Need help!!!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-24-2013, 02:26 PM   #1
zetec035
Fan#: 119219
What I Drive: 2003 red ZTS
Points 390, Level 7
Points: 390, Level: 7 Points: 390, Level: 7 Points: 390, Level: 7
Level Up 80% Completed
FF Reputation: 1 zetec035 Good Standing Member
Need help!!!!
my car wont start as soon as you turn the key to start it it blows the starter fuse. it died just before i got home so its in the driveway sitting now. when it was in gear it bucked and died so i coasted home,any suggestions? i also noticed that one wire to the coil pack was burnt. do i need a new harness or what?
zetec035 is offline
Old 09-24-2013, 02:27 PM   #2
zetec035
Fan#: 119219
Points 390, Level 7
its a manual tranny
zetec035 is offline
Old 09-24-2013, 03:39 PM   #3
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,434, Level 65
Points: 9,434, Level: 65 Points: 9,434, Level: 65 Points: 9,434, Level: 65
Level Up 28% Completed
Forum Activity 7%
You can order a new coil pack harness from Ford for under $30 if I remember correctly. They get brittle and brake with age. I would check and be sure there are no other bad wires in that circuit.
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is offline
Old 09-24-2013, 04:17 PM   #4
FoMoCus
Fan#: 109390
What I Drive: 2002 Focus ZX3 Dark Shadow Gray
Points 369, Level 7
Points: 369, Level: 7 Points: 369, Level: 7 Points: 369, Level: 7
Level Up 38% Completed
FF Reputation: 1 FoMoCus Good Standing Member
I'd check for bad grounds. I don't know where all of the are off of the harness but I'm sure there's several. Blowing fuses means you either have a bad ground or you have a hot wire grounding out.
FoMoCus is offline
Old 09-24-2013, 04:53 PM   #5
zetec035
Fan#: 119219
Points 390, Level 7
anyone know where the grounds are? i know where 2 of them are but idk where the other ones are if there is any
zetec035 is offline
Old 09-24-2013, 11:41 PM   #6
Leora83
Fan#: 69136
What I Drive: 2003 ZX5 chrome yellow
Points 519, Level 10
Points: 519, Level: 10 Points: 519, Level: 10 Points: 519, Level: 10
Forum Activity 14%
FF Reputation: 1 Leora83 Good Standing Member
Yep, new harness. Cheap and easy, just splice in the three wires and you're good to go. Mine wasn't burnt, it just had a wee bit of corrosion on the middle wire, so close to the plug you could barely see it. But it was enough to throw a CEL and make it run like crap.
Check the alternator harness for the same thing.
Leora83 is offline
Old 09-25-2013, 02:49 PM   #7
zetec035
Fan#: 119219
Points 390, Level 7
so i looked further into the wiring harness to see if it melted anywhere else. well i found another spot. my exhaust had broke the day before this all happened. and where it melted was over top the exhaust. now having said that. could the fumes get hot enough to melt wires that far up the firewall? they are all separated now. will have pics to follow.
zetec035 is offline
Old 09-25-2013, 03:16 PM   #8
Gi_Jo_Nathan
Gi_Jo_Nathan's Avatar
Fan#: 98931
What I Drive: 2012 Sonic Blue 5Door MTX
Points 368, Level 7
Points: 368, Level: 7 Points: 368, Level: 7 Points: 368, Level: 7
Level Up 36% Completed
FF Reputation: 3 Gi_Jo_Nathan Good Standing Member
Yeah pics will help. I doubt the exhaust will melt wires untless they are pretty close to touching..
If you have a short, it can melt the wires further up.
Jonathan
12 SE HB MTX, IE Tuned, Snorkel DLT, Green Filter(Gray), custom 2.5" cat-back w/borla, Steeda RSB & Short Shift Bracket, JBR Solid Shifter Bushing's, MS3 RMM w/Corksport Inserts, Ti Heads, Redline Tuning Hood Struts, De-chromed
Gi_Jo_Nathan is offline
Old 09-25-2013, 03:37 PM   #9
zetec035
Fan#: 119219
Points 390, Level 7
heres the pics
zetec035 is offline
Old 09-25-2013, 03:38 PM   #10
zetec035
Fan#: 119219
Points 390, Level 7
second pic is the wires all separated.
zetec035 is offline
