puff of blue smoke :/ - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-24-2013, 03:33 PM   #11
Tjrommel
Tjrommel's Avatar
Fan#: 114674
What I Drive: 2013 Oxford white Sedan 5M
Points 1,588, Level 22
Points: 1,588, Level: 22 Points: 1,588, Level: 22 Points: 1,588, Level: 22
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 Tjrommel Good Standing Member
I guess it was blow by, I was at WOT from 1-3 (almost 4th (on a track of course)). I haven't been able to reproduce it. I feel it's either blow by or I knocked a hunk of junk off a valve and what nots. Must say, these cars love cold weather lol.
Originally Posted by Sonic_HedgeHog View Post
That or the new SMurF mod ;)
Tjrommel is offline
Old 09-24-2013, 10:24 PM   #12
Slo86GT
Slo86GT's Avatar
Fan#: 88885
What I Drive: 2013 Sterling Gray Focus SE
Points 3,119, Level 34
Points: 3,119, Level: 34 Points: 3,119, Level: 34 Points: 3,119, Level: 34
Level Up 46% Completed
FF Reputation: 2 Slo86GT Good Standing Member
Had you been driving easy for some time before that? Do you have an aftermarket intake?
It is possible that there is some oil vapor escaping the crank-case ventillation system and making it to the intake where it's circulated by the vacuum there. If you've been driving it easy, sometimes this vapor will puddle, and the first time you get on it after a while, it will ingest the oil. Boom, oil smoke.
Nothing to worry about too much about unless it's extreme, but I'd check the intake tube for oil residue to verify if that's what happened. Disconnect the tube at the throttlebody, wipe the inside with a papertower. If it's more wet than just a little bit black sooty, you may want to check the PCV valve.
2013 Focus SE 5M Daily Driver
2003 Mustang GT V8/Auto Wife's Daily
1986 Mustang GT V8/5M Toy
- Jody -
Slo86GT is offline
Old 09-25-2013, 12:20 AM   #13
Tjrommel
Tjrommel's Avatar
Fan#: 114674
lost an 8th quart of oil over 5500 miles :3
Tjrommel is offline
Old 09-25-2013, 02:50 PM   #14
Slo86GT
Slo86GT's Avatar
Fan#: 88885
That is negligible. I wouldn't be concerned.
- Jody -
Slo86GT is offline
Old 10-13-2013, 08:46 PM   #15
Tjrommel
Tjrommel's Avatar
Fan#: 114674
I did an oil analysis ( I run mobil 1 full synth, I drive hard and change ever 2500-3000 miles as a safeguard). I don't have the sheet however everything was fine, which makes no sense. I have a coolant leak somewhere (I absolultly cannot find it either). I am going in for warranty work tuesday.
Tjrommel is offline
Old 10-14-2013, 11:44 AM   #16
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
Why does it make no sense? Without an indicator in the oil (wear metal, coolant, fuel, etc.), an oil analysis is not going to tell you why you saw blue smoke from your tailpipe, nor is it going to explain your coolant leak.
1/8 quart in 5500 miles is completely normal oil consumption. My engine consumes 1/2 quart in 10,000 miles, and I'm happy about that.
Hatch Nation #90
TboneZX3 is offline
Old 10-17-2013, 01:51 AM   #17
BeepBeep2
Fan#: 119597
What I Drive: 2012 Sterling Grey SEL Sedan
Points 166, Level 3
Points: 166, Level: 3 Points: 166, Level: 3 Points: 166, Level: 3
Level Up 32% Completed
Forum Activity 3%
FF Reputation: 2 BeepBeep2 Good Standing Member
Do you actually have a coolant leak, or is it just low?
My coolant level is below the minimum mark in the reservoir, but it is not dropping. I know a lot of others have had this problem too.
BeepBeep2 is offline
Old 10-17-2013, 04:05 AM   #18
MG_MK3
MG_MK3's Avatar
Fan#: 114522
What I Drive: 2013 Blue Candy Focus Hatchback SE
Points 492, Level 9
Points: 492, Level: 9 Points: 492, Level: 9 Points: 492, Level: 9
Level Up 84% Completed
Forum Activity 2%
FF Reputation: 0 MG_MK3 Newbie
Mine is too.. Never actually had the serviceman look at it, but I know they (are supposed too) check all coolant levels and such at your scheduled oil change.. Not sure if every dealership does this, but mine does. No one has mentioned it and I have had no problems that I'm aware of.
2013 "Blue Candy" Focus Hatchback SE/DCT
AEM CAI | Steeda RMM | ST wing | TTR UMM
2.5 inch straight pipe | 3SDM 0.05 18"x8.5J | KSport Kontrol Pro's
Instagram @miKeyGilmore #MK3SLöCUS
MG_MK3 is offline
Old 10-25-2013, 02:34 PM   #19
DougC
DougC's Avatar
Fan#: 86547
What I Drive: The biggest mistake I've ever made.
FF Reputation: 1 DougC Good Standing Member
Mine uses nearly 1 1/2 quarts in 1800 miles....
DougC is offline
Old 10-27-2013, 10:56 PM   #20
DustyAlex
Fan#: 107712
What I Drive: 2012 Sonic Blue SE
Points 740, Level 14
Points: 740, Level: 14 Points: 740, Level: 14 Points: 740, Level: 14
Level Up 40% Completed
Forum Activity 2%
FF Reputation: 1 DustyAlex Good Standing Member
Normal, direct injection cars will burn oil, and there's specs from factory saying direct injected cars will burn oil up to a certain amount that is "normal".... Why you ask? Because of thinner ring thickness to reduce friction in the cylinder wall that will cause power loss and to increase fuel efficiency. That's why they have gone to a tensioner less accessory belt and electronic steering for the same reason. Also, raunchy smell at the beginning of start up is caused by advanced timing to increase fuel output to "heat up the cat" to make it run better. So if it smells like gas in the morning it is because of that. DO NOT add any fuel injector cleaner or additive unless otherwise specified in the manual or you could f - up your entire fuel delivery system (ours is a return less style)
Sincerely your friendly neighbourhood tech
Labour rate is $60 an hour, if you already tried to fix it $80 an hour, and if you want to help me $100 an hour
DustyAlex is offline
