02 focus front wipers - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-25-2013, 11:33 AM   #1
jasonbi
jasonbi's Avatar
Fan#: 13305
What I Drive: 2002 SVT
Points 4,592, Level 43
Points: 4,592, Level: 43 Points: 4,592, Level: 43 Points: 4,592, Level: 43
Level Up 21% Completed
FF Reputation: 3 jasonbi Good Standing Member
hey, so i get in the car today, turn the wipers on cause its raining...they make one sweep and stop working...cycling the wiper switch i can hear the relay clicking. so i drive to work and park the car for a few hours, get in and try them again, they move half way through the sweep and stop vertical on the windshield. again i can hear the relay clicking so im thinking its not a problem with the switch, the linkage is intact as well so that's not the issue, im thinking the motor is toast again...any thoughts? thanks in advance!!
#3286 OF 4788
jasonbi is offline
Old 09-25-2013, 11:51 AM   #2
Leora83
Fan#: 69136
What I Drive: 2003 ZX5 chrome yellow
Points 473, Level 9
Points: 473, Level: 9 Points: 473, Level: 9 Points: 473, Level: 9
Level Up 46% Completed
Forum Activity 11%
FF Reputation: 1 Leora83 Good Standing Member
Usually when they don't 'park' back at the bottom, it's a bad relay. Does the intermittent function work? If not, that's the culprit.
It's at the top of the driver's fuse panel, conveniently hidden behind a metal support. The relay is a grey rectangular one with 3 vertical blades along the top and 2 horizontal ones beneath...part number in Standard is RY612 and will run you about $20.
When mine failed, I could hear the click when the intermittent function was on, but it wouldn't work.
Leora83 is offline
Old 09-25-2013, 12:36 PM   #3
calebstubstad
Chef Boyardee
calebstubstad's Avatar
Fan#: 103240
What I Drive: 2000 Atlantic Blue LX
Points 2,716, Level 31
Points: 2,716, Level: 31 Points: 2,716, Level: 31 Points: 2,716, Level: 31
Level Up 78% Completed
FF Reputation: 4 calebstubstad Good Standing Member
sounds like the realy
Rally Revolution #43
[HOONIGAN]
Originally Posted by matmatician View Post
Not the bear the zoo deserves, but the bear the zoo needs.
calebstubstad is offline
Old 09-25-2013, 02:11 PM   #4
jasonbi
jasonbi's Avatar
Fan#: 13305
no setting on the wiper switch is working now...the wipers wont move at all. i can hear the relay click when switching from intermittent to reg to fast, so there is power getting to the relay
#3286 OF 4788
jasonbi is offline
Old 09-25-2013, 11:07 PM   #5
Leora83
Fan#: 69136
Points 473, Level 9
Forum Activity 11%
Relay.
Really.
Leora83 is offline
Old 09-27-2013, 10:49 AM   #6
jasonbi
jasonbi's Avatar
Fan#: 13305
motor was toast...fixed now!! thanks!
#3286 OF 4788
jasonbi is offline
Old 12-08-2013, 12:26 PM   #7
Dpritch298
Fan#: 12089
What I Drive: 2010 Sterling Grey SES Sedan
FF Reputation: 1 Dpritch298 Good Standing Member
Just got a 2003 focus for my daughter to add to the focus family. the wipers do not return to the starting location when you turn them off. Is this the relay?
ooh that's gotta hurt
Dpritch298 is offline
Old 12-08-2013, 02:12 PM   #8
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,732, Level 73
Points: 12,732, Level: 73 Points: 12,732, Level: 73 Points: 12,732, Level: 73
Level Up 71% Completed
Level up: 71% Level up: 71% Level up: 71%
Forum Activity 99%
Yup - most likely.
It was for myself when they would stop whenever turned off instead of "parking" like they should. Long needle nose pliers was my "trick" to get the relay out without a lot of disassembly (it's WAY back in there).
http://www.focusfanatics.com/forum/s...ht=Wiper+Relay
I used this thread for info., managed to skip the disassembly portion with the long pliers...
Needed the part # info to order the relay, parts lookup at the dealer was by number not by function so they didn't know which was needed!
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 12-09-2013, 11:30 AM   #9
Leora83
Fan#: 69136
Points 473, Level 9
Forum Activity 11%
It's actually listed as "General Purpose Relay". You just have to make sure the blade arrangement is the same.
I scrapped off a Mazda truck this fall, and noticed it was full of just those relays (even stamped "Ford"), so now I have a handful of them...which means I'll never need one ever again!
Leora83 is offline
Old 12-09-2013, 12:48 PM   #10
Dpritch298
Fan#: 12089
thanks for the info. I will get the relay and see what happens. going to replace the cigarette lighter fuse while m in there as that also does not work. That is high on her priority list so she can charge her phone.
