The trouble with codes - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-22-2013, 10:32 AM   #1
tryingtofixthis
Fan#: 118287
What I Drive: 00 blue FF, 91 black Volks Jetta
FF Reputation: 1 tryingtofixthis Good Standing Member
Okay simply put zetec engine swap and im still chasing reoccuring problems.
Okay here are the codes please help me identify what you can and what problem that could imply.
R20
E005
DTC none
F107
012C
6152
AB-H
EB-H
1L-L
CR-H
A-6D or A-8D (wzas switching back and forth)
B-19
C-D1
D-3F
0152
1255
2255
3255
4107
5000
6000
7000
Now the p codes which I kinda knew about already amd seems to indicate something wrong with egr.
P103
P200
P400
Gasoline, Better burn it while we still can!
tryingtofixthis is offline
Old 09-22-2013, 11:59 AM   #2
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
Where did all that gobbledy come from?
Your problem is likely your not using an scanner/ code reader that plugs into the OBD II port on the left side of the dash under the light switch. You cannot get powertrain DTC codes using the dash diagnostic test, if that's what you're doing; that is for testing the gauge functions and inputs and some PATS/ignition functions only. (It's even called the HEC test mode as in "Hybrid Electronic Cluster" test mode.)
A proper DTC code has four digits after a letter. P103 is meaningless. If it was a proper DTC code it would be "P0103" and your CEL light would be illuminated. I'd buy/borrow a code reader as a first step if your CEL light is on.
What "reoccurring problems" are you trying to fix?
BC_ZX3 is offline
Old 09-22-2013, 01:23 PM   #3
tryingtofixthis
Fan#: 118287
correct i am not using a scanner although some of those p codes did pop up using one (autozone) under different conditions.
also correct that i do not have a cel light which is probably the most frustrating part about this.
i have been trying to find/borrow a code reader in particular the one turbofocus1 advertises for but alas no luck thus far.
in short the issue im dealing with is after a short time of driving and things warm up, when i go to WOT, say on the freeway my car will not downshift properly and the engine seems to bog down as if its missing or recieving too much air and not enough fuel.
Old 09-22-2013, 01:24 PM   #4
tryingtofixthis
Fan#: 118287
and yeah i thought it was odd the P codeswerent in 4 digit too. also i got all these codes from the manual code retreval method.(where you puch in the trip reset button and hold it in while you turn the key to the on position)
Old 09-22-2013, 10:17 PM   #5
spiller
spiller's Avatar
Fan#: 75607
What I Drive: 11 Sangria SE sed, 01 Wht SE Wagon
FF Reputation: 1 spiller Good Standing Member
http://obdii.com/dtcanatomy.html
The second character is for SAE/MFG designation
P0400 - Since certain components that control the EGR valve are mounted to the firewall and not likely changed with your engine swap, are probably your issue. The vacuum lines and connections would be a good start.
Remember that some fluids will eat holes in certain hoses.
P0200 - Injector Control Circuit Voltage ?
P0103 - misfire may be casused by either of the two (though more likely the Injector Control Circuit issue.
spiller is offline
Old 09-22-2013, 10:58 PM   #6
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
P0301 is misfire on cyl 1 my fellow bullet dodging Memphian.
DTC codes with Detailed Descriptions
I highly recommend using those descriptions for these cars over the generic descriptions that come with scanners. Please note that the possible causes are not separated from the test description- the first cause is in the same paragraph as the test description.
P0103 - Mass Air Flow (MAF) Circuit High Input The MAF sensor circuit is monitored by the PCM for high air flow (or voltage) input through the comprehensive component monitor (CCM). If during key ON engine OFF or key ON engine running the air flow (or voltage) changes above a maximum calibrated limit, the test fails.
Possible causes:
MAF sensor screen is blocked
MAF circuit shorted to VPWR
Damaged MAF sensor
Damaged PCM
A MAF V PID (MAF PID) reading less than 4.6 volts (Refer to equivalent grams/second chart in GO to Pinpoint Test DC ) in continuous memory or key ON and engine running indicates a hard fault.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 09-22-2013, 11:34 PM   #7
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,634, Level 94
Points: 23,634, Level: 94 Points: 23,634, Level: 94 Points: 23,634, Level: 94
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
Wtf is all that..
if you get access to a good scan tool, have a friend drive with you and have them watch the maximum g/s value for the MAF (mass air flow) PID at acceration from a stop into second gear. I almost suspect you'll notice an unusually low value.
mikebontoft is offline
Old 09-23-2013, 08:55 AM   #8
spiller
spiller's Avatar
Fan#: 75607
whynotthinkwhynot, P0103... What typo on http://obdii.com did I make? I don't know, but sure enough I pulled the wrong info for the OP's code....
PS: We don't have much gun fire anymore in my neighborhood.
spiller is offline
Old 09-23-2013, 11:22 AM   #9
Leora83
Fan#: 69136
What I Drive: 2003 ZX5 chrome yellow
Points 477, Level 9
Points: 477, Level: 9 Points: 477, Level: 9 Points: 477, Level: 9
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
Forum Activity 12%
FF Reputation: 1 Leora83 Good Standing Member
Memphian? Not Memphisian, or maybe Memphibian?
Leora83 is offline
Old 09-24-2013, 07:37 AM   #10
tryingtofixthis
Fan#: 118287
i have inspected all vacuum lines thoroughly andswaped al vacuum related parts from both cars in andout. what would be the chances of 2 differwnt engines having the same syptoms and the same faulty part,.very low I would assume.
Originally Posted by mikebontoft View Post
Wtf is all that..
your right but I have nobody I know with a scanner, but im not sure it mav related, I have t maf sensors and I have tried them both with same.syptoms occurring as well as the fact I have replaced tje wiring harness when I replaced engine
