would have gone though it was filled 6 months ago and i checked it 2 months ago and all was ok.. (Denial lol)
If it is a replacement an engine + ancillaries can be cheap but cost of getting it in? Doesnt seem logical unless i get some help from a few friends & we spend a good day or 2 on it
Jayx21 is offline
Old 09-27-2013, 07:55 AM   #8
amc49
Fan#: 96610
Forum Activity 7%
Occasionally they don't seize just tear everything up to leak oil past pistons.
You're like my son who thinks oil checked once is good forever. I keep telling him one day that viewpoint will cost him thousands. He doesn't listen and must be shown.
A car can be perfect and suddenly break something and it does not matter if new or old car or anything else, you have to stay on top of that, walking twenty miles some dark and stormy night may be necessary to illustrate the point.
Solid white smoke could eat all oil in car in an hour, so much for your thinking.
Get compression test before you get motor, or maybe look dumb again............casual judgement sucks, even moreso when inexperienced. Did your oil light work?
amc49 is offline
Old 09-28-2013, 04:34 PM   #9
Jayx21
Fan#: 112991
Ouch harsh reality :/..
Oil/engine light never came on as i always wait for those
Lights to turn off before i even start it up so would of noticed it
Compression test will be done in a couple of days..
If all is ok on the compression test what would the likely outcome be?
Jayx21 is offline
Old 09-28-2013, 08:24 PM   #10
elsolo
elsolo's Avatar
Fan#: 96835
Forum Activity 8%
If the compression test is good, then your engine is sucking in oil somewhere along the intake tract (better than through a hole in a piston).
elsolo is offline
