Installation of electronic a/c temp control - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-25-2013, 12:32 AM   #1
Yossef Gofer
Fan#: 119239
What I Drive: Focus 2007 gray
FF Reputation: 1 Yossef Gofer Good Standing Member
Dear friends.
I own Ford Focus, ca.2006 or so.
I dislike the dumb a/c system since it has no REAL temperature control. As much as I understand, the only way to control the temperature is by mixing hot air, which is an unacceptable strategy in greening world. This means that the a/c always works if engaged, which eventually freezes us, but more disturbing, it is a terrible waste of energy.
I have a little, electronic temperature controller, with more than necessary features (LAE, MTW11 pt100). I would have liked to make use of it and control the compressor on-time just as commonly dome with many a/c systems.
My intention is to wire the output controller relay to compressor clutch relay.
My questions:
1. Am I right and there is no hidden thermostat somewhere that I can just adjust the temperature to a bit higher?
2. Am I going to do a stupid mistake? Will it damage my a/c system?
3. If, in general, it is not a bad idea and might work, does my idea of hooking it to the clutch relay the best way to achieve my goal, or is there a better way?
4. Where would be the best position to locate the temperature probe?
Thank you answerers in advance, for any hint.
Yossef Gofer
Yossef Gofer is offline
Old 09-25-2013, 07:27 AM   #2
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
Points 626, Level 12
Points: 626, Level: 12 Points: 626, Level: 12 Points: 626, Level: 12
Level Up 52% Completed
FF Reputation: 15 mikeeshaq Great Standing Member
Since you wish to do R/D engineering.
You will have to understand 100% your system and obtain ALL Ford manuals
You will also have to study automotive refrigeration completely
On a home/building refrigeration system one cannot start/ stop the compressor whenever , there must be a delay interval after shutting it off.
If it breaks, you get to fix no options for that
mikeeshaq is offline
Old 09-25-2013, 10:48 AM   #3
Leora83
Fan#: 69136
What I Drive: 2003 ZX5 chrome yellow
Points 523, Level 10
Points: 523, Level: 10 Points: 523, Level: 10 Points: 523, Level: 10
Level Up 46% Completed
Forum Activity 14%
FF Reputation: 1 Leora83 Good Standing Member
The simplest solution is to keep the fan on high and set for Recirculate. Run the AC until you're cool, then turn it off but leave the fan running. When you get too warm, turn it back on.
That's essentially what your home AC does. Doesn't make it smarter, IMHO.
Like mikeeshaq says, you have to have an interval (usually 3 minutes or so) between shut-down and restart or your compressor will have a very short life on a home system. Not sure but I'm guessing that's why there's no automatic cycling of the compressor in a car--the intervals would be too short for the system and too long for comfort.
Leora83 is offline
Old 09-25-2013, 04:08 PM   #4
FocusKnot
FocusKnot's Avatar
Fan#: 117505
What I Drive: 2004 Red SE Wagon 2.0 Zetec Auto
Points 1,686, Level 23
Points: 1,686, Level: 23 Points: 1,686, Level: 23 Points: 1,686, Level: 23
Level Up 86% Completed
FF Reputation: 3 FocusKnot Good Standing Member
Since I think you are determined to build your own climate control system, let me see if I can help.
Cycling your compressor clutch is the most common way to control the cabin temperature other than using heat to compensate for the A/C being too cold.
Two options for locating the temperature sensor would be (1) the evaporator coil, or (2) the return air going into the evaporator coil.
You would need to have enough hysteresis built into your design to allow the compressor's high side pressure to come down before re-engaging the compressor clutch. The hysteresis would be a combination of several things: the mass of the sensor, the location (air vs. coil), and the settings of the controller.
Take some pressure readings to see how your compressor is operating normally, and then how it is operating with your controller. As long as you are not short cycling the compressor with high pressures, it is unlikely you will damage it.
One more thing, put a diode (i.e. 1N4004) across the clutch...it has quite an inductive kick when it disengages. Anode goes to ground.
FocusKnot is offline
Old 09-25-2013, 04:19 PM   #5
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
If he were to control compressor cycling using a sensor for the return air, how would that work with recirculation turned off?
Hatch Nation #90
TboneZX3 is offline
Old 09-25-2013, 04:28 PM   #6
FocusKnot
FocusKnot's Avatar
Fan#: 117505
His emphasis seems to be on conserving energy, so recirc mode would be the best way to do that. Otherwise, he could put a small hole located before the blower and sample the cabin air temp even when not using recirc mode.
Old 09-25-2013, 05:57 PM   #7
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,622, Level 31
Points: 2,622, Level: 31 Points: 2,622, Level: 31 Points: 2,622, Level: 31
Level Up 15% Completed
Forum Activity 2%
I toyed with this idea previously on a Buick and also on my Focus.
I was just going to add a thermostatic controlled switch to do the equivalent of pushing the AC button on/off. It would be in series with the AC button.
That's low voltage, low current; why go to the power side of the system instead of the control side?
2.3, home fabbed Mustang GT brakes, SVT suspension
67 Chevelle SS-496, owned since 1991
elsolo is offline
Old 09-25-2013, 09:33 PM   #8
amc49
Fan#: 96610
Points 3,381, Level 36
Points: 3,381, Level: 36 Points: 3,381, Level: 36 Points: 3,381, Level: 36
Level Up 21% Completed
Forum Activity 55%
Going 'green' on a system that dumps its hydrocarbon achieved load every time the car door is opened.
Or, LOL there....................
If you take over clutch switching with a controller, you will be switching a/c on/off without PCM control, I can see idle bumpup issues there when sitting at a light. The idle could get jerky since the IAC not brought to the party.
amc49 is offline
Old 09-26-2013, 09:53 AM   #9
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,675, Level 62
Points: 8,675, Level: 62 Points: 8,675, Level: 62 Points: 8,675, Level: 62
Level Up 75% Completed
Forum Activity 49%
Why not just adjust the fan speed rating while leaving it on max cool or heat? The A/C system uses High and low pressure sensors to determine clutch engagement. If you lower the fan speed, then the condenser will not drop in temp meaning the high pressure side will stay at a higher pressure and the clutch for the AC compressor will not turn on till needed.
That is why when you have the A/C on with a low fan speed in a mild climate it cycles a lot less and is on for less time. where in the middle the heat when you have MAX A/C its on basically for 90% duty cycle or higher.
Just lower the fan speed appropriately. I would work with controlling temp that way before touching the control of the A/C system.
If you tie directly to the clutch then you are ignoring the high and low pressure switches and can cause major damage to the compressor and create a possible dangerous environment.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 09-26-2013, 10:19 AM   #10
FocusKnot
FocusKnot's Avatar
Fan#: 117505
If Yoseff installs his controller in the existing clutch wiring, all the other controls remain in place and the system is fully protected.
Yoseff, you are receiving many suggestions here. What ends up working well for you may be a matter of trial and error. Designing climate control systems for cars is not easy...I did it professionally for many years. But, in those days we often controlled the clutch, heater, and blower to achieve the desired results. Conserving fuel was not something the manufacturers had us consider.
