A bit of help needed with my Focus race car - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Road Racing & Rally
Road Racing & Rally The place to discuss information about road/rally racing stats, tips and events. Track sanctioned events only.
Old 10-18-2013, 11:38 AM   #51
Gi_Jo_Nathan
Gi_Jo_Nathan's Avatar
Fan#: 98931
What I Drive: 2012 Sonic Blue 5Door MTX
Points 368, Level 7
Points: 368, Level: 7 Points: 368, Level: 7 Points: 368, Level: 7
Level Up 36% Completed
FF Reputation: 3 Gi_Jo_Nathan Good Standing Member
Nice.
Jonathan
12 SE HB MTX, IE Tuned, Snorkel DLT, Green Filter(Gray), custom 2.5" cat-back w/borla, Steeda RSB & Short Shift Bracket, JBR Solid Shifter Bushing's, MS3 RMM w/Corksport Inserts, Ti Heads, Redline Tuning Hood Struts, De-chromed
Gi_Jo_Nathan is offline
Old 10-19-2013, 12:38 AM   #52
Leora83
Fan#: 69136
What I Drive: 2003 ZX5 chrome yellow
Points 477, Level 9
Points: 477, Level: 9 Points: 477, Level: 9 Points: 477, Level: 9
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
Forum Activity 12%
FF Reputation: 1 Leora83 Good Standing Member
We tested the '01 Celica GTS, a whole new beast from the '83-85 RWD we ran before. Started out loose, improved with some spring rubbers and tire pressure changes, ended in the B Main running over a doofus who spun himself in every turn and bent the front right strut. There's one way to get camber!
We finished and drove it on the trailer, which was about what we expected. Actual finishing place was something like 56th out of 30 cars...
Should have known how it would go, since after leaving home the very first road we turned onto had fresh manure all over it...and soon so did the motorhome, hauler, trailer, even the racecar! Smelled like a barn all weekend. A sh!tshow from the start...
Leora83 is offline
Old 10-19-2013, 05:57 AM   #53
teamDFL
teamDFL's Avatar
Fan#: 92060
What I Drive: 2001 ZX3, 2012 SE Sport Hatchback
FF Reputation: 6 teamDFL Good Standing Member
Add a baffled pan and/or accusump. Those engines have zero oil control and starve badly.
Rich aka Dr. Bilkenstein, the three footed hobbit
Rally Revolution #21
teamDFL is offline
Old 10-20-2013, 08:44 PM   #54
FastFocus50
Fan#: 118010
What I Drive: 2000 ZX5
FF Reputation: 1 FastFocus50 Good Standing Member
Good advice on the baffles. I hadn't thought of that for this car. I put baffles in the oil pan on my road racing car as the speeds were higher and we would be in the corners longer. But come to think of it, a third mile oval is almost all corner. I hope its an easy job to drop the oil pan. Thanks for the tip
FastFocus50 is offline
Old 10-20-2013, 08:46 PM   #55
FastFocus50
Fan#: 118010
It sounds like you had a sh_tty weekend. Watching the other races is tons of fun but not so much when your's is bent and in the trailer.
Old 10-20-2013, 09:23 PM   #56
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,393, Level 61
Points: 8,393, Level: 61 Points: 8,393, Level: 61 Points: 8,393, Level: 61
Level Up 81% Completed
Level up: 81% Level up: 81% Level up: 81%
Forum Activity 30%
I would not worry about oil baffel. The oil cloud is not that bad. I have looked into oil scrapers and my research showed there was little to no gain in it. Not sure where that thread went. Do a search on this site for "oil scraper" should come up with it.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 11-05-2013, 10:05 AM   #57
Leora83
Fan#: 69136
Points 477, Level 9
Forum Activity 12%
The oil pan is very easy to drop. Just be really diligent about the RTV when you're reinstalling it or you'll miss a tiny spot and end up with leaks (then have to scrape it all off and redo it, grrr).
Some of our guys swear by the baffles, some have never bothered and haven't had any problems. Seems an easy enough thing to do, and hey, you have all winter now.
Leora83 is offline
Old 11-05-2013, 10:13 AM   #58
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 30%
If your set on doing it. check this guy out.
http://www.crank-scrapers.com/Ford_Lima.html
Has some good setups for some fairly good prices.
Hatch Nation #42
Old 11-06-2013, 08:09 AM   #59
teamDFL
teamDFL's Avatar
Fan#: 92060
I am not talking about oil scrappers of misting. I am talking about g-forces causing the oil to climb the side of the block, moving away from the pickup. It is a known problem with that engine. Was on the Celica GT-S that ran in the Long Beach Celebrity races. Is a problem with the engine in a Lotus.
Moroso 20970 - http://www.moroso.com/catalog/catego...?catcode=11930, bottom of the page - is made for a reason. Call TRD and ask them. The factory pan does not provide adequate oil control.
teamDFL is offline
Old 11-06-2013, 09:38 AM   #60
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 30%
I understand that. But the link provided appears to be just a integrated windagetray and oil pan.
The baffles are not sealed along the edges of the pan so the oil can still push out to the sides due to centripetal force.
I would just check your oil levels before a race as you already should and fit your self an oil pressure gauge.
Hatch Nation #42
