Ford is not the only one with DCT headaches! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 09-25-2013, 11:49 PM   #1
danyall2010
Fan#: 89399
What I Drive: 2012 Red Candy Focus Titanium Sedan
FF Reputation: 3 danyall2010 Good Standing Member
Check out the Hyundai Veloster forums and search the forum:
http://www.veloster.org/forum/9-hyun...-transmission/
Check these out, as well:
http://www.veloster.org/forum/9-hyun...ing-noise.html
http://www.veloster.org/forum/9-hyun...hirring-4.html
danyall2010 is offline
Old 09-26-2013, 01:52 AM   #2
Et cetera
Et cetera's Avatar
Fan#: 117795
What I Drive: 2013 Focus 2L TDCi 163PS (MPS6 DCT)
FF Reputation: 1 Et cetera Good Standing Member
Thanks for sharing. I could not tell if they use dry-clutch or wet-clutch design.
Code name D6GF1, 6 speed, manufactured by WIA (?) based on parts supplied by LuK.
Heard all DCT's are based on LuK's parts, could not verify it independently, though.
Et cetera is offline
Old 09-26-2013, 01:54 AM   #3
BlueIce
BlueIce's Avatar
Fan#: 93794
What I Drive: 2012 Sterling Gray Focus Titanium
Points 1,732, Level 24
Points: 1,732, Level: 24 Points: 1,732, Level: 24 Points: 1,732, Level: 24
Level Up 32% Completed
Forum Activity 3%
FF Reputation: 2 BlueIce Good Standing Member
It's annoying that people on here think it's a problem with Ford. DCT is a pretty new technology in cars like these, there WILL be problems. Maybe it's because I'm coming from a GTI, but the transmission on these is like a god send.
The story behind my avatar:
www.focusfanatics.com/forum/showthread.php?t=293992
BlueIce is offline
Old 09-26-2013, 01:55 AM   #4
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,070, Level 67
Points: 10,070, Level: 67 Points: 10,070, Level: 67 Points: 10,070, Level: 67
Level Up 5% Completed
Forum Activity 20%
Activity: 20% Activity: 20% Activity: 20%
Code name D6GF1, 6 speed, manufactured by WIA (?) based on parts supplied LuK.
The Veloster is using a dry dual clutch design similar but not identical to the one used in the Ford Focus in North America, as well as on the 1.6 L n/a petrol in the Fiesta and Focus in Europe.
In europe the diesels mostly use the DCT450 wet dual clutch transmission.
The D6GF1 is a dry dual clutch transmission. It only has an oil capacity of 1.9 L the DCT250 has a capacity of 1.7 liters, that's just the oil to coat the gears in the transmission, and not provide an oil bath for the clutch plates like in a wet clutch set up.
http://en.hyundai-wia.com/business/a...smission02.asp
Dual Clutch automated manual transmission for FF vehicle
Max. Power (PS/rpm) 140/6,300
Max. Torque(kg-m/rpm) 17/4,850
Control Type Auto
Length (mm) 394.8
Center distance (mm) 191
Oil(L) 1.9
Weight(kg) 73.5
Gear ratio
1st 3.615 2nd 1.955
3rd 1.303 4th 0.917
5th 0.909 6th 0.694
REV 4.530
suss6052 is online now
Old 09-26-2013, 02:19 AM   #5
Et cetera
Et cetera's Avatar
Fan#: 117795
Thanks for the info on the DCT used by Hyundai.
I have the DCT450 with the TDCi (bought in Taiwan).
So far there is no real problem (no grinding noises) with about 1000 miles (3+ months of ownership). But there are some hesitations during shifts and drivability issues -- I could not ascertain if they are turbo-lag related or transmission related.
The frequent up/down shifts (I'd say I could shift a little smoother when I drive a stick shift, and I'd shift much less frequently too), however, are totally transmission related. These can be managed, though, once I get used to it (at least I believe so).
Wife is the primary driver of the focus. I only advised her to use "S" mode more often so far.
Old 09-26-2013, 05:24 PM   #6
gostinger
Fan#: 44867
What I Drive: 2013 SE Black Pack Loaded 5 Spd MTX
FF Reputation: 1 gostinger Good Standing Member
Aren't the DCTs now wet due to seal leakage and contamination.
Sent from my SGH-T989D using FF Mobile 4
gostinger is offline
Old 09-26-2013, 06:23 PM   #7
CunFFS13
CunFFS13's Avatar
Fan#: 117411
What I Drive: 2013 Sterling Gray Ford Focus S MT
Points 2,360, Level 29
Points: 2,360, Level: 29 Points: 2,360, Level: 29 Points: 2,360, Level: 29
Level Up 40% Completed
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 6 CunFFS13 Good Standing Member
Ford, Mazda and Volvo shares the same DCT.... Let's see how often the problems are
CunFFS13 is offline
Old 09-26-2013, 07:10 PM   #8
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
Points 3,035, Level 33
Points: 3,035, Level: 33 Points: 3,035, Level: 33 Points: 3,035, Level: 33
Level Up 90% Completed
Forum Activity 4%
FF Reputation: 12 dan50 Great Standing Member
Mazda transmissions have nothing in common with Ford's DCT, at least in North America. While Volvo uses a Getrag DCT, it is 6DCT450, not the 6DCT250 used in the Focus. The 6DCT450 uses a wet clutch instead of the 250's dry and again are completely different animals.
dan50 is offline
Old 09-26-2013, 07:19 PM   #9
slybarman
Fan#: 105425
What I Drive: 2013 Ford Focus Titanium hatchback
Points 1,664, Level 23
Points: 1,664, Level: 23 Points: 1,664, Level: 23 Points: 1,664, Level: 23
Level Up 64% Completed
FF Reputation: 6 slybarman Good Standing Member
LOL.
MK3 Focus = a lot of good ideas rather poorly executed.
slybarman is offline
Old 09-26-2013, 07:21 PM   #10
slybarman
Fan#: 105425
Hmmm . . let's see:
Ford designed the car
Ford selected the transmission
Ford assembled the car
Ford put their name on it
I bought it at a Ford dealer
Ford wrote the warranty
I gave my money to Ford
I took it to be serviced by a Ford certified technician
Who would you suggest we be upset with . . . the Easter Bunny maybe?
